E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > 330d cold start problem help!
      12-02-2014, 01:20 AM   #1
Mrhaggis
Hi guys wondering if anyone could advise on a problem i am having with my 2009 LCI 330D 38000 miles on the clock
I have owned the car for little over a month and after having it for around a week i started having cold start problems with a lumpy idle, car was taken to the garage and they checked the glow plugs which were fine but found a problem code with the glow plug control which they changed for a new one.
I have now started having the same lumpy idle on cold start again and its only been a week or two since the control unit was changed. Anyone else had this experience? should i clean the EGR or could it be the swirl flaps i have heard people mention??
Any help would be greatly appreciated.
      12-02-2014, 04:47 AM   #2
AzRiz
AzRiz's Avatar
130
Drives: E92 M3 LE500
Used to happen on my car too (330d LCI) but stopped doing it a few months back.
What fuel do you use?
I used to use V-power but now I just use standard diesel and it feels like this choice in fuel has possibly stopped the mentioned issue.
Progress Thread | Instagram: @azriz
      12-02-2014, 06:11 AM   #3
'V'
Drives: ~Carbon black F36
I find the fuel I use has big effects on my 330d (although an early pre-lci 231hp) it only seems to like BP ultimate and drives like shit with anything else, especially Tesco fuel - so my club card is now redundant LOL!!!
      12-02-2014, 06:49 AM   #4
Mrhaggis
I have tried various types of fuel but neither has made any difference!
      12-02-2014, 07:10 AM   #5
John320d
John320d's Avatar
31
Drives: BMW 320d E93
Have your codes checked again and see if your new controller is faulty
      12-02-2014, 08:35 AM   #6
oldbilly
Drives: 330d e91 M Sport
maybe now the controller is working the glow plugs have given up, are there any codes since fitting the controller?
      12-02-2014, 09:59 AM   #7
littlejohno
Drives: BMW 130I M Sport
Mine has a lumpy idle now and then from cold lasts around 10 seconds or clears if you rev the car 2010 Lci 330d.
I use shell v power its unburnt diesel for sure as you can smell it but the car starts instantly just put a tank of standard fuel in see how that goes.
      12-02-2014, 10:04 AM   #8
Mrhaggis
I have tried this but didnt seem to make any difference, going to take it back to the garage again and see what codes come up. Pretty annoyed as i havent had it long! i have a 2004 peugeot van and nothing ever goes wrong with it!!!
      12-02-2014, 10:12 AM   #9
AzRiz
AzRiz's Avatar
130
I would suggest coming off V-power and using the standard Shell diesel for a couple of tanks. I know you said that you have tried different fuels but it does take a good couple of tanks to get rid of the previous fuel. Usually I'm the type to recommend using premium fuel options (my petrol cars only use Shell V-power unleaded) but this was the only change that I made which cured the issue of the lumpy idle described in this thread. It now starts beautifully and smoothly.
I haven't noticed lumpy idle since summer time which is roughly when I stopped using Shell V-power diesel. Could just be luck, or something else that has changed, but it hasn't happened for months now and I'll be staying away from Shell V-power diesel in this car.
      12-03-2014, 01:12 AM   #10
Mrhaggis
Well it was minus 2 this morning when i started the car up, it was really rough on idle all for about 10 seconds or so. Going to take it back to the garage and see whats going on.
      12-03-2014, 12:36 PM   #11
ryanwarriors9
Drives: F11 530D
mine does this now and again when its really cold but lasts about 5 seconds then is fine not sure what it could be
if you have any luck keep us updated
      12-06-2014, 04:08 AM   #12
Precision Engineered
Drives: M sport
See here http://www.e90post.com/forums/showthread.php?t=1060029
Could be one of a few things. Last thing they changed on mine was glow plug leads (HT Leads?) but I've not had chance to fully test yet to see if its resolved the issue.
      12-08-2014, 03:37 PM   #13
Mrhaggis
Well heard back from the garage and the problem a faulty swirl flap actuator, getting it sorted tomorrow hope that will be the end of the problem! And I can now enjoy my car!
      12-09-2014, 06:22 AM   #14
littlejohno
let me know the cost as i have a background code for a flap if you dont mind..
Darren
      12-09-2014, 02:31 PM   #15
Mrhaggis
Darren
Was done under a warranty but i think the part was between £200-300 and a good days labour as the intake manifold has to come off etc
      12-10-2014, 11:29 AM   #16
oldbilly
They must have done a lot more work if it took all day, to change swirl flap actuator is an easy job, on my 330d I can remove the manifold in 40 minutes.
      12-15-2014, 06:58 AM   #17
Mrhaggis
I left it with them for the day so i have no idea how long it took them, plus it was done under the warranty so didnt cost me a penny
      12-16-2014, 03:20 AM   #18
littlejohno
If you do find out let me know and pleased it's sorted have you noticed and other differences
e90post
