ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      11-30-2014, 02:55 PM   #1
2sporty
Germany
244
Drives: bmw
Question Why does the power stay on after I turn off the car
I press the engine stop button and my V1, which is connected to the cigarette lighter, stays on. On my E92 M3, it used to always turn off. Does it ever turn off?
      11-30-2014, 03:13 PM   #2
fortressmaximus
Drives: BSM M4
Press the on/off button one more time lightly to turn all the other stuff like radio off if you have already switched off the engine. Alternatively, hold your finger longer on the on/off switch while the engine is running to shut everything off with one button push. I think this should work but haven't used the V1 with this new car so I may be wrong.
2sporty243.50
      11-30-2014, 03:16 PM   #3
2sporty
Germany
244
Drives: bmw
Originally Posted by fortressmaximus View Post
Press the on/off button one more time lightly to turn all the other stuff like radio off of you have already switched off the engine. Alternatively, hold your finger longer on the on/off switch while the engine is running to shut everything off with one button push. I think this should work but haven't used the V1 with this new car so I may be wrong.
I did this. When the radio is off, the cigarette lighter power stays on still.
      11-30-2014, 03:46 PM   #4
fortressmaximus
Drives: BSM M4
Ok, too bad that didn't work. Hopefully, someone else will chime in if there is a way to do this.
      11-30-2014, 04:08 PM   #5
shortseller
shortseller's Avatar
Drives: ‘18 ABM F80ZCP/dct
I find this info very helpful, thank you.
      11-30-2014, 04:27 PM   #6
fortressmaximus
Drives: BSM M4
You're welcome! Glad I could help. Hopefully someone can find an answer to help the OP with the cigarette lighter issue.
      11-30-2014, 04:34 PM   #7
joeyb26
Drives: 2020 M340i xDrive
pretty sure once you lock the car everything shuts off
2016 340i xDrive 6MT (regretfully sold)
2020 M340i xDrive
      11-30-2014, 04:38 PM   #8
3er
3er's Avatar
Drives: 2019 BMW M5 Competition
From what others have said, the "hold the on/off button trick" no longer works on the F8X.
http://f80.bimmerpost.com/forums/sho....php?t=1054818
2019 ///M5 Competition
On Order: 2023 ///M3 Competition xDrive
      11-30-2014, 04:40 PM   #9
Seagull
Seagull's Avatar
Drives: F87 M2, E84 X1
I drive an F30 and I leave the radio on when I'm unloading the groceries etc. Once I lock it, the radio and everything shuts down. Hence I never specifically turn off the radio or any other system when I leave the car. It all will shut down when I lock it.
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
      11-30-2014, 04:41 PM   #10
fortressmaximus
Drives: BSM M4
Dang. That used to work on my e92. I've been doing the push once to turn off engine and push a second time to turn the radio off in the m4. It's a shame that the holding it down for a longer period doesn't work on the m4.
      11-30-2014, 04:42 PM   #11
shortseller
I had a radar detector for a bit in my f80, plugged into the socket, the power never seemed to go out. I ended up having to power down and up the unit with it's own power switch, till I returned the unit. I don't think these plugs have an on/off function.
      11-30-2014, 04:43 PM   #12
w00tw00t
w00tw00t's Avatar
Drives: 2016 MW M4
the cig lighter turns off a while after power off. I don't know how long but I think in about under a minute..
      11-30-2014, 04:44 PM   #13
w00tw00t
w00tw00t's Avatar
Drives: 2016 MW M4
I hardwired my RD to avoid this hassle..
http://f80.bimmerpost.com/forums/sho....php?t=1061438
      11-30-2014, 04:53 PM   #14
domd817
domd817's Avatar
79
Drives: '16 YMB F80 6MT
Agreed. Mine does the same thing. Never timed it but it does shut off eventually and will turn back on if I unlock the car/open the door.
      11-30-2014, 05:05 PM   #15
shortseller
Interesting. The on/off button double tap should do it if it shuts down everything else, which the OP says it doesn't turn off the plug. Mine did stay on but I never sat there to see what happened after a couple of minutes. I guess the OP, if motivated, will just have to go back to the car after 10, 20, etc, minutes to see. Frankly, it is weird these cars don't just shut down fully when turned off on the initial button press.
      12-03-2014, 04:13 PM   #16
StBS
Belgium
Drives: M4 SS
If you push the start/stop button when the car is in "N"(neutral) the engine stops, but the ignition is still on. If you push the button when the car is in "D" or "R' the engine stops AND the ignition is switched off. The power outlets will go off after a couple of minutes both ways
M4 /SS/19Black/DCT/CCB/BlackLeather
First BMW ever
      12-03-2014, 04:15 PM   #17
StBS
Belgium
Drives: M4 SS
I totally mis reader the thread, sorry
First BMW ever
      12-03-2014, 10:42 PM   #18
Lessthanzero
Drives: BMW M3
"Double clicking" the on/off button just turns the engine back on for me.
      12-03-2014, 10:44 PM   #19
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
Take your feet off the pedals.
      12-03-2014, 10:46 PM   #20
Merli
Sunburnt Member
Australia
158
Drives: 2015 F82 M4
Take your foot off the brake pedal and/or clutch...
2019 Deep Blue Tesla Model 3 Performance | 2015 Mineral White F82 M4 | 2010 Burnt Orange Lotus Exige S2
Past: 2009 Ibis White S5 (APR Supercharged V8)
Past: 2004 Imola Red M3 Convertible
      12-03-2014, 10:46 PM   #21
NorCal f80
Drives: M3
Lol. Take your foot off the brake?
      12-05-2014, 02:32 PM   #22
FrankG5
Drives: '15 Silverstone M3
I had mine coded so the electronics go off when I open the door. I don't lock the car in my garage so for me I prefer everything to go off once I open the door.
f80post
