11-25-2014, 07:08 AM | #1 |
Rep 8,083
Headlamp washers
Has the operation of the headlamp washers changed on the F3x? On all my other BMWs, assuming your lights were on, then the headlamp washers would wash every three or four applications of the screen wash.
On my F31 I haven't noticed them activate in the couple of weeks I've had it. As the e9x were forever busting the washers in cold weather I wonder if the F3x washers stop working below a certain temperature? Any ideas?
Ian
11-25-2014, 07:11 AM | #2 | |
Rep 20,651
They should always work first time you have either full lights on or adaptive green light showing. |
11-25-2014, 07:15 AM | #3 |
Rep 8,083
Yes, that's how they've always worked before.
Must be fcuked
Ian
11-25-2014, 07:19 AM | #4 |
Rep 20,651
11-25-2014, 07:20 AM | #5 |
Rep 186
Just make sure that there is a strong enough brew of washer fluid in the bottle for those cold times ahead.
Made the mistake last year and ended up loosing both of mine on the E91 and then had a £400+ bill to get new ones fitted. Very wary now.
2016 F31 335d xDrive M Sport,iDrive 5,Melbourne Red |
11-25-2014, 07:32 AM | #7 |
Rep 8,083
The fluid is not low, it has adaptive xenons, but no dice....
Ian
11-25-2014, 07:52 AM | #8 | |
Stormtrooper
170
Rep 806
I have used for some time BMW Washer Fluid, summer & winter, a ratio of 1 : 1 which gives cover down to minus 23 deg C. Hoping this will always be ample for the London area and controlling calcium corrosion generally. |
11-25-2014, 07:59 AM | #9 |
Rep 8,083
Yeah I use the BMW stuff at 1:1 too, mainly because it smells nice.
Anyone know the if the fuse for the headlamp washers is in the box under the boot floor or the one under the bonnet? (F31)
Ian
11-25-2014, 08:07 AM | #10 | |
Rep 186
Should have checked really before winter started.
11-25-2014, 08:13 AM | #11 |
Rep 20,651
On a side note. I popped to my local dealers parts bit and got some bits and pieces.
For princely sum of £8:46 I got a winter pack - neat little bag, small version of car care kit. 2x1 litre of BMW winter screen wash Demist pads / cloth De-icer And some other bits Nice getting little deals like that |
11-25-2014, 08:20 AM | #12 | |
Rep 1,919
11-25-2014, 09:21 AM | #13 | |
Rep 20,651
The actual winter bag thing contains 500ml screen wash De-icer Smell nice cleaning stuff? Scraper - I rejected it, it's ok for decapatating people - hard sharp plastic. And the bag, same material as the car care lit but smaller. That should be 25 quid, however guy said that was too expensive so we agreed on £8 and on top of that I got the stuff I orginally went in for for free lol 2x 1 litre winter wash and bits n bobs. Also putting feelers out for some alloys for next year, was a nice EBII M235i with black winters on. Also said they need to be nice to me in spring when I get black grills fitted. So bit of a gentlemans agreement there. |
11-25-2014, 09:23 AM | #14 | |
Rep 1,919
11-25-2014, 09:29 AM | #15 |
Rep 20,651
I do take them biscuits now and then
I have not properly bought screen wash for over 2 years. Usually I pop the car in and have everything topped up. Rule is, you don't get if you don't ask. Bought daughter new 46 tv, had 50% off Samsung blu Ray player as part of deal. Far too many people just accept things. |
11-26-2014, 01:58 AM | #16 |
Rep 8,083
An update on this: The headlight washers do work but they've changed the operation over every other BMW I've had and perhaps it's a new thing (car is October 2014 build).
On previous cars the headlamps were washed every three times the screen was washed which sometimes was too frequent IMO, leaving to rapid reservoir emptying. On this they wash every ten times but crucially this is not reset by switching the engine off. As suggested above, I started the car, switched on headlights, activated washers but nothing happened. However, on my journey home after a couple of more washes, the headlamp washers sprang into life. Looking at the coding in FEM_BODY there is WW_ANZAHL_WASCHBET_ZUR_SRA which is Number of washes (screen) before headlamp reactivation, and this is set at 10. I confirmed this by washing the windscreen ten times and then the headlamp washers reactivated. I now need to fill the reservoir but at least it works and that level of frequency is about right.
Ian
11-26-2014, 03:25 AM | #17 | |
Rep 20,651
Well spotted, seems crazy not having them spray when car first starts and first use. Invariably they are minging from driving to destination or from drive home night before. |
11-26-2014, 03:32 AM | #18 |
Rep 8,083
True, it's codable. On the other hand, it might stop them from activating when the car is freezing in the morning. Sometime on my F10, when it was safe, I'd actually switch the lights off before washing the windscreen because I thought it washed the headlamps far too frequently.
On the other hand, they do FA good anyway!
Ian
11-26-2014, 12:47 PM | #19 | |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
11-26-2014, 01:16 PM | #20 |
Rep 3,815
I suspect the part numbers have changed but if you ask parts department you can get the screen wash in large bottles 5L works out cheaper then the 1l refils
F30 335i M Sport - now departed
11-26-2014, 01:18 PM | #21 |
Rep 20,651
