11-22-2014, 02:08 AM | #1 |
Rep 43
Running in a 330d
What's the recommended way and timescales to run in a new car?
What are people's experiences on how the engine changes when it's run in? Cheers |
11-22-2014, 02:21 AM | #2 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
I picked up my 330d on Thursday. I'm just driving it like I did my old car. Various driving speeds and I've giving it a bit of stick already. Cars don't need running in like they used to. Just give it a bit of respect for the first few hundred miles.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
11-22-2014, 02:29 AM | #3 |
Rep 2,511
I went more or less by the guide in the manual.
1200 miles of relatively gentle normal driving less than 90 ish mph and 4000 rpm. I stuck to comfort mode gearbox and tried to avoid kick down. I think at one point or another I marginally exceeded all of these with a fully warm engine... Going from a 20d its hard not to. However, seasonal grip levels should reign in excesses for you. Now knocking on for 9k the engine has loosened up, gained power and increased fuel efficiency. Best of all it's still running in... Enjoy your new motor.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
11-22-2014, 02:37 AM | #4 |
Rep 20,651
I sort of followed the run in period.
Initially, you want tyres and brakes to bed in properly. Then you need to keep it within your limits (sensible ones) as you learn how to drive the car and interact with things like Idrive, adaptive lights etc as you drive. The engine needs plenty variation once at temperature, drive in Eco, comfort, sport. When you get used to the car try it with stick to the left in comfort and in sport, get used to using paddles. Got pro media? Practice with setting it up and using diverts while on the move. Most of all have fun and enjoy. |
11-22-2014, 03:40 AM | #5 |
Rep 976
I used full throttle regularly but kept it in manual to stop it over revving. After 500 miles started increasing the maximum revs in small increments until at 1k I gave it everything
11-22-2014, 05:00 AM | #6 | |
Rep 32,881
11-22-2014, 05:40 AM | #8 | |
Rep 15,858
I suppose some of it depends on the tightness of the engine, (the build tolerance stack), and how an engine is actually run-in. HighlandPete |
11-22-2014, 06:21 AM | #9 | |
Rep 1,404
http://www.bmw.co.uk/en_GB/footer/q-...-and-tips.html Brakes, Tyres and Clutch apparently need running in up to 300 miles (cautious driving), Engine needs up to 1300 miles at varying speeds (guess this depends on the engine?). After that, go for it! (legally and within safety limits of course!)
Current - F80 M3 CP SS/SO | M Performance Extras
Prev - F30 330D M Sport | White | M Performance Kit | Various Extras Prev - E92 330D M Sport | Black | Highline Older - E46 330i | Silver | AC Schnitzer, E36 328i Coupe | White |
11-22-2014, 08:48 AM | #10 |
Rep 1,409
I would not use sport mode in the 1000 miles and not do overtakes with the throttle floored with a cold engine.
I think being gentle with it is probably all you need to do. |
11-22-2014, 10:05 AM | #11 |
Rep 5,021
There is not enough room inside the car to run in it!
Previous: Superman 330d sDrive M Sport + Toys
Present: Red Tornado Golf 7R 5 Dr, DSG + Toys |
11-22-2014, 11:00 AM | #12 |
Rep 44
My 2012 316d sports now on a 102k miles had no kid gloves running in.....the reliability has been great and only had rear discs pads changed. Its no 330d but today's cars are all built to withstand thr performance they deliver,.....my tip drive it that's what you bought it for!
11-22-2014, 11:19 AM | #13 |
Rep 590
11-22-2014, 11:23 AM | #14 |
Rep 915
If I was a serial car changer always operating within warranty then no brainer - why wait for big fun
Personally - as someone who intended to keep car beyond warranty, the few weeks of gentleness in line with manual for peace of mind was worth it. I agree to loosening though, sure my car seems louder and faster than it did a couple of months ago - up to nearly 9k miles and getting better |
11-22-2014, 01:26 PM | #15 |
Rep 152
I kept the engine speed within reasonable limits.
Also, I gave it regular bursts of full throttle at low revs - the theory being that it helps bed the piston rings in and prevents bore glazing. Although I think this more applies to petrol engines with lower cylinder pressure - the diesel has plenty of pressure to activate the rings anyway. But whatever it was fun to do and non-damaging. I found that if you use sport+ in manual mode then full throttle doesn't activate kickdown (so you don't get excessive revs). Mine's now at 14k miles and never used a drop of oil.
F31 330d MSport - Black Sapphire, Coral Red, Pro Media - M Sport+ - Towbar
11-24-2014, 12:11 PM | #16 |
Just waiting...
Rep 11
I remember my brother getting a replacement engine in his E36 M3 with some nice running in instructions left on the passenger seat for him.
From memory it was no more than 4000 rpm for the first 1000 miles, which If I remember correctly was about 140mph ish in 6th |
11-24-2014, 12:20 PM | #17 |
Rep 2,046
I drove it like I stole it from day one, after waiting for the engine to warm up of course. After 30,000 miles it's driving better than ever and has never used any oil.
I have no intention of keeping it past 2 years let alone 3. Last edited by RichardM; 11-24-2014 at 04:27 PM.. |
11-24-2014, 02:49 PM | #18 | |
Rep 1,409
I like the sound of my 330d. It sounds smooth as a purring kitten |
