F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Rubber Inflation Valves (Amended)
GetBMWParts
      11-19-2014, 09:47 AM   #1
Buster Blue
England
77
Drives: F30 EB11 320i MSport
Hi
Just noticed today after looking at another f30 I have rubber valves on my 2013 403's, the other F30 2014 had aluminium valves also on 403's, should mine be aluminium. Also have 0001's if that makes any difference.
I do get pressure sensor information ie it comes up on the dash if the pressers are uneven. can I retro fit to the aluminium when I change tyres and will this then give me individual pressure in each tyre.
Thanks
E46 325is MV Augusta Previously-E30 318is E36 323i
      11-19-2014, 09:56 AM   #2
RhysT1
RhysT1's Avatar
Drives: 430d Gran Coupé
Think this means he has the TPMS (Tyre pressure monitoring system)
      11-19-2014, 10:23 AM   #3
xenon
xenon's Avatar
England
1397
Drives: 2021 G21 330i M-Sport
Yes from April 2014 the full TPMS system is fitted with sensors in the aluminium valve stems. Prior to that the ABS sensors were used.
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      11-19-2014, 11:58 AM   #4
Buster Blue
England
77
Many thanks Xenon do you know if I can retro fit to the full TPMS system when I change the tyres.
Cheers
      11-19-2014, 12:39 PM   #5
SkyJawa
SkyJawa's Avatar
3719
Drives: F10 530d
Been asked a few times recently and the consensus is no - it can be coded but theres no receiving modules or wiring so would throw an error.
      11-19-2014, 12:50 PM   #6
Buster Blue
England
77
Should have bought a 2014, thats always my problem I get there to early!
Thanks
      11-19-2014, 01:22 PM   #7
gr4z
gr4z's Avatar
Drives: i4 e40
I bought a March 2014 registered 330d and found out later it was *manufactured* a month or two earlier. I only found this out after a bought a set of 400m wheels with the new TPMS valves in them they will be in the classified section in the next few weeks when I have fitted my new winter tyres to the 400m's.
Current: G26 i4 M Sport Pro, Tech Pk, Sunroof
Previous: 2016 440i MPPSK, 2014 330d Saloon F30, 2013 Audi S4 Avant, 2011 Mercedes C350
      11-19-2014, 04:31 PM   #8
RichardM
England
133
Drives: G21 M340i LCI
My winter tyres don't have the aluminium valves. Are they easy/cheap to get fitted? Will the car display an error if I don't fit them?
      11-19-2014, 04:56 PM   #9
teaston
Drives: X3 M40d
If your car has TPMS then with the winter wheels you'll get a warning come up in the idrive screen every time you start the car. It just takes one press of the controller to dismiss it so up to you if that'll be annoying enough to warrant £200+ for a set of sensors.
Although, if your winter tyres are RFT then by law you need to have some sort of flat tyre warning!
      11-20-2014, 06:08 AM   #10
johno
Drives: G20 M340ix
In my experience, never mind the legal aspects, you really need a warning because otherwise you just won't notice. I had a RFT warning on my old car and the tyre looked the same as all the rest, so much so that I didn't believe the warning at first. Then I measured it and found it was completely unpressurised.
      11-20-2014, 06:14 AM   #11
RichardM
England
133
As I don't have the sensors does anyone know if there is a way to code the car to use the old ABS method my 2012 car uses? I've looked through the cheat sheets but can't see anything.
      11-20-2014, 06:23 AM   #12
teaston
Drives: X3 M40d
What is it you want to code? Your car has the basic flat tyre warning system, to get full TPMS you have to add the module, sensors, receivers in each wheel arch and cabling.
      11-20-2014, 06:25 AM   #13
gr4z
gr4z's Avatar
Drives: i4 e40
I will have some TPMS sensors for sale in the next week if you are interested.
      11-20-2014, 07:53 AM   #14
RichardM
England
133
I have a new car arriving next week
      11-20-2014, 07:57 AM   #15
teaston
Drives: X3 M40d
Oh I see so you want to use Winter tyres without TPMS sensors?
      11-20-2014, 08:01 AM   #16
RichardM
England
133
Yes, use the same winter wheels/tyres I already have from last year but the new car will have TPMS. Sorry I wasn't clear.
      11-20-2014, 08:06 AM   #17
teaston
Drives: X3 M40d
Good question I want to know the same thing for my next car albeit that's not for 2 winters yet!
Maybe ask @shawnsheridan
      11-20-2014, 08:29 AM   #18
neilv
Drives: 335d xDrive MSport
Stupid question, but is the valve cap part of the system?? I recently had a puncture repaired and they just fitted the standard rubber cap... I haven't noticed any error messages so I'm guessing its not important, just doesn't look as good!!
      11-20-2014, 08:40 AM   #19
RichardM
England
133
As you picked up your car on 1st March 2014 it probably doesn't have TPMS.
      11-20-2014, 08:43 AM   #20
neilv
OK cool, thanks
How did you know I picked up my car on the 1st March btw??
      11-20-2014, 08:55 AM   #21
RichardM
England
133
OK cool, thanks
With only 31 posts it was easy to click on your user name and select view previous posts .
f30post
