11-07-2014, 02:20 PM | #1 |
Rep 47
335d vs 330d: are the engines physically different?
Is a 335d a re-mapped 330d, or is there is more to it than that? Anyone know for sure? Sorry if this is well known.
11-07-2014, 02:28 PM | #2 |
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Yes, they are definitely different. The 335d has 2 turbos to the 330d's 1 turbo. I believe it has a smaller one for quick response low down and then a larger one for higher revs.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
11-07-2014, 02:28 PM | #3 |
Rep 1,409
I would have given BMW an order for a 335d if it wasn't for x drive.
So I'm waiting for a slightly lower powered 330d. The 335d engine has twin turbos I'm told. Not sure if I could buy a twin turbo unit and bolt it on at some stage. Probably not... |
11-07-2014, 02:33 PM | #5 |
Rep 47
Thanks. I found the references to "twin power" on the BMW site unclear, as they use it in relation to the 330d (meaning the type of turbo?), but I could not find anything specific about the 335d.
11-07-2014, 03:15 PM | #7 | |
Rep 3,490
You won't regret it. And a PPK will certainly squash any doubts in the unlikely event you do. |
11-07-2014, 03:17 PM | #8 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Exactly why I ordered a 330d, as didn't want xDrive....
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
11-07-2014, 04:05 PM | #9 |
Rep 3,445
Drives: G22 M440D
Same as me, coming from an E92 335D, didn't want xDrive. The 4/330D is a very sweet all rounder.
D.
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : M440D ¦ Previously : F32 435D : F32 430D M Sport sDrive, 335D E92 2006
11-07-2014, 04:14 PM | #10 |
Rep 19,982
I wonder if xdrive has gained BMW more sales than it has lost it?...
11-07-2014, 04:36 PM | #11 |
Rep 464
Polar opposite here, getting the 335d was an easy choice as I explicitly wanted xDrive and it made no sense to get a 330d xDrive...
It would be interesting to know if there is any difference to the engine internals, probably not I suspect - may have bigger injectors although PDK would suggest they have similar capabilities in terms of fuelling. The sequential turbo charging is quite a complex set-up and requires complexity in the exhaust and intake, as well as ECU to control a smooth cross-over. In terms of drive - the 335d gives more torque across a larger rev range, and higher peak power - it has more of a 'big engine' feel as a result and is quicker all-round. I know a number of ex Audi S/RS owners like myself that have jumped to BMW as a result of xDrive; those who don't want it still have the 335i / 330d PPK / M-power options available, it was about time it came to the UK. |
11-07-2014, 04:38 PM | #12 |
The artist formerly known as AC Schnitzer UK
3609
Rep 4,518
"Twin power" is (deliberately?) confusing but usually means a single twin-scroll turbocharger i.e. a turbo that has two volutes through the turbine (exhaust) housing for a wider spread of torque than a single volute turbo. Due to the different length paths this can produce a slightly offbeat exhaust note.
11-07-2014, 05:40 PM | #13 |
Rep 11,292
From Wikipedia http://en.wikipedia.org/wiki/BMW_N57
Seems there is more pressure too for the 335d.... 57D30Ox has 1800 bar pressure, while N57D30Tx has 2000 bar pressure. N57D30Ox uses single turbocharger, while N57D30Tx uses 2 turbochargers, and N57S uses 3 turbochargers of varying size.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
11-08-2014, 03:50 AM | #14 |
Beemer Heaven
462
Rep 2,941
It's bound to of gained them sales, certainly poaching some Audi customers. The thing that annoys me with the BMW and xDrive is the fitment of the SE suspension. Surely with all the options available when speccing the car, that's a choice an owner should have.
Scott
11-08-2014, 04:00 AM | #15 | |
Rep 20,651
With hindsight I would have still went xdrive but would have had ACS from new (prior to delivery/ collection). I believe the big resale point with the 335d over the 330 will be the EU6 engine rather than just the power output. |
11-08-2014, 04:05 AM | #16 | |
Rep 11,292
Dear BMW, can I have some of my money back due the the fact you dont fit M Sport suspension but charged me for it?
11-08-2014, 04:14 AM | #18 | |
Rep 20,651
Then using the £3k difference put the car through ACS and had say £3k to £4k (depending on discounts) of kit, springs etc fitted). |
11-08-2014, 11:21 AM | #19 | |
Beemer Heaven
462
Rep 2,941
Scott
11-08-2014, 05:42 PM | #21 |
Rep 11,292
Thats what I thought. I'm sure Nisfan mentioned in the past that the rear M Sport brakes where the same as standard but front M Sport brakes are upgraded. More pistons or something.
11-08-2014, 05:58 PM | #22 |
Rep 976
I think it's the other way round, rears are upgraded to two piston. Brake discs are bigger too, 370mm fronts instead of 340 I think.
