11-03-2014, 07:54 PM | #1 |
Rep 3,396
Artificial exhaust note
Does the volume of the exhaust note that is piped into the cabin adjust with the volume control of the audio system?
I ask because I swear today I was running around with the radio off and it seemed like the engine pipe in was barely noticeable, even somewhat non existant through the speakers.
11-03-2014, 08:00 PM | #3 |
Rep 3,396
Fine, call it what you will. Do you have the answer?
11-03-2014, 08:11 PM | #7 |
Rep 3,396
Wasn't trying to be short, just didn't want to get into a debate on where the synthesized noise was coming from. Too much of that already covered here. Just hoping I was able to reduce the volume.
11-03-2014, 08:15 PM | #8 |
Rep 1,517
11-03-2014, 08:40 PM | #10 |
Rep 473
11-03-2014, 11:37 PM | #11 | |
Rep 2,701
Got It: F82 2015 M4 Alpine White / Silverstone
With integrity nothing else matters, without integrity nothing else matters. |
11-04-2014, 08:13 AM | #12 | |
Rep 12,999
Yes, it does...
The ASD module mixes the sythesized engine sound with the iDrive audio outputs before the OEM amp in the standard HiFi system, inside the OEM amp in the HK system. Volume of the ASD then depends of the volume of the OEM amp -which it is based on the iDrive volume knob. Understand as well that OEM amp is still on, and at a minimum volume even when the iDrive volume is all the way down/muted. So engine sound may be heard albeit low level (depending on ASD parameters) during no iDrive volume conditions. Quote:
11-05-2014, 07:10 PM | #13 |
Rep 971
11-07-2014, 12:10 PM | #15 |
Rep 480
11-07-2014, 02:27 PM | #17 |
Rep 971
