E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Settings for V2 low end torque (like 1.47)?
      01-04-2008, 10:17 AM   #1
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
I miss the low end burst of speed with 1.47....I certainly appreciate the overall power that V2 provides, I just dont use the top end that much. Im a quick vs. fast kinda guy...what settings can I tweak with to get it closer to that?
      01-04-2008, 10:24 AM   #2
sflgator
sflgator's Avatar
148
Drives: '09 MB C63 AMG & '08 MB GL450
Are you running 93 octane? If so, what are your TQ Curve settings across the board? I'm running at 94% TQ Curve settings across the board (14.7-15psi max) and with the newer v2.0.2 maps (12-19-07 or later), you'll see much improved low-end TQ.
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod |
| TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers |
      01-04-2008, 10:26 AM   #3
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
I believe it is currently 91 octane but am about to fill up with Premium shell. Currently at 62 miles at 90%.
      01-04-2008, 10:29 AM   #4
sflgator
sflgator's Avatar
148
Do you know which v2.0.2 map you have loaded up? If it's the 12-19-07 or later v2.0.2 map, then you should datalog a couple runs (refer to Shiv's instructions on the Vishnu PROcede Forum), and try bumping up the TQ Curve values (if running 93 octane) by 1-2% to see if you're running between 14.5-15.0psi max @ 5,500rpm. With 93 octane, many of us have ended up ~ 94% across the board.
      01-04-2008, 10:32 AM   #5
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
I have the latest map.......I ran this most recent data log at 90%.
How long should I run at each uptick in % once I set it?
      01-04-2008, 10:39 AM   #6
sflgator
sflgator's Avatar
148
Try datalogging a couple runs when you increase the TQ Curve settings across thew board by 1-2%, until you see your max boost at 14.5-15psi @ 5,500rpm. Make sure you datalog your runs @ WOT to redline in at least 2 & 3rd gears...then check your datalogs to see the max boost @ 5,500rpm and up to redline.
      01-04-2008, 10:42 AM   #7
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
WOT - Wide Open Throttle?
Once I do a run at 92% and check it, I can immediately bump it up to 94% if it needs it?
      01-04-2008, 11:26 AM   #8
sflgator
sflgator's Avatar
148
Exactly; good luck and enjoy!
      01-04-2008, 11:28 AM   #9
NPDAN
NPDAN's Avatar
95
Drives: AW DCT M3
2008 E92 M3  [8.00]
07' E92 335i  [0.00]
Agree 100%..... I run full 100 octane and have my setting at 96% across the board. It definatley has the tq of the 1.47 in the low end now...
      01-04-2008, 12:32 PM   #10
slubu
Never Go Full Retard
slubu's Avatar
182
Drives: White Lightning
What if you are on 91 oct, are you out of luck?
2008 335i
      01-04-2008, 12:38 PM   #11
sflgator
sflgator's Avatar
148
Shiv said it's all about running 14.5-15psi max @ 5,500rpm, so if you're seeing that boost level @ 90% TQ Curve values when running 91 octane, then yes, you should leave it as is. I'm sure Shiv will be tweaking some things for v2.0.3 though.
      01-04-2008, 01:13 PM   #12
rambino
M Master
rambino's Avatar
Drives: M6 / X6M
I run 94.7 octane here in germany...
Think its safe to run 96% across the board. why not dip into 100% down low?
Also when i do my data logging. What is the max PSI that should be safe for my car to run.. 15?
      01-04-2008, 01:19 PM   #13
OpenFlash
Drives: A Lot
You're not seeing 14.1psi at 90%. You're cursor is on the boost spike that occurs when you lift off the throttle. Your real boost pressure is a bit less (don't know exact because there is no boost reading on the way Y-axis in the graph you posted up). Also, you'll notice that that boost dip in the midrange has absolutely no effect on engine torque (as seen by the smooth, constant slope in the RPM graph). The dip is caused by a valve phase change. Boost drops but engine torque doesn't. If we attempted to shove in more boost to keep the boost curve flat, you'd get a torque bump in the midrange.
shiv
      01-04-2008, 03:08 PM   #14
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
shiv
So what is the proper way to take and post a boost log so that I can get (and provide) an accurate reading? Is there no way to tell what PSI i had in this most recent reading?
      01-04-2008, 10:25 PM   #15
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
shiv
Here is another data log that was taken on my way home this evening after bumping up to 94%. What does this one say vs. the earlier one? I notice my peak boost is at 5122rpm and measure 14.6psi.....suggestions?
      01-05-2008, 02:06 PM   #16
yahtzee
El Capitan
yahtzee's Avatar
Drives: fast
I'd really appreciate some feedback..Not understanding why my psi isnt climbing....I made a couple more runs this morning. Here are those two data logs..13.8 and 14.4psi....
I then filled up with Shell 93 (I only had ~20 miles left on reserve 91 octane) and drove approx 15 miles before running this last data log...13.8psi
e90post
