Swapping Motors in a AWD (xDrive) BMW
10-20-2014, 01:02 PM | #1 |
23
Rep 70
Haven't put much research into it but what are the difficulties in swapping a RWD motor into a xDrive BMW. According to BMW, their AWD is rear wheel biased with 100% torque going to the axle that slip is detected on. 40:60 on regular conditions. Which is an electronic AWD opposed to permanent AWD. However their driveshaft has an added plate & electronic motor at the front connected to the gearbox for distribution to both axles.
http://youtu.be/y9XelFndsC8 http://youtu.be/NlUJPca0ePk Is it possible to remove the front wheel drive split, and make the power run 100% to the rear wheels using a custom driveshaft? Is it possible to mimic the AWD's driveshaft with an engine such as, maybe, a 2JZGTE or BMW's own S54? Would the swapped transmission work with a custom shaft that mates to the xDrive system? How can I go about doing an engine swap in a xDrive car? emailed the driveshaftshop.com and they had no clue what I was talking about, maybe you guys can shed some more light and mentor me more on this idea. Thank You |
10-20-2014, 02:10 PM | #2 |
Curmudgeon and Pedant
690
Rep 3,489
Not sure, but I think there's confusion.
1) BMW's xDrive is indeed a full-time awd system. 2) The motor has nothing to do with the awd system, other than the fact that it has a different oil pan (structural) that the front diff mounts to and that the right-side half-shaft goes through (I think there might be another slight difference - routing of a hose or something.) 3) The transfer case sits on the back of the transmission - causes the rear driveshaft to be shorter. 4) Engines have been swapped before. There's a thread somewhere titled (something like) "Can a bmw be rwd like a WRX". Not sure which forum/site. |
10-20-2014, 02:38 PM | #3 |
Rep 1,681
Don't need an engine swap, motors are the same. Some people pull the fuse and apparently that works. This guy just pulled the driveshaft.
http://www.e90post.com/forums/showth...ved+driveshaft He didn't do it purely to make his car RWD, he was chasing down another problem. But apparently it won't kill your car. |
10-20-2014, 03:54 PM | #4 | |
23
Rep 70
I've see RB26DETT Motors come in different configurations, AWD & RWD variants to be precise. That was the reasoning behind me asking if the motor and transmission matter when mating to AWD. That brings me to my next question on if a AWD RB26DETT swap will be easier |
10-20-2014, 05:58 PM | #5 | |
690
Rep 3,489
1) A 335xi has more hp/torque out of the box, and is relatively easy to boost up to 350-375hp or so. Don't really see what you're gaining by dropping a GTR engine in there unless it's the 600 HP one. 2) The 'xDrive front suspension is much different, and heavier than the non-xDrive, so why not go for a non-xDrive car? 3) The transfer case is on the back of the tranny; if you remove it you need the longer drive shaft... if you leave it on you don't, but you're paying the weight penalty of having it... 4) AWD or RWD variant of the GTR engine doesn't matter - you're never going to get AWD with that motor in an E9x chassis as nothing will match up. I'm just totally confused on why you're thinking of doing this. |
10-20-2014, 06:22 PM | #6 | |
23
Rep 70
If I can pull the whole xDrive setup out, run RWD & hook a longer custom driveshaft, my question will then be would a 2JZGTE work? are there any other problems, mechanisms, etc. that the AWD system extends to? Differential or axles for example? I have a close friend who own a xdrive car but in the 328 variant. It has sentimental value to him so he doesn't want to trade or sell for a 335xi or any other car for that fact. We're also rebuilding a 2JZGTE motor. 328xi badge + a 2JZGTE motor = 1 good looking sleeper |
10-21-2014, 06:32 PM | #7 | |
690
Rep 3,489
You're going to want an LSD in the rear in any case. Is the Nissan engine direct injection? Not sure the lift pump in the 335i tank will have the volume and pressure for regular injection. On longevity - considering that the main forum has a current post from a guy with 265K on his 335i, I doubt that the Nissan lasts significantly longer than the N54/N55 (especially modified.) Last edited by floydarogers; 10-21-2014 at 06:39 PM.. Reason: FI |
10-21-2014, 06:58 PM | #8 | |
23
Rep 70
RB & 2JZs aren't direct injection, would need new fuel pumps. I've seen 200,000+ miles 2JZGTEs & RB26s from guys who rape the roads with their cars. The modding is unlimited for those motors. N54s are quite limited at the moment especially considering the price for the mods. Vargas sells turbo kits that cost $7k+ just to make 650whp on E85. $7k can rebuild a 2JZGTE with forged internals & add a sizable turbo making over 800whp pump gas. Wanted something unique with the AWD platform, in a sense mimic an evo or sti for their traction |
10-22-2014, 06:42 AM | #9 | ||
Rep 124
Drives: s2000
̶m̶2̶0̶ > ̶m̶2̶0̶ > ̶m̶2̶0̶ > ̶s̶1̶4̶ >F20C->1̶.̶8̶t̶-> n54
10-22-2014, 09:04 AM | #10 |
23
Rep 70
welding I can be able to do, wiring however I won't. Need some solid answers from guys who can make custom harnesses. Any ideas of shops or websites that specialize in those areas besides the forums?
10-22-2014, 12:59 PM | #11 |
Rep 819
It seems like your mind is set on the RB motor, AND Nothing will match up. You'll have to ditch the entire ECU and computer systems and run the nissan or a stand alone ECU.
You will only do this if this is a track car. Cause I doubt that it will pass inspection in NYS. You're pretty much better off finding another car for the swap. an old schoool bmw? Miata? 240's? |
10-22-2014, 01:04 PM | #12 |
Rep 848
Drives: '01 E39 540iA, '09 E90 M3
You need to be specific like what car this is going into and what engine you want otherwise this whole thread is just pointless speculation. You can put any engine you want in the car provided you have the money. And if you think $7000 is too much to make the power you want then I doubt you'll want to see what it costs for an entirely different drivetrain to be made to work in the car...
E90 M3 DCT LCI | E90 LCI N54 M-Sport(retired) | E90 Technical Docs download: http://j.mp/bmwe90docs *good read, very detailed.
10-22-2014, 01:31 PM | #13 | |
23
Rep 70
10-22-2014, 01:47 PM | #14 | |
23
Rep 70
We already have a 2JZGTE BMW E30. Swap went smooth besides the custom body work to accommodate the intercooler & the usual swap outs of stock E30 parts that can't hold the power (differential, axles, etc.). Gutted the whole electrical & ran a standalone with a racepack. Nothing besides the shell is BMW. Figured in a 2008 BMW, the parts will be strong enough to hold at the most 700whp with the possibility to go beyond. Passing inspection in the sense of what exactly? I know there's MK4 Supras both with standalones & stock computers that pass inspections. Stock computer's with OBD1&2. Will we have a hard time being that it is a 2008 BMW running a different motor? Check engine lights due to the swap? Would a standalone with a custom harness to the BMW computer fix this? Not too knowledgable on how the whole BMW ECU works & how it will work with a standalone |
10-23-2014, 05:45 AM | #15 | |
Rep 72
10-23-2014, 06:20 AM | #16 | |
23
Rep 70
& again I'll mention, I already have the motor. It's just putting the two together that I am here gathering info on. I am 98.73% sure I can put the motor in the car and run it RWD. But I'd like to add a touch of uniqueness and run AWD. If I can't run AWD (reason for me creating this post), then what are the obstacles, that you know of that I may not know of, in gutting out that AWD system and running RWD only? |
10-23-2014, 08:07 AM | #17 |
Rep 147
Hey Baby -
Check out this thread on someone mating the E46's CANBUS system with non BMW motors (in this case, GM engines). This will give you an idea of what is feasible and what's totally out of the realm of reason. Another thread to look at is this thread - http://www.e90post.com/forums/showthread.php?p=16007036 where a user managed to shoehorn in an LS engine into the e90 body and used a custom harness. I have that users email and have been trying to get updates from him with no luck...but it'll give you an idea of the hurdles. Also - if you make this work, I live in DC and travel to NYC often for work - I'd be happy to send you my car for a swap
10-27-2014, 08:03 PM | #19 | |
23
Rep 70
Thanks for replying though, please keep me posted if you hear anything regarding the swap. Your input is appreciated |
10-28-2014, 05:06 PM | #20 | |
Rep 72
I'd love to see something like this done, but it seems like you have a LOT of research left to do, or a HUGE (like astronomically, insanely, boneheadedly HUGE) bill from a custom shop heading your way. |
10-29-2014, 12:11 PM | #21 |
Rep 147
I was doing some research and came across this standalone ECU that has a range of preset CANBUS configurations and can also do custom CANBUS confs as well.
This might be helpful - http://www.vi-pec.com/ecus/i88 I'd also look at that e46 CANBUS post I referenced earlier - itll give you an idea of reverse engineering the CANBUS stuff if you went the route of mating it to the BMW electronics seamlessly. If you dont want to run seamlessly, you'll probably have to run a custom cluster for speed, temp, gas, etc and figure out how to code out the engine error codes, DSC error codes etc
12-03-2014, 09:28 AM | #22 | |
23
Rep 70
I would really like to get the OBD2 to work in tandem with 2JZGTE in order to pass yearly inspection. Do you know if the engine's VIN is uploaded to the DMV upon emissions & OBD2 tests? I haven't given up on this project and it will be done the right way. I have managed to find a way to get past the OBD2 problem but it seems pretty annoying to do yearly OBDII Emissions Testing Waiver You may be eligible to apply for an OBDII emissions inspection waiver if: Your vehicle failed its OBDII retest but received a vehicle report showing the vehicle passed all of the following: The safety inspection. The gas cap test (gas-powered only). A visual inspection of emissions and smog control devices (gas-powered only). The emissions control system on your vehicle is free from any signs of tampering and intact. You have attempted to complete emissions-related repairs to your vehicle, and the repair costs have reached at least $450. You must be able to provide receipts and work orders detailing the amounts and type of repairs completed on your vehicle by a NYS registered repair shop. If you completed the repairs yourself, you may only count parts, not labor, towards the $450 threshold. If you meet the above requirements, then you may apply for a waiver at the time of your retest. Inspectors will complete the application for you, as long as you are able to provide them with all your repair receipts. If your application is approved: You will be issued a waiver that you must sign, which is kept with the inspection station along with other documents regarding your waiver application. Inspectors will affix a new inspection sticker to your windshield that will be valid for 1 year. |
