Trying to keep it within 1%
10-14-2014, 07:11 PM | #1 |
Rep 96
I can't figure out how to use the calculator so hopefully some of you will be able to help me! So I have a set of 19x9 and 19x10 wheels and I'm fitting 235/35/19 in the rear and 225/35/19 up front. Help me out!
10-16-2014, 10:49 AM | #2 | |
Rep 361
225/35/19 - 255/30/19 235/35/19 - 265/30/19 |
10-16-2014, 02:21 PM | #3 | ||
Rep 96
10-16-2014, 07:41 PM | #4 |
Rep 883
Although there is a guy running that same wheel and tire size on the forums and he's XI. Barrique? red e90. I'm on my phone and can't copy the link but search my e90 on style 95s.
10-17-2014, 02:57 PM | #5 |
Rep 1,464
Drives: 2009 BMW 335xi
Three options:
225/35-19 with 255/30-19 235/35-19 with 265/30-19 235/35-19 with 275/30-19 Option 2 is the most common choice because it has the least fitment issues when considering different tire manufacturers and offsets. Option 3 gets you a wider rear tire but may cause fitment issues particularly with LCI cars depending on your rear wheel offset Option 1 is really only used for high offset applications where a stretch is needed to reduce/eliminate rubbing and other fitment issues. This also provides the lowest sidewall and therefore the least amount of wheel protection from road hazards. |
10-17-2014, 03:08 PM | #6 |
can you stand it?
16
Rep 367
sorry to thread-jack, but since people are helping here, maybe i can throw in my specs for some guidance with this "1% difference" aswell...
19x8.5 et35 235/35/19 19x9.5 et40 245/35/19 falken 452 this isnt what i'd normally go with, but a used setup i'm looking at has these tires mounted and just wanted to ensure its ok with the xdrive thanks in advance
__________
When I get sad, I stop being sad and be awesome __________ |
10-18-2014, 08:21 AM | #7 |
Rep 1,464
Fronts are small than rear. I would recommend against that setup.
10-18-2014, 08:23 PM | #9 |
Rep 1,464
215/40 if you are talking about 19s. Not sure if that size even exists. What are you trying to do? Why the wierd and crazy sizes?
10-19-2014, 11:49 AM | #10 | |
Rep 96
10-21-2014, 07:09 AM | #11 |
Rep 12
Google Miata tire calculator.
That's what I used for my staggered setup
2008 e92 335xi
JB4 G5, BMS DCI, ER Chargepipe TialQ bov Custom Magnaflow AxleBack STR 609 staggered 8.5 & 9.5 Ericcson Front bumper, Yellow Halos & Fogs |
10-21-2014, 08:02 AM | #12 |
Rep 664
They will not work with the xdrive, well technically you could mount them and drive and wait for the xdrive to malfunction lol.
But seriously you need at least the 265/30, the 275/30 is even better, if you want to keep the 235 in the front. |
10-21-2014, 12:24 PM | #13 |
Rep 1,464
Well he could run 235/35s all the way around but the rears would be stretched and the fronts wouldn't.
10-21-2014, 10:23 PM | #14 |
Rep 96
I ended up going 225/35 in front and 255/30 in the rear thanks for all the help guys(they aren't actually mounted on the car yet just set them next to it to see how they'll look)
