10-09-2014, 10:24 AM | #1 |
Rep 136
Winter tires question
Hey guys, winter is coming up and its time to look for winter tires!
My question is, is it possible/safe to run 225/40/18 winter tires all around with the OEM staggered wheels? I'm looking to get new wheels in the summer and use the OEM wheels for winter, so I don't want to have 3 sets of wheels/tires sitting around. Thanks! Edit: Forgot to add, I'm looking at the Bridgestone Blizzak WS80 92H XL or LM32 92V XL. Any other tires you guys would recommend?
2018 M3CS Frozen Dark Blue II
2018 AW 440GC 2014 Sapphire Black M235i (sold) 2014 AW F31 (sold) |
10-09-2014, 10:40 AM | #2 |
Rep 75
I asked tired rack and they said it will fit. There are a few other people on here that have 225/40 on all 4s with staggered wheels. This is what I'm planning on doing for my winter setup
10-09-2014, 10:47 AM | #3 |
***** noob
1355
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
I have 225/40 on oem with LM32 (non rft)
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
10-09-2014, 11:55 AM | #4 |
Rep 347
I only go there after I've exhausted all other options.
F22 * (N55 + 6MT) ÷ PSS = FUN
10-09-2014, 12:45 PM | #5 |
Rep 25,989
You shouldn't run into any issues with that setup
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
10-09-2014, 02:58 PM | #6 |
Rep 77
I debated the square setup but ended up with the LMs 225/40 front and 235/40 rear from tire rack.
The diameter is similar to stock and I'll be able to easily tell where each wheel goes. |
10-10-2014, 11:01 AM | #7 |
Rep 294
I got this same setup. I'm using the original wheels for winter tires and just wanted wider rear tires because wheels are wider. Also it is easier to see which wheels go to front and which ones to rear. I did not take 245s because the minimum profile for studded tires is 40 and 245/40 would be too big on my opinion.
10-11-2014, 10:34 PM | #8 |
Rep 765
Anyone able to tell me if these would fit?
http://seattle.craigslist.org/see/pts/4707018263.html 17x8 with +47 offset and 5x120 bolt pattern Front tires are 225/45/17 and rears are 245/40/17. Pretty good deal locally, I think, but is 245/40 staggered okay?
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
10-12-2014, 11:49 AM | #9 |
Rep 1,040
Bridgestone Blizzak LM32 tires seems to be a good choice. Just don't put them on too early as they wear very quickly. I normally wait for the first announce snow fall is coming before I swap out the tires.
10-12-2014, 01:32 PM | #10 | |
Rep 765
Anyone know if these wheels will clear the brake calipers? Even if I have 12mm spacers on the rears?
10-12-2014, 10:52 PM | #11 |
Rep 862
Drives: '19 M2 '21 X5
On my PSS's the car will lay out drifts turning into a street with any power just from being cold in the garage(10C) ... They definitely are 0 use below freezing and even less if there is any ammount of snow or slush.
10-13-2014, 11:14 AM | #12 |
Rep 765
This was the experience of a friend on RE-11s on his 335i. Guess I will keep my eyes open for an off-set of wheels with some all seasons or winter tires just in case.
