Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      10-02-2014, 02:56 PM   #1
BigMacSmallFries
Drives: '19 M5C 911 Turbo F430 GT3 RS
KW Sleeve Kit for F80 M3 Arrived
UPDATE: First car on bimmerpost with KW sleeve kit installed on F80 M3. Pics below.
      10-02-2014, 03:16 PM   #2
Sean@PSI
Sean@PSI's Avatar
Drives: 2021 IOMG M3 Sedan
We will be installing a set next week and will post more info!
      10-02-2014, 03:52 PM   #3
FTS
Enjoying driving
FTS's Avatar
Drives: 645
Sean, it would so great if you guys could test the spring rate range (assuming they are progressive), if at all possible; TIA.
      10-02-2014, 03:53 PM   #4
Black Gold
Drives: M3
yes, there is shockingly little data on these
-spring rate?
-how spring rate was determined?
-spring length?
-minimum drop vs stock (assuming max perch height)
to name a few
      10-02-2014, 04:07 PM   #5
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
-spring rate?
-spring length?
to name a few
I msg'd a vendor about these and he told me to save my money and buy springs.
      10-02-2014, 04:07 PM   #6
SakhirM4
SakhirM4's Avatar
Drives: '15 SO M4/'20 Z4 M40i
2020 BMW Z4 M40i  [10.00]
2015 BMW M4  [8.76]
That's because they are springs, not shocks
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
      10-02-2014, 04:07 PM   #7
FTS
Enjoying driving
FTS's Avatar
Drives: 645
If my calculations are correct based on the H&R TUV submission paper that was posted few weeks ago, the F82 super sport springs at 150# front and 350# rear, I do not know if this makes any sense though, little weird for me to see such wide range in a front heavy car.
      10-02-2014, 07:56 PM   #8
gthirtyfizle
gthirtyfizle's Avatar
191
Drives: E92 M3 AW
Funny, a vendor told me the complete opposite
      10-02-2014, 08:15 PM   #9
SMOKE EM IF U GOT EM!!
SMOKE EM IF U GOT EM!!'s Avatar
Drives: 06' E90 330, 20' F97 X3m
2006 330i SPORT  [7.34]
I see what you did there!
LIVE FAST..DRIVE FASTER!!
      10-02-2014, 10:13 PM   #10
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
It's all about motion ratio. That sounds way too soft, though.
DSC_3369 by Kit W, on Flickr
      10-03-2014, 11:19 AM   #11
Boostin FD
Bored all the time
Boostin FD's Avatar
Drives: Batmobile
They would... it's 3 times the price of springs.
Better get coilovers.
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3...
It all started with an RX-7 (FD).
      10-03-2014, 11:25 AM   #12
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
My thoughts exactly.
      10-03-2014, 05:16 PM   #13
BigMacSmallFries
      10-03-2014, 09:39 PM   #14
Boostin FD
Bored all the time
Boostin FD's Avatar
Drives: Batmobile
Originally Posted by BigMacSmallFries View Post
Measured the difference between front and rear wheel gap. It is 1.7".
In other words if the front is dropped 1.7" and the rear is left at the same height as OEM the wheel gap will be exactly the same.
I don't have the technical info, but is it possible to drop the front 1.7" and keep the rear at the same ride height 0.0"?
Don't know the ranges available.
Thanks!
I did this on my old e92 m3. I only lowered the front with eibachs... Never had any issues and loved the stance.
      10-04-2014, 11:43 PM   #15
BigMacSmallFries
Installed the springs yesterday. Best of all the ride was somewhat floaty before, now it feels like the the E92 M3 again. Looking forward to installing sway bars from Dinan when they are released. Want to make the car give feedback, and ride like the E92 M3 again. I think with the sway bars it will be very similar. Highly recommend this!
      10-05-2014, 06:06 AM   #16
rubber_ducky
rubber_ducky's Avatar
386
Drives: roach coach
OP... great to hear that you're happy with the kit.
Do you have the active or the passive suspension?
      10-05-2014, 09:34 AM   #17
BigMacSmallFries
Active on the F80. I owned both active and passive on the E9x M3s.
The excitement that was partially lost with the more capable suspension/chassis of the new car is simply just toned down a bit and masked. Install these springs and the car really starts to feel like the E92 M3 again. Looking forward to installing the sway bars.
      10-05-2014, 02:27 PM   #18
Black Gold
Drives: M3
I'm a little confused, you think the e92 suspension was better?
The f8x is a more race oriented suspension with a much firmer chassis and solid mounted subframe
      10-05-2014, 04:43 PM   #19
BigMacSmallFries
No, biggest improvement of the F8x M3 over the old one is the suspension, easily. What's lost is the road feel (crevices, cracks, small bumps) because the suspension glides over everything making the car feel floaty and slightly disconnected, not to mention the electric steering. Same story with the new 991s compared to the 997s. Just had a joy ride in my car on some winding roads, these springs bring back all that road detail that the OEM setup hides. Surprised how much more feedback the KW springs give through the chassis compared to the OEM springs. Highly recommend this.
      10-05-2014, 05:24 PM   #20
BigMacSmallFries
We took some accurate measurements based on a full tank of gas, and about 50lbs of weight in the trunk that I always have in the car.
Front needs to be dropped 1.5" so that the top of the wheel edges to the fender flares are the same front and rear. This is the result. Did not want to touch the rear ride height because it is already very low. We confirmed this at the end by remeasuring the heights.
Drop in front: 1.5"
Drop in rear: 0.0"
Note: 20mm/18mm spacers front/rear. No rubbing.
      10-06-2014, 12:44 PM   #21
DBV
DBV's Avatar
776
Drives: G87 M2, G20 330d, Brabus Smart
2023 BMW M2  [8.75]
2018 Brabus Smart  [0.00]
2021 BMW 330d  [0.00]
^^That looks perfect.
      10-06-2014, 12:57 PM   #22
slalomfever
slalomfever's Avatar
Drives: Nardo Grey F80
looks GREAT! how's the overall ride quality?
f80post
