reasonably priced aftermarket struts & shocks for 2010 XI
10-02-2014, 09:14 AM | #1 |
craptastic
18
Rep 281
Hi,
$ is a factor for me. I live in New England, pavement can get pretty dicey re: potholes and winter damage. @ 100k miles, my fronts seem pretty shot, and I'm looking to upgrade to something aftermarket that won't break the bank. I have a 2010 335 XI, any recommendations for something reasonably priced (i.e. for the set of 4, ~700$), that will effectively be an upgrade over stock? I don't race the car, but enjoy great handling during aggressive driving. Looking forward to hearing what you guys recommend! P.S. Are mounts & bushings typically replaced at the same time? Am I correct in assuming nothing will come with the struts & shocks re: bushings/etc and that these would need to be ordered separately? |
10-04-2014, 10:41 AM | #2 | ||
Rep 2,561
http://www.tcklineracing.com/index.c...y&Category=256 https://www.tirerack.com/suspension/...lar=Base+Model More here: http://www.e90post.com/forums/showthread.php?t=352950 (BTW, your shocks were shot about 50K miles ago ;-) Quote:
You should consider re-using OEM ones unless: 1). They are obviously worn off (rubber is cracked, separated, etc). 2). You want to upgrade the car's suspension geometry (if you did, you would already know what you want!) 3). You are paying someone to swam the struts, and want to insure against having to pay again in the next 100K miles (or while you own the car) in case struts/camber plates go bad before you need to replace shocks again. HTH, a |
