Converting silver trim to shadowline?
10-01-2014, 03:15 PM | #1 |
Rep 356
How would I do this? Interested in purchasing a 2008 328i 6MT coupe locally, and it comes with that awful silver window trim.
10-01-2014, 03:36 PM | #3 |
Rep 1,023
Or vinyl wrap it yourself for $50. I just did all the interior trim in my car, my wife's car, and my track car. It's really easy. Haven't decided yet if I want to pull the trigger on my exterior trim.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
10-01-2014, 06:18 PM | #4 |
Fuck it dude, let's go bowling.
888
Rep 2,480
It's really NOT easy! The shadowline trim wrap is far more difficult than interior trim wrapping. I posted my experience here: http://www.e90post.com/forums/showthread.php?t=1000993
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
10-01-2014, 06:25 PM | #5 | |
Rep 405
heat gun? obviously a razor/exacto-knife...I find taking the trim off semi difficult. |
10-01-2014, 06:34 PM | #6 | |
Came to the N55 Darkside
1112
Rep 12,740
10-01-2014, 06:50 PM | #7 |
Rep 307
I'm torn between vinyl wrap or plasti dip.
Just purchased my matte black grilles so def want to do the window trim I'm sure vinyl wrap isn't an easy as slapping in on the trim and calling it a day but I'm still unsure it's so difficult that we would have to pay a shop. Was quoted up to $240 for vinyl wrap Plasti dip is $8 a can Vinyl trim is $25 |
10-01-2014, 06:53 PM | #8 | |
Rep 1,023
As for the interior vs exterior, that's very interesting. I kind of assumed that the exterior trim pieces came off so you could do it separate from the car...
10-01-2014, 07:45 PM | #10 | |
Rep 3,393
More often than not, I have seen people take off their plasti dipped window trim pieces and then had them vinyl wrapped instead. Vinyl is more consistent in its finish versus plasti dip which doesn't come out as smooth on larger pieces at times. Especially when you're dealing with a black finish. Everything shows up more on black. -Don |
10-01-2014, 08:00 PM | #11 |
Rep 3,552
nothing beats oem until you bent it installing it lol or taking old trim off.
Plasti-dip probably looks the worst but it's also a lot cheaper. vinyl is the way to go for window trim.
12.0 @ 117 |
10-01-2014, 08:45 PM | #12 | |
Rep 307
Seems to be same cost as it would to get someone to vinyl wrap it Anyone purchase this from them? |
10-02-2014, 04:07 AM | #13 | |
888
Rep 2,480
1 - shadowline vinyl which comes in 3" and 4" straight rolls 2 - 3m vinyl which comes in sheets Option #1 is made specifically for the shadowline trim look. It really looks good when done. But you see the problem - straight≠curved. Getting that straight roll to bend takes LOTS of stretching. And lots of patience. Heat gun won't help as the film is too thin. Even with the trim off the car, you will have difficulty - I never tried it that way, but I could see how it might even be *more* difficult. In my experience, leaving the gutter trim on the vehicle is the way to go. However, it likely would be easier to remove the sill trim (along the bottom window ledge) for wrapping, because it's a straight piece. With option #1, patience will be rewarded with trim that looks and feels like OEM shadowline. Option #2 is not made for the shadowline look, nor is it made for dealing with the curve of that gutter trim. It is much thicker than shadowline vinyl, and therefore will not curve around angles the way shadowline vinyl does (at least not without heating it to the point of distortion). You would have to buy a large sheet and cut it in the shape of the trim (with excess for tucking, of course). This makes wrapping *very* easy, but obviously with lots of waste. With this option, I would say that removing the trim from the vehicle is the way to go. I can't vouch for the look and feel - I'm sure it would look decent, but I've used 3M vinyl and it is not the same as the shadowline. Hope this helps. Anyone who has experience wrapping the exterior trim in 3M vinyl, please chime in. Yikes!
10-02-2014, 07:13 AM | #14 |
Rep 718
Anyone ever try cutting vinyl to size with a vinyl cutter/printer from a computer? Seems like that could make it pretty easy to put on since you could just have it cut to the shape of the curve. Although you would still end up with a lot of waste.
10-02-2014, 07:22 AM | #15 | |
Rep 130
Drives: 2015 M235i xDrive
http://www.getbmwparts.com/partlocat...catalogid=4462 I don't believe it's considered Shadowline trim but it's matte black, OEM and looks good with my matte black kidney grills. I think I bought mine a little cheaper at the time but and I'd recommend this over all of the other solutions.
Current: 2015 M235i F22 BSM (FBO)
Current: 2015 X5 M Sport CBM (hers) Previous: 2008 335i E90 Tiag (FBO) |
10-02-2014, 08:39 AM | #16 |
Rep 503
Drives: e92
^i bought this also, didn't have patience for paint or vinyl, pick up some extra clips if you go this route
ZSP/ZPP/BMW PE&PI/ BMW CF STRUT BRACE/ EIBACH PRO SYSTEM / H&R WHEEL SPACERS
10-02-2014, 08:44 AM | #17 |
Thats all you need to know.
43
Rep 1,188
I have not seen a wrap or paint job on the trim I like. True Shadowline is easy to spot, get the authentic part.
- M2 2018 LBB / Black
- X5 F15 2016 Mineral White / Black 1981 Delorean number 6489 |
10-02-2014, 08:48 AM | #18 |
Rep 228
No to plasti dip. I tried that on mine came out like sh€t!
It looks grainy, wrong black coloration, it chips easily when rubbed with paper towels when cleaning your windows and tons of prep work for unwanted results. I have not vinyl'd mine yet , but I will be going that direction soon . Probably not going to do it myself. |
10-02-2014, 09:12 AM | #19 | ||
Rep 307
ECS tuning wants $785 for their complete window trim kit $380 is more reasonable considering it costs $200-250 to have shop do vinyl trim. Or I'll try vinyl at cost of $25 and do it myself. If screw it up I'm only out $25 |
10-02-2014, 10:06 AM | #20 |
Rep 503
Drives: e92
Its actually +$430 for coupe, so close to ecs price, but check out my garage, I bought exact same trim kit
10-02-2014, 10:34 AM | #22 |
Rep 503
Drives: e92
^Did you remove and then paint?
Painting would probably be best route, I should've done that, the trim kit I bought is just window trim painted black,
