Starter or Fuel Pump?
09-30-2014, 05:43 PM | #1 |
Rep 102
I tried using search today, but all day I been getting an error msg when I tried to search so I apologize in advance to those who been on here for a while and seen this topic alot but I need some advice.
Went to start the car 3 days ago, didnt start but it cranks like it wants to start for about 2-4 secs but doesnt, no ignition, then either it starts easily on the second push of the start button or it starts at the end of those long 3-4 sec cranks on the first attempt, all days in a row now. ( I noticed the car gave up on it's own after about 3-4 secs the other day ), I was hoping this was a one time thing and it would go away. Wishful thinking. I have no shaking, metal grinding noise, rough idling, shifting issues once it starts up and I drive off. It does not do this any other time for the day, just only that first attempt in the morning and no other time. I bought it used 5 weeks ago so I dont know if battery has been changed, there is a receipt for around $200 for a battery i found in the trunk from 2 years ago. Dont think the starter nor fuel pump (or filter) has been changed out as no mention on the service docs he gave me. I have been reading about this and seem the starter is a well known issue but some think its the fuel pump, filter or battery. No error codes of any kind show up. I dont know what to think. Can anyone advise me which is the likely reason per what I described. I live in So Cal so its not a weather issue either. i have no experience under the hood, I can maybe change the oil and thats about it. Car has about 65k. Last edited by seanay12; 09-30-2014 at 06:12 PM.. |
09-30-2014, 05:59 PM | #2 |
Rep 193
Id say fuel pump if it turns over and then starts up right away. But just my 2 cents. Idk if there are any codes but that usually tells you straight up. Good luck man
Edit: I see there were no codes, reading it again. Since it could be so many things you might have to just wait till somethin poops out |
09-30-2014, 06:09 PM | #4 |
Rep 3,854
Drives: 330i, 135i
Check your Essentric shaft sensor for oil in the connector. Easy to troubleshoot. Just remove the plastic engine cover and disconnect the connector and look inside.
See below. http://www.e90post.com/forums/showthread.php?t=697252 |
09-30-2014, 06:52 PM | #5 | |
Rep 102
09-30-2014, 07:04 PM | #6 | |
Rep 3,854
Drives: 330i, 135i
10-01-2014, 12:06 PM | #8 |
Rep 102
Update: Today when I got in, started right up with no hesistation or long cranking...what's going on here. So 3 days of long cranking before turning over, and today back to normal....wth!
10-01-2014, 12:12 PM | #9 |
Rep 3,854
Drives: 330i, 135i
Do you know how old your battery is? This might be your issue. Take it to your local auto store to have them do a load test on your battery. Should be free.
10-01-2014, 12:49 PM | #12 |
Rep 102
Yea, my battery is about 2 years old it appears, it is not the OEM BMW battery as I took a look at it other day, cant see what brand it is but it starts with a C and is red, white and black label. That big bar/strap that goes across the middle of the batt is covering up the brand label.
There are quite a few around me here that are indy, I will take it in soon and see if they can run some diagnostics on it for sure. Based on what I have seen, I can rule out bad alternator at this point. I have not yet been able to rule out, bad gasoline batch, starter or possibly fuel pump/filter. Could be a failing battery too, I will go and get it checked out this weekend for sure at a local autozone or something and report back. |
