Turbo Sound
09-30-2014, 04:04 PM | #1 |
Rookie
10
Rep 69
Turbo Sound
Sorry in advance if this is a stupid question. I recently had my old engine (109,000 km) swapped to a "newer" engine with (60,000 km) due to a timing failure. Anyway I've noticed that I can hear the turbos spool from the the inside even under fairly modest acceleration. Don't get me wrong I love the sound of turbos spooling, but I didn't notice spooling sound with my other engine. Maybe my old engine had to much other noise from the worn valve train that it masked it turbo sound. Is it normal to hear the turbos on a stock engine from the inside of the car? Again sorry for the n00b question.
09-30-2014, 04:25 PM | #2 | |
Out Boosting...
242
Rep 3,987
Might be a loose pipe, or some kind of intake/exhaust leak. Does it seem to be running perfect? Or some hesitation?
Alpine White M-Sport F30
09-30-2014, 05:13 PM | #3 |
Rep 726
As stated above, intakes and/or exhaust will make it easier to hear them. But yes it is possible, boost leak test, shaft play test may help you narrow down.
2006 Bmw 325xi VMR V715/OE lip/Redlines/Zsp Springs
1999 Eclipse Spyder Gst 16g/264cams/550cc/255lph/corbeau seats/Comp Stage 4 Clutch/ECUflash etc... |
09-30-2014, 05:27 PM | #4 |
Rep 2,872
Could be a small leak or something if it's much louder than before. If you're truly concerned Id bring it back to whoever did the replacement before you dig too deep into the issue yourself.
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
09-30-2014, 07:06 PM | #6 |
Came to the N55 Darkside
1112
Rep 12,740
Swapping engines as in N54 for N55 (highly unlikely of course) or the same engine? or....
The N55 can produce a blow off effect of sorts at times, as it has some sort of atmospheric blow off valve thingy that I don't know the technical name for that the N54 lacked. |
10-01-2014, 09:43 AM | #10 |
Rep 52
10-01-2014, 11:27 AM | #13 |
Rep 184
i dont hear a thing on my 07 335. All i hear is my muffler delete...no whistle at all. Im used to hearing a big loud spool...but then again I came from a 67mm single supra.
10-01-2014, 01:13 PM | #14 | |
Rep 3,158
I've had a louder turbo sound before, but it turned out to be a diverter valve return that I had forgot to lock back down--charge pipe's rear diverter valve return hose wasn't connected.
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
10-02-2014, 06:16 PM | #15 |
Rep 726
I hear my turbo spool on my eclipse! lol jp well...not playing i really do. It is normal i dont know much about bmw, i would hope it is normal!
