Approaching 100K w/ bad wg rattle: Evaluating options - opinions welcome
View Poll Results: What should I do? | |||
RB Turbos | 2 | 28.57% | |
Vargas Turbos | 2 | 28.57% | |
OEM Turbos | 2 | 28.57% | |
Other Turbos | 1 | 14.29% | |
Pay $1,000 to tighten the actuator rod | 0 | 0% | |
Voters: 7. You may not vote on this poll |
09-29-2014, 02:14 PM | #1 |
Rep 374
The title pretty much says it all.
- Approaching 100K (currently at 93-94k) - Car is in good shape: 2007 Montego Blue e90 sport, auto trans - Recent Maintenance (this month): walnut blasting, new brakes/pads, coolant change - Performance Mods: JB4 G5 ISO, 7" VRSF FMIC, BMS DPs, BMS DCI, Alpina Transmission Software - Aesthetic Mods: M3 Rep Front w/ foglight delete & OEM ducts, M Sport Rear w/ BMW Performance Diffuser, OEM M3 tri-stitch steering wheel, BMW Performance Shifter w/ Boot, black grilles/trim/badge, misc. stuff So, the issue is my FRONT wastegate is rattling like crazy. Every tech has said the turbo needs to be removed to fix. I tried it as a DIY and guess what - the turbo needs to be removed to fix. That means a lot of labor, so i might as well put in a new front turbo, and if I'm replacing one i should replace both (save on labor), and if I'm replacing both, i might as well go with better turbos. Therein is the logic that has turned this from tightening a bolt on the wg actuator into a $5,000+ repair. So, what are your thoughts? I'm inclined to go with RBs. There's a great shop near me that can install RBs for $2K with dyno tuning and a Walboro pump. They are, however, recommending replacing all the seals/gaskets and doing a transmission service before doing the RBs - this adds another ~$2K to the sticker price. Not thrilled about spending $7K on this car. I like everything about the car except - would like a manual and would like an LSD. So there you go, thoughts welcome |
09-29-2014, 02:22 PM | #2 |
Rep 2,016
If you don't want to spend that much, find a good used pair of turbos for 500each and a good Indy, you could have the turbos installed for 1-1.5k I would think
Instagram~~"alexverdii"~~~
09-29-2014, 02:51 PM | #4 |
Rep 718
I would not pay to get the actuator rod tightened. That will only be a temporary fix and it will rattle again.
Between OEM and RB turbos, I guess you just need to decide how much you want to spend. I just put on new OEM turbos bc I couldn't justify the amount of money for RBs.
09-29-2014, 03:23 PM | #5 |
Accepting Donations
9
Rep 333
Drives: Montego Blue E92
If you want a manual and don't want to put tons more money in to your current e90 why not sell it and pick up a newer one with a manual and non rattling turbos?
09-29-2014, 05:09 PM | #6 |
Rep 193
Im in about the same boat as you.
07 AW auto 335i with 103k and my turbos are sounding worse every day. I was deciding whether to pony up and refresh the car but it was gonna cost like 9k. I decided to look for a 2010 manual 335 so i can transfer my mods, get the benefits of newer model (oil cooler, lights ect), less miles, a manual trans to handle the power, newer suspension. Then drop like 5k to make it a beast. Better money to satisfaction ratio I believe. |
09-30-2014, 04:00 PM | #7 | |
Rep 374
