Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      09-27-2014, 11:09 AM   #1
schmitzna
schmitzna's Avatar
Drives: 2015 M3
2018 BMW X3 M40i  [0.00]
2015 BMW M3  [0.00]
Coding F80: What worked and what didn't for me
If anyone has any comments on what I need to do to get the things I couldn't get working that would be great!
I don't have the LED headlamps or the Lighting package. Bought enhanced bluetooth. In both cases I should have read the forums before placing my order!!!
Thanks, Bert
These worked for me
REM:
Enable rear view camera at all speeds (keeps cameras on longer, but I think you need to enable PDC at all speeds to get them back on)
D_SCHWELLE_2 Werte=FF
V_SCHWELLE_2 Werte=FF
ACSM:
Disable Welcome 3 Gongs:
3000 → Initialwarnung_GWF_IW = nicht_aktiv
SeatBelt Reminder Lights OFF: set all to nicht_aktiv – werte=00
3000→Gurtzustandsanzeige_Beifahrer_GFW_GZA_BF
3000→Gurtzustandsanzeige_Fahrer_GFW_GZA_FA
Turn Off Seat-Belt Reminder Chimes:
3000 → SeatBeltReminder_SBR_Fahrer = nicht_aktiv
3000 → SeatBeltReminder_SBR_Beifahrer = nicht_aktiv
FEM_BODY Module:
Close windows, sunroof & mirror from key fob:
3053 → KOMFORTSCHLIESSUNG_FB = aktiv 00
3053 → KOMFORT_SCHLIESSEN → WERTE = 09 (Mirror Fold Delay = WERTE * 100 millisec)
3110 → ASP_BEIKLAPPEN = aktiv (werte=01)
3110 → ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = (werte=01)
3110 → ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN = (werte=01)
Turn off MMI when door is opened:
3020 → TCM_LOGIC_R_OFF_DOOR set to: aktiv
Unlock Door on Engine OFF (1 pull):
3040 → CLM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK set to: aktiv
Turn off window roll-up door interrupt:
3050 → FH_TUERAUF_STOP_MAUT set to: nicht_aktiv
Turn on Brake Force Flashing with Hard Braking:
3060 → ESS_AKTIVIERBARER_AUSGANG = bremsclicht blinkend
Ambiance Lighting controlled independent from Dimmer Switch
3070 → AMBIENTE_NACHFUEHRUNG set to: nicht_aktiv
HU_NBT Module:
Set cell phone ringer as primary -- I have changed this back to default -- it seems it takes a long time to start ringing
3003→INBAND_RINGING set to: aktiv – werte=01
Disable Active Sound Design -- I have changed this back to default -- there is no difference in cabin sound between Eco, Sport & Sport+ with windows closed
3000 → ASD_SOUND_OFF set to: aktiv
Enable Video Files from USB
3000→ENT_CODEC_XVID set to: aktiv
3000→ENT_CODEC_XVCD set to: aktiv
3000→ENT_CODEC_OGG set to: aktiv
DVD-in-Motion activated:
3000 → SPEEDLOCK_X_KMH_MAX werte = FF
3000 → SPEEDLOCK_X_KMH_MIN werte = FF
3000 → VIDEO_HANDBRAKE set to: nicht_aktiv
3000 → VIDEO_FRONT_LOCKED set to: nicht_aktiv
3000 → VIDEO_SPEEDLOCK_CONDITION set to: none=00
Remove Legal Disclaimers:
3001 → LEGAL_DISCLAIMER_TIME set to: kein_ld
3001 → MACRO_CAM_LEGALDISCLAIMER set to: kein_ld
Disable Office Function Speed Lock-Out
3000→ OFFICE_MESSAGES_SPEEDLOCK_CONDITION set to: nicht_aktiv
Enable Full Text Lines in Office While Driving
3003 → PIM_DRIVING_TEXT_LENGTH set to: whole text_07
Eliminate Speed Locks for Owner’s Manual & Bluetooth pairing:
3000 → SL02_ES nicht_aktiv
3000 → SL06_IBA_1 nicht_aktiv
3000 → SL07_IBA_2 nicht_aktiv
3000 → SL09 nicht_aktiv
3000 → SL021_IBA_3 nicht_aktiv
Added for those wanting to turn off the amber sidemarker lights with LED headlights (which my car does not have):
From: http://f80.bimmerpost.com/forums/sho...3&postcount=21
Both TMS modules, FDL Code Standlicht Modus 1 & Standlicht Modus 2, change the Werte Value 64 to 00 as follows:
00, 03, 00, 00, 64, 03, 00, 00, 64, 03, 00, 00, 2B, 04, 00, 00
00, 03, 00, 00, 00, 03, 00, 00, 64, 03, 00, 00, 2B, 04, 00, 00
The F80 already did this without any coding:
Auto Start/Stop Remember Last Setting:
3023 → TCM_MSA_MEMORY set to: aktiv
Enable ///M LapTimer
3000 → M_LAPTIMER set to: aktiv
Navi Trip-Import
3000→NAVI_TRIP_IMPORT set to: aktiv
Display Tire Pressure & Temperaure in Vehicle Info:
3001 → RDC_SAFETY set to: aktiv 01
Add GPS Current Location to Navi Menu Items
3000→NAVI_POSITION_MENU set to: aktiv
Enable GPS-Sync for Clock -- F8X cars use the BMW online to sync the clock so this is unnecessary
3000→GPS_UHR set to: aktiv
Disable Audible Chirp/Beep When Locking Car
3000 → ACOUSTICAL_LOCK_CONFIRM set to: nicht_aktiv
Show Digital Speed in MPH in Cluster
3000→BC_DIGITAL_V set to: aktiv-werte=01
These did not work or I did something wrong:
Add Weatherband Radio to sources:
3002 → RADIO_WEATHERBAND set to: aktiv 01
Enable the function of saving video files to NBT Hard Drive for play later
3000 → ENT_MC_VIDEO_SUPPORT set to: aktiv
Enable Speech Input for E-Mail or SMS -- Although this code does not work, you can press and hold the speech button on the steering wheel and have Siri or Google do this
3003 → SPEECH_2_TEXT set to: aktiv
Enable IPCE Web Server @ 172.16.222.1
3000→IPCE_WEBSERVER set to: aktiv
Enable WiFi Hot-Spot
(Need to install a DLNA/UPnP media sharing server on your laptop or phone to be able to use this)
3000→ENT_MC_WLAN_STREAM_DMP_COVERART set to: aktiv
3000→ENT_MC_WLAN_STREAM_DMP_VIDEO set to: aktiv
3000→ENT_MC_WLAN_STREAM_DMP set to: aktiv
3003→WLAN_STATUS set to: aktiv
3003→WLAN_MODUS set to: ap
3003→WLAN_SIGNAL_STRENGTH set to: outdoor
3003→WLAN_CHANNEL set to: channel_1 -14
Last edited by schmitzna; 12-11-2015 at 06:05 PM.. Reason: Added new codes, added amber side marker light codes
      09-27-2014, 11:13 AM   #2
gthirtyfizle
gthirtyfizle's Avatar
191
Drives: E92 M3 AW
Sorry for kinda getting away from ur question, but how or where did u get ur coding done?
      09-27-2014, 11:30 AM   #3
schmitzna
schmitzna's Avatar
Drives: 2015 M3
2015 BMW M3  [0.00]
I bought the cable and did it myself.
      09-27-2014, 04:46 PM   #4
LukasAT
Drives: 2024 BMW X5M
I had the same experience what you wrote .. what worked and what not
      09-28-2014, 02:54 AM   #5
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
Has anyone gotten the high beam assistant Auto On to work?
HighHBeam Assistant – Auto On:
3060 FLA_AKTIVIERUNG set to: werte=02
3073 C_HBA_ENA set to: F030_enable=01
High Beam Assistant – Auto On
3000 HIGH_BEAM_ASSISTANT set to: aktiv – werte=01
This didn't seem to work.
DSC_3369 by Kit W, on Flickr
      09-28-2014, 11:04 AM   #6
NorCal f80
Drives: M3
Is there an Exhaust Valve Open All The Time Code?
      09-28-2014, 11:46 AM   #7
Keto
Keto's Avatar
Drives: F80 M3
2015 BMW M3  [10.00]
Sport plus mode...
2015 SO/SO MT M3 :: Exec : Lighting : Adaptive : HK : CF trim : Full leather : DAP : Black 19's : sunshade
Crystalline tint 40%/70% on windshield : M performance mirrors, spoiler, splitters : Status Gruppe CF lip : RKP diffuser : Fully dechromed
Bavsound Stage 1 : V1 Savvy hardwired : Self-coded
      09-28-2014, 01:13 PM   #8
RickMonet
RickMonet's Avatar
175
Drives: 2015 M3 6MT
Originally Posted by schmitzna View Post
ASD Module:
3000→ Funktionen-Baureihe → set to: F021
Hi Bert - can you comment on how much difference when you turned off Active Sound?
Noticeably quieter cabin?
Better or feel like something missing?
Thanks
      09-28-2014, 03:17 PM   #9
Hoopumpers
Hoopumpers's Avatar
113
Drives: M2 Comp
73 911 RSR  [0.00]
04 996 Cup  [0.00]
06 997 Cup  [0.00]
12 Boxster Spyder ( ...  [0.00]
15 Sierra HD Denali  [0.00]
16 GT3RS  [0.00]
17 Radical SR3  [0.00]
18 Model X  [0.00]
18 GT350R  [0.00]
19 M2 Comp  [0.00]
ASD Module:
Thanks
+1
      09-28-2014, 04:23 PM   #10
schmitzna
schmitzna's Avatar
Drives: 2015 M3
2015 BMW M3  [0.00]
Thanks
The sound difference inside between economy and sport/sport+ is hard to notice with the windows up. I might turn ASD back on.
      09-29-2014, 07:30 AM   #11
schmitzna
schmitzna's Avatar
Drives: 2015 M3
2015 BMW M3  [0.00]
I mostly miss the aggressive throttle blips on the downshifts with ASD off.
There were lots of ASD parameters to code: wonder what happens if you tell it you have a different engine.
For now, ASD is back on and I like it much better.
      09-29-2014, 06:21 PM   #12
kitw
kitw's Avatar
471
Originally Posted by Keto View Post
Sport plus mode...
Nope - sport plus closes the valves at low rpms and low throttle openings to prevent drone.
It's very easy to just unplug them when they are open, though.
      09-29-2014, 07:26 PM   #13
RickMonet
RickMonet's Avatar
175
Drives: 2015 M3 6MT
Thanks.
Lots of talk on this forum about ASD this and ASD that - sounds like you prefer to have it. I plan to run for the first few months with it - then turn off to see if I miss it.
I have asked this forum if anyone has complaints from hands free calling that other party hears engine roar during phone calls (or other background noise) - but have not found an avid phone user to reply, I guess most people are too excited driving their new car to be talking on the phone!
      09-29-2014, 08:13 PM   #14
Keto
Keto's Avatar
Drives: F80 M3
2015 BMW M3  [10.00]
Thanks.
I've talked on the phone for long periods when i was driving from ATL to NOLA. No complaints.
      09-29-2014, 08:28 PM   #15
fourtailpipes
Drives: the ladies crazy
has anyone successfully disabled rev-matching on a manual car? vendors say they can, but i don't want to be a guinea pig. has it been done before?
      09-30-2014, 11:01 AM   #16
RingMeister01
Croatian
RingMeister01's Avatar
Drives: PORSCHE
I recently read a post how the speed governor can be coded out but within 10 hours of DME operation. Can anyone confirm if this is correct and if so how to? It sounds a little ridiculous to me.
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only)
Husqvarna FS450 (track only)
Looking for an SUV
      09-30-2014, 12:14 PM   #17
Sivart321
Sivart321's Avatar
32
Drives: 2015 F80 M3
Thanks.
I was playing with this last night while on a phone call. I suspected that the ASD would turn off when on a phone call so I put it in sport plus and romped on it and noticed much less cabin noise than normal. I cannot definitively say that it turns off, but the caller on the other end did say it sounded quiet and they had no complaints.
      09-30-2014, 12:35 PM   #18
MWcoupe
24k GOLD
MWcoupe's Avatar
Drives: Mineral White M4
can someone crack the code for the yellow corner light already!
      09-30-2014, 12:49 PM   #19
RickMonet
RickMonet's Avatar
175
Drives: 2015 M3 6MT
Interesting. I would have thought BMW would use noise cancellation for the far end with ASD since it would be pretty straight forward knowing exactly what sound is being added through the speakers.
I will be testing this out as well.....once my car arrives...
      09-30-2014, 12:51 PM   #20
JMN
Drives: 2019 BMW X4 m40d
How much was the cable and where from?
      10-01-2014, 01:42 PM   #21
Boostin FD
Bored all the time
Boostin FD's Avatar
Drives: Batmobile
Is there a code setting to control the brightness of the M logo on the seat... Or when to come on etc?
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3...
It all started with an RX-7 (FD).
      10-01-2014, 02:00 PM   #22
Keto
Keto's Avatar
Drives: F80 M3
2015 BMW M3  [10.00]
I'm not sure of that fine level of control, but it comes on whenever the door handle lights come on. I have the door handle lights come on when I go in reverse (illuminates curbs for the top view camera) and the M lights come on then.
f80post
