How loud is your intake ?
09-24-2014, 09:23 PM | #1 |
Rep 2,016
I just installed VRSF DCI and I can only hear it when I have the music off and windows down, anyone else?
Instagram~~"alexverdii"~~~
09-24-2014, 09:35 PM | #2 |
Rep 823
Drives: 2008 335i Coupe TIAG
09-24-2014, 09:39 PM | #3 |
N54 to N55
66
Rep 308
09-24-2014, 09:40 PM | #4 |
Rep 2,016
How do I do that??
09-24-2014, 09:48 PM | #5 |
N54 to N55
66
Rep 308
09-24-2014, 09:49 PM | #6 | |
I <3 Boost
9
Rep 131
2011 Alpine White BMW 335is 6MT Coupe | M-Sport | 18" Gloss Black 313M | CF Spoiler | BMS Cowl Filters | ER CP with HKS SSQ BOV | Gloss Black Vinyl Roof | BMS DCI | RPI Air Scoops
09-24-2014, 09:51 PM | #7 | |
Rep 2,016
09-24-2014, 09:53 PM | #8 |
N54 to N55
66
Rep 308
I thinks its quite a big difference. The turbo spool sound awesome I could never hear it before. Search the forum for threads about it. I bought mine used off someone here for $45 so that's another option.
09-24-2014, 09:55 PM | #9 |
Rep 2,016
gotcha i might have to get this. will it sound the same if i try removing my cowl to see if theres a difference you think?
09-24-2014, 09:58 PM | #10 |
N54 to N55
66
Rep 308
Yea you can remove it and see how it sounds just put it back after you test it since you don't have the filters which covers the holes left by removing the cowl. Test it when it's not raining.
09-24-2014, 09:59 PM | #11 | |
I <3 Boost
9
Rep 131
09-24-2014, 10:03 PM | #12 | ||
Rep 2,016
Costs of removing engine cowl: Possible engine smells in the cabin, Possible failure of AC Possible damage to engine components in rain, ice, etc Possible engine fire (dry leaves getting near turbos) Possible deleterious aerodynamics at speed Windows fog up almost instantly if you turn the fan on, but not the A/C Benefits of removing engine cowl: Hear the engine. Easier to do work under the hood. Cooler under-hood temps
09-24-2014, 10:11 PM | #13 | |
N54 to N55
66
Rep 308
09-24-2014, 10:12 PM | #14 | |
Rep 2,016
09-24-2014, 10:48 PM | #15 |
I <3 Boost
9
Rep 131
Looks like you did your research. I don't drive my car in the rain or snow anyway so it was a no brainer for me. I have a beater for that.
09-24-2014, 11:24 PM | #16 |
Rep 777
I have the BMS dci and the sound is pretty noticeable. I did realize that it was a lot quieter when my JB4 was in map 0 (stock boost).
09-24-2014, 11:26 PM | #17 | |
Rep 998
09-25-2014, 03:15 AM | #18 |
Rep 193
I ran without a cowl and no filters for a long time as well, with 0 issues. Maybe a bit of smell every once in a while but i had an exhaust leak at the time so idk if it really counts. Only real thing that made sense to me is your a/c has to work harder cause it uses the hot air leaving your engine but I had 0 problems.
09-25-2014, 08:44 AM | #19 | |||
Rep 2,016
09-25-2014, 09:10 AM | #21 |
Rep 777
Keep your cowl on lol. You'll notice a sound difference when you run higher boost. I might be selling my JB4 in the Spring.
09-25-2014, 09:28 AM | #22 |
2095
Rep 43,350
I've seen too many problems related to those cowl filters to go with anything else. One of our local test cars had a never ending fogging issue due to moisture getting into the ventilation system which will eventually lead to mold and other things nobody should be inhaling.
