09-25-2014, 02:15 AM | #2 |
Rep 143
Interesting. I still feel that the swaybars on this car is the last thing I would worry about. Maybe it's different when running slicks...
7:51,4 BTG BMW M4, 8:35 BTG Mini Clubman S, 8:56,6 BTG Swift Stage 2
208 laps on the Nordschleife |
09-25-2014, 03:43 AM | #3 |
Croatian
884
Rep 3,613
Drives: PORSCHE
Is installing the rear sway bar as PITA as the E92 was ???
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only) Husqvarna FS450 (track only) Looking for an SUV |
10-06-2014, 06:44 PM | #4 |
Supreme Allied Commander
3810
Rep 54,295
Drives: F80 M3
01-29-2015, 11:10 AM | #5 |
Rep 1,183
Has anyone confirmed the OEM front sway bar specs? 30mm seems to a be large bar but the car is bigger. I took my M4 to thunder hill and notice a bit of body roll on front. I'm interested in the front bar for sure if its bigger and will help reduce that.. I have EDC and H&Rs.
02-04-2015, 03:52 PM | #6 |
Rep 886
HP Autosport, do you know the stock sway bar (F & R) sizing in MM?
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
02-04-2015, 06:18 PM | #7 |
3810
Rep 54,295
Drives: F80 M3
02-12-2015, 11:47 AM | #8 |
3810
Rep 54,295
Drives: F80 M3
Just to add to this thread.
Springs, struts and shocks should be upgraded before sway bars. That said, sway bar does cost less and is much easier to install(with the exception of the rear bar). |
02-12-2015, 12:40 PM | #9 | |
Rep 1,183
02-12-2015, 02:20 PM | #10 |
Rep 1,338
veblen goods, priced for fools. the better part of a thousand dollars for two bendy bars of spring steel and four urethane bushings.
if you owned a vw golf, h&r would be selling you bars of similar size with lots of extra required pieces for about half the price. Last edited by fourtailpipes; 02-12-2015 at 02:31 PM.. |
02-21-2015, 04:58 PM | #11 |
Rep 1,183
26mm front
23mm rear |
NightAngel0.00 |
07-16-2017, 11:20 AM | #12 |
Curve trader
Rep 4
Thanks ! These values are those of the "standard" BMW M4 or the one equipped with the competition package ?
The ETK references of the stabilizer bars are different with the competition pack... I suppose, therefore, that their diameter is increased. |
07-16-2017, 11:39 AM | #13 | |
Rep 1,183
07-16-2017, 11:58 AM | #14 |
Curve trader
Rep 4
07-16-2017, 04:08 PM | #15 |
Rep 1,183
i would do both with dampers and aero the car stays super flat
07-17-2017, 10:02 PM | #16 |
Rep 188
I have only front with H&R swaybar, the rear is stock bar, worked great so far.
"Learn the rules like a pro, so you can break them like an artist."
