Pre-lci hood fit lci?
09-23-2014, 10:12 PM | #1 |
Rep 193
I have an 07 335 and wanted to fast forward a few years to a 10 or 11 335 but i really dont like the unsightly lines running down the hood. Will a pre lci hood fit a lci? Or are there any other replacements that arent crazy expensive?
09-24-2014, 01:02 PM | #3 |
Rep 2,015
You will need to replace the hood, bumper, grilles, and fog lights.
If you don't want the lines of the LCI hood, consider a aftermarket hood like an m3 rep. DN |
09-24-2014, 01:41 PM | #4 |
Rep 1,040
I think the LCI hoods looks far better than pre lci on the sedans. The lines make it much more aggressive looking to me. Though, as stated above, you would need to essentially convert the entire front end to a pre-lci to make it fit. Headlights and kidney grilles are different which means you would need buy very expensive bi-xenon lights and a bumper with fogs... unless of course you bought aftermarket, but I don't know where you will find a pre-lci look a like lci hood... Those "unsightly lines" will turn into "unsightly" bulges and vents.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
09-24-2014, 02:41 PM | #5 | |
Rep 88
09-24-2014, 03:02 PM | #6 |
Rep 2,554
It would require an entire front end replacement unfortunately. I also prefer the pre-lci hood to the lci. I do like the LCI headlights though, they are interchangeable I believe.
09-24-2014, 03:08 PM | #7 |
19
Rep 298
As stated above the headlights are interchangable between pre and lci other than that in order to fit a pre hood to your lci you need hood, fenders and bumper which can also get expensive especially if you go oem. If you go aftermarket, I have not seeing pre lci style for lci fitment but then again I haven't searched for one but shoot me a pm I'll try my best to help.
09-24-2014, 03:14 PM | #8 |
Rep 193
Thanks for the replies guy, good information to know. Sad to hear it isnt just a grab and swap tho.
09-24-2014, 03:23 PM | #9 | |
General Nuisance in a Private Conveyance
77
Rep 1,907
Drives: like it's rented
BMWCCA Member # 414198 |E90|SGM|6MT|Premium|Cold|Sport|Tint|LCI MSport Conversion|MTech|Blacklines|219M|PSS|Quaife|Helix FMIC|M3 Suspension|Megan Racing|GC Camber Plates/Coilovers|Eibach 440/800#|AR Catted DP|Cobb AP|StopTech Drilled/Slotted|SS Brake Lines|DWS Quaife Review: http://www.e90post.com/forums/showthread.php?t=311570 |
09-25-2014, 03:09 AM | #11 |
Rep 193
09-25-2014, 07:59 AM | #12 |
Rep 622
09-25-2014, 11:44 AM | #13 | |
Rep 193
04-26-2015, 11:27 PM | #15 | |
Rep 1
04-27-2015, 12:29 AM | #16 |
Where'd my VTEC go?
481
Rep 6,067
The fenders are the same
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
