2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) How Protect Underside of Front Spoiler?
      09-18-2014, 03:06 PM   #1
disco4me
Drives: M235i
Any thoughts on how to protect the underside of the front spoiler from being scraped besides not hitting anything? I already christened it coming out of a steep downward driveway onto a street. Nothing noticeable from the front, but scraped underneath. I'm certain to do this again somewhere, sometime. Especially of concern are parking lot stops/bumpers.
      09-18-2014, 03:55 PM   #2
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Get an M Performance front lip.
Then you just trash the lip, not the car itself...
      09-18-2014, 04:33 PM   #3
disco4me
Drives: M235i
I wonder how many of those I'd trash?
      09-18-2014, 04:37 PM   #4
MG 228i
Drives: Z4 m40i, 340i 6MT, i3S
Luckily all the driveways I've gone over have been okay, although the front end barely clears it.
Besides approaching the driveway at an angle, there is not much you can do
      09-18-2014, 04:39 PM   #5
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Bag the car and add a switch to lift the suspension when approaching bumps.
      09-18-2014, 05:24 PM   #6
NYHoustonman
Drives: 2009 135i Dinan S3
Surprised nobody has said this yet: Just be careful. If you scrape occasionally, that's okay. On cars with low(ish) right heights, the underside of the front splitter bumper might as well be categorized as a wear item. I rarely see 1-series (as an example) without at least a scratch or two down there.
      09-19-2014, 12:05 PM   #7
rickinaz
Drives: BMW 435i
My weekend car is a Porsche 997S with the factory aerokit. That car is REALLY susceptible to scraping. A trick that I've learned is to switch on the sport suspension, just before the obstacle, so that it not as compliant as it inches over the curb.
      09-19-2014, 12:17 PM   #8
1stm235i
1stm235i's Avatar
25
Drives: Estoril blue m235i
+1
      09-19-2014, 12:33 PM   #9
tccox
tccox's Avatar
Drives: 2014 228i Msport
What a coincidence , just scraped mine for first time about a hour ago. Oh well, at least it's not visible
A peasant and proud of it
Save The Manuals!!!
      09-20-2014, 09:11 PM   #10
krhodes1
Drives: 2011 328i Wagon
2011 128i  [10.00]
2011 BMW 328i Touring  [10.00]
Get a strip of the thick clear 3M film sold to protect headlights and stick it on under there. That stuff is TOUGH. No idea where you would get a piece that long, but where there is a will there is a way.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option
'11 128i Convertible - Space Gray on Savannah Beige, 6spd manual,
also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire
      10-01-2014, 07:57 PM   #11
disco4me
Drives: M235i
I've been experimenting with the Park Distance Control as a means of protecting the front spoiler. If I turn it on just as I am entering a parking space with a curb/cement bumper ahead, the sensor will start beeping well in advance. If I turn on the Park Distance Control while I am very close to the curb/cement bumper, it will not start beeping. So if you turn it on well in advance, it helps by telling you the curb/cement bumper is ahead.
Try it and let me know what you think.
      10-01-2014, 08:17 PM   #12
overcoil
Drives: M235i 6spd
I use the Park Distance control with perfect results. But if I didn't have that feature I would layer on 3M or X-Pel thick and on the underside and exposed lower front.
      10-01-2014, 09:53 PM   #13
haloeight
Drives: m235i xd perf. ed'n
That is effin brilliant. Thanks, will try this.
      10-02-2014, 10:56 PM   #14
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
Would have suggested this. After 5 years lowered on my A4, my front lip has plenty of scratches. It just takes time to get used to how to maneuver the car and how far to park away.
Of course, when parking, could just get in the habit of backing into spots :P
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
      10-03-2014, 08:49 AM   #15
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
You think that's low? My Corvette had 1.5" of ground clearance between the air dam and the floor.
A lot of scraping can be avoided by driving habits. It will happen on occasion, not much you can do. Most of them won't be visible to anyone looking at the car unless they get underneath or it's extremely bad.
-When you see a driveway that is steep, pull in at a very shallow angle and as slow as possible. This way the suspension doesn't load up and push the front end down further. Hard braking coming into a steep driveway will push the nose down and then with a sharp turn you aren't giving the suspension any angle to take the turn. Shallower the angle of entry, the less steep and less chances of scraping.
-When pulling into spots you can use the PDC, but your better habit to form is remembering the front end of your car is fairly long in comparison to others. Don't feel like you need to pull up so far. The 2 series is a small car, chances are higher you'll hit the curb pulling way in than giving yourself an extra foot. Your car is still shorter than the lady next to you in the Expedition. Also just use other cars for reference. Remember FWD cars have shorter front ends so don't try pulling up to their mirrors, leave yourself a foot or so.
-When exiting steep driveways same rules - pull out at a shallow angle. Sometimes this isn't possible (you'll block all the traffic) so in that case just go as slow as you can when pulling out.
My 3 Msport bumper is fairly low and it's stayed in pretty good shape by following the above rules. Sometimes you can't get around it though and you'll scrape. I had a driveway in Miami that was so narrow you couldn't take it at an angle (otherwise you'd drop it off the curb) so the only option was to go super slow. It was so angled that even my exhaust would have hit if it weren't for the hitch installed.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      10-03-2014, 03:01 PM   #16
tccox
tccox's Avatar
Darn, scraped again today. I never had this issue with my 128 sport. Maybe I should have gotten sportline instead of MSport. Guess I should just consider it a sacrificial part.
Save The Manuals!!!
2addicts
