H&R Sports Springs on e92
09-14-2014, 06:40 PM | #1 |
Rep 64
I know I'll probably get yelled at but I literally could not search for the answer.. At least not straightforward.
I am looking to lower my car just for looks and I live in a city where pot holes are not common. Would you guys recommend for me to install H&R springs to get a better stance? Are there better springs out there? I also need to install M3 fronts and Z3 rear bump stops correct? Where could I buy those bump stops? Has anyone done just this and ran into any problem? Thanks in advance |
09-16-2014, 06:04 PM | #3 | |
I Can't Drive 55
129
Rep 883
Drives: 2008 BMW 335i (E90)
Garage List 2023 VW ID4 Pro [0.00]
2002 Ford F250 7.3L ... [9.50] 2008 BMW 335i [0.00] 2012 Mercedes ML350 [0.00] 2002 Toyota MR2 Spyder [0.00] |
Eibach Pro-Kit springs are closest to the sport springs but still lower the car a bit more and provide the closest to OEM ride. Should be no rubbing issues w/conventional tire/wheel sizes. Eibach Sportline springs are in between the H&R and Pro-kit springs in terms of height and ride. Word is that the Sportlines "settle in" over time increasing the harshness of the rides and also raising possible rubbing issues. You can make all of the springs go even lower in the front using Supreme Power lowering perches BUT you'll be even more likely to face rubbing issues if you do. Eibach Pro-Kit springs can be used w/sport OEM or Koni FSD shocks. The Pro-Kit springs and FSD shocks are often marketed as a combo kit. However, if you go lower w/the H&R, Sportline and/or SP lowering perches you'll probably have to use adjustable Yellow Konis or comparable shocks instead. You should install the E36 M3/Z4 bumpstops for anything lower than the Pro-Kit springs to avoid the possibility of bottoming out w/the OEM bumpstops. I installed the E36 M3 and Z4 bump stops when I installed my FSDs for Phase 1 of my suspension mods. Didn't really need to do it because I didn't install lower springs but they were cheap and did it just in case I went w/lower springs later, which I am currently planning on doing. I've got the E90 OEM sport suspension using 12 & 15mm spacers (front & back) with OEM sized tires/wheels with no rubbing issues. Only got rubbing when I tried 18mm spacers in back. For Phase 2, I'm planning on adding M3 sway bar & control/tension arms in front w/Koni Pro-kit springs all around as the next stage in the suspension mod. The Pro-kit springs are only a few mm shorter (but are noticeably firmer) than the OEM sport springs, which I expect will provide a firmer/more stable front end with a bit more understeer but w/o any rubbing issues. Phase 3 and would include a change of the rear suspension/diff bushings, the addition of the rear sway bar and maybe a LSD which will balance out the suspension and provide more control in the rear. However, I'm not sure if I'll ever do Phase 3; all depends on how the car performs after Phase 2. Troll the threads for further details on the possibilities.
2008 Black Sapphire 335i E90 Sport & Premium Pkgs - Cobb Stage 1+FMIC Sport map, Mishimoto FMIC & Alpina B3 AT Flash. See: My Build Thread.
