2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Active Sound
      09-14-2014, 06:32 PM   #1
nzw212
Drives: M235XI, Maserati, Ducati
Active Sound
Is there a way to adjust the volume of the active sound? So much has been made of the artificial sound inside the car. Honestly, I can't really tell it's there, which means wow the stock exhaust is quiet. I'm on the verge of getting the M PE but I am worried I'll be disappointed with it as most of the reviews say it sounds great on start up and light rev'ing but not so great when the revs increase. I know this topic has been discussed too much already...
      09-14-2014, 07:58 PM   #2
Spieltag
Drives: 2015 BMW m235 AW/KR-B
2015 BMW m235  [0.00]
Sorry, not to thread jack but in that same vein, How does active sound adapt to different exhaust? Does it simply amplify sound or is it engineered sound? Ie will it mix tunes if you put different exhaust in?
      09-14-2014, 08:24 PM   #3
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
Not quite sure but maybe it just pipes the exhaust sound so it will sound exactly as whatever the exhaust sounds like
It is said that asd only accounts for 10% of the sound anyway
You can disable ads through coding but don't think you can change volume
      09-14-2014, 08:54 PM   #4
Spieltag
My understanding was that it just amplifies sound near the resonators in the stock exhaust and pipes it in through the speakers based on air flow sensors. Hence when you go to sport and it increases you get the louder noise. Along with a little boost to sound levels. That being said I didn't know if they engineered the actual notes for the exhaust. If so then I think I will have to disable ads when my new exhaust gets here.
      09-14-2014, 09:55 PM   #5
pikcachu
pikcachu's Avatar
1399
mmm.... but if you do DSC off (hold 5 secs)... you also get ASD but you don't get sport throttle mapping or shift.... so don't think sport is related with louder exhaust
      09-14-2014, 10:13 PM   #6
nzw212
Can you explain this further?
Thanks
      09-14-2014, 10:19 PM   #7
pikcachu
pikcachu's Avatar
1399
if you hold the DSC button for 5 seconds deactivating all the stability controls, you get the louder exhaust even though you are not in "sport" mode (so comfort throttle mapping and comfort shift points if you have an automatic)
you can easily test this..... with the car parked, rev up to 1800-2000 rpm.... hold the DSC button for 5 secs and when DSC gets deactivated you will hear louder exhaust....no keep the revs at 2000rpm and hit DSC again to turn it on and you will see the exhaust goes quiet again
      09-14-2014, 10:24 PM   #8
nzw212
Wow, interesting. This functions is only to have a louder exhaust sound while in Comfort?
      09-14-2014, 10:32 PM   #9
pikcachu
pikcachu's Avatar
1399
apparently yes... but be careful cause you have no stability control...
also DSC off puts the chassis in sport meaning heavier steering and harder suspension...
      09-15-2014, 05:37 AM   #10
ah bui
Drives: M235
My recent experience after I add a amp to the sound system, active sound become louder and caused a nimble vibration at 2k rpm.
      09-15-2014, 08:23 AM   #11
xxxHolic
xxxHolic's Avatar
Drives: 2015 M235i Xdrive
Does no stability control have the same impact on xDrive cars?
That's interesting. Did you have the car in Sports mode?
      09-15-2014, 08:35 AM   #12
ah bui
Drives: M235
exist in both comfort and sports mode, in sport mode more worse no choice so ended up in coding off the active sound.
      09-15-2014, 08:45 AM   #13
xxxHolic
xxxHolic's Avatar
Thanks for this info! I always thought it was just based on pre-computerized sounds. Are you sure its not just your exhaust is louder lol?? It's great that we have the option to to turn it off.
      09-21-2014, 03:37 PM   #14
mmmmm235i
mmmmm235i's Avatar
104
Drives: 440xi GC
I had my active sound coded off, I just prefer to hear the actual sound of the car and it bugged me not knowing what was the car and what was coming out of the speakers. You can definitely notice a difference, but when you get on it, the car doesn't need any added sound effects.The exhaust note is real.
Thanks for this info, I like the increased exhaust sound in sport + mode, but don't need to be revving like that during normal driving. Looking forward to trying this.
2020 X3M Comp., Alpine White on Black/Beige
RETIRED:
2018 440xi GC, Carbon Black on Black/Blue
2014 M235i Black on Black, DINAN Stage 2
      09-21-2014, 05:14 PM   #15
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
I did too coded out at the dealer !! Car sounds real now !!
      09-22-2014, 11:32 PM   #16
BRM6
BRM6's Avatar
Brazil
11
Drives: 328/335/M235i/M4 - Current M6
Do all M235i have active sound from the factory? How can we tell?
      09-22-2014, 11:37 PM   #17
pikcachu
pikcachu's Avatar
1399
you can probably unplug the speakers fuse and you will notice the difference...
      09-23-2014, 04:38 AM   #18
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
Thats a poor recommendation as the stereo wont work ! Every m135i and 235i is fitted with this so have your dealer code it out on your next software update !! cost me $100 and its well worth it , I had the auto start stop coded out at the same time as that pissed me off also.
      09-23-2014, 08:24 AM   #19
david.orr
Australia
123
Drives: Cars
Originally Posted by chaddy74 View Post
........Every m135i and 235i is fitted with this so have your dealer code it out on your next software update !! cost me $100 and its well worth it , I had the auto start stop coded out at the same time as that pissed me off also.
nice, will def follow up. where did you get it done? thanks
      09-23-2014, 11:22 AM   #20
pikcachu
pikcachu's Avatar
1399
well he asked "how can we tell"? I gave him an easy way to tell without having to go anywhere or buy anything...
It's not meant to be a permanent solution..
You can buy the cable and code it yourself too
      09-23-2014, 09:23 PM   #21
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
My auto/stop doesnt need any coding
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      09-23-2014, 11:23 PM   #22
pikcachu
pikcachu's Avatar
1399
auto/stop comes coded to "last setting" here in the US by default.. so it stays in whatever you left it
2addicts
