09-10-2014, 10:42 PM | #1 |
Rep 15
Daytime running lights location
On the M235i, has anyone looked into replacement of the daytime running light LED's? I was looking into the manual as to where these are located, but the manual doesn't match the vehicle. In the manual is says the DRL and high beams are in the same place, but that doesn't make sense (since the high beams are on the same side as the low beam).
I guess the question is, where are the DRL's LED's located (how do you access them?). Thanks |
09-10-2014, 10:47 PM | #2 |
Rep 6,925
Drives: 2018 M2 AW DCT
They are the LEDs around both lights.
You turn them on using the menus in idrive. |
09-11-2014, 01:58 PM | #3 |
Rep 15
Thanks for the info.
What I was actually wondering was where they are physically accessed from, in case you need to replace the LED. Is it underneath one of the heat sinks inside the hood? If so, which heat sink? There are two on each side... Thanks |
