what's my 1st step? cc-id-370 DXC 370 4X4, DSC, ABS and EBV Failure
09-08-2014, 05:41 PM | #1 |
Rep 203
I've been getting a vibration out of the front end. I wasn't sure if it was a wheel bearing or a tire with a broken belt. When I've had bad wheel bearings before, they stopped making noise when turning one way and continued to make noise when turning the opposite direction.....so I assumed it was a tire.
This morning, I got a cc-id-370 code and the AWD and ABS turned off. I did a little reading and there are 3 common issues that cause this. 1) Wheel Bearing/ABS Sensor issue 2) Transfer Case Actuator/Transfer Case Actuator Gear issue 3) Charging/Battery issue I'm leaning towards a Wheel Bearing/ABS Sensor issue except the front wheels don't seem to have any play at all. ( wheel bearing part number: 31226783913; lock ring 07119934760 & nut 33411133785 ) DIY: http://www.e90post.com/forums/showthread.php?t=870124 I doubt it's a Charging/Battery issue because I tested the battery and its at 12.4 volts with the car off. I have no idea what to look for if its a Transfer Case Actuator/Transfer Case Actuator Gear issue. I also don't know what the part number of the gear is. The whole motor assembly is 27107546671 . What do you suggest I do first? Sources------------------------- Wheel Bearing/ABS Sensor issue: http://forum.roadfly.com/threads/126...-lights-all-on... http://www.e90post.com/forums/showthread.php?t=290544 Transfer Case Actuator/Transfer Case Actuator Gear issue http://www.xoutpost.com/bmw-sav-foru...r-motor-3.html http://www.xoutpost.com/bmw-sav-foru...al-solved.html Charging/Battery issue http://www.bimmerfest.com/forums/sho....php?p=4208966 http://5series.net/forums/e60-discus...ion-quo-79434/
2008 BMW 335xi Coupe 6-speed, 12.8 @ 107
2000 Chevrolet Corvette Z51, 11.4 @ 123 2005 Saturn Ion Redline, 14.1 @ 100 (sold Jun-2013) Last edited by tb30570; 09-09-2014 at 07:12 PM.. |
09-25-2014, 06:02 PM | #2 |
Rep 203
I thought it was a wheel bearing / speed sensor issue because I was getting a vibration from the front. Turns out, my tires are just noisy. I rotated them to the back and it was a lot quieter.
I was getting a clicking or grinding sound when the car shut off and I found a couple posts stating that is usually a transfer case issue. I just purchased the actuator motor for $413.48 after shipping. I'll get that installed and go from there. http://www.e90post.com/forums/showth...0#post16690230
2000 Chevrolet Corvette Z51, 11.4 @ 123 2005 Saturn Ion Redline, 14.1 @ 100 (sold Jun-2013) |
09-25-2014, 07:22 PM | #3 |
Rep 203
I'm ordering some transfer case fluid too. Can I fill the fluid through the actuator motor hole or do I need to top it off using the fill hole? It sounds like access to the fill hole stinks.
http://www.thebmwpartstore.com 83220397244 - $38.76 Here is a DIY for TC fluid change: http://www.pelicanparts.com/BMW/tech...Replacing.htm#
10-24-2014, 06:31 PM | #4 |
Rep 203
I replaced the motor a couple of weeks ago. It was pretty easy. Topping off the fluid was no big deal either. I got a 14mm hex off ebay when I ordered the motor and fluid. No problems since!
10-27-2014, 09:19 PM | #5 |
Rep 203
I put the wheel bearing, axle nut and snap ring on ebay if anybody is in the market for those parts
