E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > KW V1 Problem clunk thump
      09-05-2014, 07:24 AM   #1
Rob13567
Rob13567's Avatar
40
Drives: 2016 Camaro 2SS NGM
Unhappy KW V1 Problem clunk thump
Just had KW V1 coilovers installed handling is great! but ride is a little stiffer than I thought it would be, but I am okay with that. the problem is I hear a clunk/thump when I go over bumps on the road or up my driveway. I use to hear from both passenger and drivers side, but when I removed the wheels to check endlinks(what I read is common problem) I stopped hearing the drivers side clunk. I still hear the passenger side though and I noticed a mark on the passenger side bottom of the endlink, am I too low?. Pic Below
      11-12-2014, 01:15 AM   #2
Karman
Drives: 335i e92 07 space gray
Bumppppp!!!! I have the same issue
      11-15-2014, 10:39 AM   #3
ZhengHai
ZhengHai's Avatar
240
Drives: E90
Try tightening the top hat from the engine. How many threads are showing above the nut?
      11-15-2014, 05:27 PM   #4
Bladerunner
Bladerunner's Avatar
Drives: 2011 e92 335xi
I was reading that we need to change to the extended endlinks on the xi when lowering, I just ordered a set from HPAuto on here.
      11-18-2014, 04:09 PM   #5
Mtriple
Drives: 2011 335i x-drive
Could you post a link?
      11-19-2014, 11:30 AM   #6
fastcarz4life
Drives: 2011 335i xDrive Mtech 6 speed
Op did you resolve this problem yet?
      11-19-2014, 04:24 PM   #7
Rob13567
Rob13567's Avatar
40
Nope, going to put stock suspension back on in a couple of weeks
      12-10-2014, 10:52 AM   #8
Karman
I suspect I have a failed strut same issue
      12-14-2014, 12:10 AM   #9
Rob13567
Rob13567's Avatar
40
how does it feel like when the car is moving on the road? just wondering I hope not.
      12-18-2014, 02:26 PM   #10
eastcoast335xi
Drives: 2008 e90 335XI
I got no issues with mine. I have them set to the KW specs at the moment.... Maybe try that? The back is snug, front slight wheel gap. Going lower next summer and hopefully not having this happen
      12-20-2014, 11:56 AM   #11
Cali 335
Drives: M/T 08' e92 335xi
i'm running the kw v1 on my 08 335 xi coupe also and i'm running 19 inch wheels 235/35/19 et 37 front + 265/30/19 et 33 rear and do not have or hear any thumps on my from the suspension.
Is that your front strut bar knocking on a control rod? Maybe your front strut bar need to be look at and its not the KW's
It doesn't look like there is much travel room between the 2. ill take a pic of how mine's look in a bit so we can compare.
      12-28-2014, 11:17 PM   #12
Rob13567
Rob13567's Avatar
40
An update I have not heard the clunk in a while, and have decided not to get rid of the kw coilovers.
      01-03-2015, 03:39 PM   #13
dsjr2006
Drives: '01 E39 540iA, '09 E90 M3
2010 BMW 335i  [0.00]
2001 BMW 540i  [0.00]
If you're having a similar issue to me, seems like you are, and the reason the sound went away was because the end-link broke.
E90 M3 DCT LCI | E90 LCI N54 M-Sport(retired) | E90 Technical Docs download: http://j.mp/bmwe90docs *good read, very detailed.
      01-03-2015, 04:18 PM   #14
Nismo G
Nismo G's Avatar
Drives: 2008 335xi Sedan
Not sure if this is the same issue, but there is a video of the noise and also the correction 3/4 down on the page.
http://www.e90post.com/forums/showthread.php?t=771538
Current: 08 335xi Sedan - ST Suspension Coilovers - M3 Front Strut Brace - COBB Stage 1 - ECS Tuning Chargepipe + BOV - aFe Stage 2 Intake - Precision Raceworks Ignition Coils
      01-03-2015, 08:28 PM   #15
Rob13567
Rob13567's Avatar
40
Oh no I have to check later, I did take it in to get brakes check because I have been hearing some groaning. at the dealership they said it was because I was using non-runflat tires
what did you do, order new endlinks?
      01-03-2015, 09:07 PM   #16
gtaccord
Drives: 2009 BMW 335xi
I also have kw v1s on an xi with stock end links. No chunks or odd noises. I am in the bottom 25% of the front adjustment range.
Tags
kw v1 clunk endlink
e90post
