Washer Bottle Blocked
12-22-2007, 01:21 PM | #1 |
Rep 2
Hi
335i E92 purchsed from main dealer Dec 2006. 11k miles. Recently screen wash wipe failed i.e. no water getting to screen though I could hear the little motor whirring. Main dealer advised some "crystallisation" was evident in the pick up/filter area in the washer bottle and advised not a warranty item. Cost me £100. I have only filled the bottle twice maybe three times since new. BMW UK wont pay under warranty and are refusing to budge. their position is that its not a manufacture issue. Car is garaged every night. The wash/wipe is now stronger than ever, though previously I had no reason to believe there was any problem. They have failed to reply to this point and dont want to enter into further dialogue. Anyone had similar experiences and do I have a point? Thanks. |
12-22-2007, 01:53 PM | #2 |
Rep 1,134
Drives: BMW G20 330e M Sport MY20
Some cheapo screenwash additives can clog the washers - or even no screenwash can clog. I've had it on other cars i've owned. Bit steep to charge you £100 to clean though.
Were they pouring single malt through it to clean it?
20 BMW G20 330e M Sport Portimão Blue/Cognac, Driver Pro, Tech,M+ lumbar, storage packs
Long gone -15 Peugeot 308 2.0HDi GT AUTO Magnetic Blue, 10 BMW F10 520D SE Xirallic Imperial blue/Cinnamon Brown, 06 E90 320si - Le Mans Blue - Totally standard specification (Scrapped RIP 12/08/2010), 00 Peugeot 306 2.0 SE Cabriolet, 94 Rover 214 SEi, 91 Fiat Uno 60S Mk2 |
12-22-2007, 02:02 PM | #3 |
Rep 2,927
Drives: E60 530D M SPORT
i think bmw labour is about £90ish a hour
12-22-2007, 03:09 PM | #4 |
Rep 2,353
Drives: 2009 Z4 sDrive 23i
uham, what did you fill the washer bottle with - water or screen wash of some kind?
I think you might find it difficult to prove it is indeed a warranty item. I think NathanJT had a problem with his windscreen washer... try a search on the UK forum.
E89 Z4 sDrive 23i... for the more discerning driver
12-22-2007, 04:10 PM | #5 | |
Rep 9,218
12-22-2007, 04:21 PM | #6 | |
Rep 2,353
Merry Christmas NFS.
08-16-2009, 11:17 AM | #7 |
Rep 1,130
anyone know how to remove the bottle? I have tried and failed to remove the wheel arch liner.. what am i doing wrong?
I have taken the bolts out of the liner towards to the back of the wheel arch, but I cannot see how to remove the liner without being brutal! likely I won't be able to replace it. Any help please? |
08-17-2009, 03:19 AM | #8 |
Rep 564
Drives: e90 320D ED
has anyone tried using a calgon tablet in their washer bottle to remove the build up of crap in the filter? i was going to try it on mine, but it actually just started working one day!!
Its all about the mpg!
09-26-2009, 07:37 AM | #9 |
Rep 393
Same thing happened to me a few days ago and tried a Calgon tablet...it worked
That's saved me 100 quid!
Current: AW F20 M135i :-)
Past Masters: E90 335i with Evolve / Honda Accord Type R / Prelude VTI / Prelude 2.2 Vtec |
09-26-2009, 09:43 AM | #10 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
Seriously?? Calgon fixed it? Good stuff.
09-26-2009, 10:06 AM | #11 |
Black .... all the way !!
56
Rep 601
Drives: [Previous]2006 330d M-Sport
Top tip of the day there then ?
Did you just drop the tablet in, or dissolve it first? . |
09-26-2009, 10:13 AM | #12 |
GTR'in it
169
Rep 4,434
09-26-2009, 10:45 AM | #13 |
56
Rep 601
haha
09-26-2009, 10:45 AM | #14 |
Rep 393
Crumble it up a bit first....it's too big otherwise. Left it about 2 hours then bingo
09-26-2009, 10:46 AM | #15 |
56
Rep 601
Excellent tip
03-06-2010, 05:54 AM | #18 |
Rep 1
Had same symptoms after using non BMW windscreen fluid, the pump was turning with little water on the windscreen. The headlight jets were working well. Tried Calgon overnight and still blocked. Unplugged the pipe going into the jets and tried blowing into it. The water in the tank bubbled for a second then was blocked, so used a cheap Halfords tyre compressor and it cleared the blockage. Filled with some hot water from tap to dissolve any extra gunge and the windscreen washers now work great.
03-06-2010, 02:24 PM | #20 | |
Rep 274
ps i tried the calgon tablet b4 i went to bmw and it did'nt work. |
03-06-2010, 06:07 PM | #21 |
Rep 7,690
Drives: 335i SE Coupe Space Grey
Hi I got the same problem....which dealership did u use?
03-09-2010, 05:41 PM | #22 |
Rep 2,472
I had this problem and decided to fix it myself. I searched for a DIY for cleaning the filter. I mean it's only a water bottle how hard can it be? 3 hours later, hands cut to ribbons and the whole of the drivers side wheel arch removed I finally managed to get the bottle out, removed the pump and gave it a good clean. It was all blocked up with black slime. 1 hour later everything was back together (no bits left over). Jumped in the car and tried the washers but still no water. I could hear the pump and smell the fluid but no sign of water. Jumped back out the car and looked under the bonnet only to see water collecting around the cover at the scuttle panel. I decided to whip this off and try disconnecting the hose from the jet to blow through the hose which is supposedly a quick fix for the blockage problem. When I removed the panel I discovered the hose wasn't even connected to the washer jet . I didn't know whether to laugh or cry.
