08-28-2014, 01:17 AM | #1 |
Rep 79
Does A/C bog down performance?
Random thread, but my throttle response seems to change a lot. Sometimes, my car flies like a dream with just a tap on the gas pedal, while other days, I feel like the car actually slows down when I shift up even though I use the same pedal input as normal. Of course, it's probably a really subtle difference, but driving stick lets you notice these subtle issues.
Someone suspected the A/C for being in charge of it... But I thought A/C bogging a car down was a thing of the past.. I thought only old cars or cars with tiny engines had that issue So is my throttle response just related to my A/C? I usually have it on at all times, but my throttle response changes from fast to sluggish in a matter of minutes |
08-28-2014, 07:32 AM | #2 |
Rep 876
You can definitely feel the A/C compressor cycling. And it definitely puts a parasitic drag on the motor which causes reduced performance. I can feel the strain every time the compressor cycles on. It annoys me so most of the summer I run with all windows down and no A/C on. Only when I have passengers do I roll the windows up and run the A/C.
08-28-2014, 08:42 AM | #3 | |
Curmudgeon and Pedant
690
Rep 3,489
Don't forget that turbo cars are pretty sensitive to heat - that's why we have an intercooler. The knock sensors, in concert with the temperature sensors in the intake tract keep things from knocking, but the result is a loss of power. It's summertime, hot air means more chances of retarded timing. Could be other things, too. |
08-28-2014, 10:22 AM | #5 |
Rep 211
I drive a manual and find that the car is much more moody than my previous e46. I also find that driving the car in sport mode feels more linear and direct than comfort. Try to see if it makes a difference. I don't notice a difference when I run ac but then again I don't drive aggressively.
08-28-2014, 12:41 PM | #7 | |
Rep 79
09-07-2014, 08:23 AM | #8 | |
Rep 209
And, a study was done that showed open windows decrease fuel efficiency vs AC at speeds above 35MPH. Since aerodynamic drag scales with the cubic power of velocity, going twice the speed causes 2*2*2=8 times the drag on your car at 70 MPH than at 35 MPH. With a variable angle swashplate, increasing the engine RPM will reduce the compression stroke distance under constant cooling demand. I never open my windows on the highway. |
