E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > Question about tires re drag strip/autox
      12-20-2007, 01:40 PM   #1
DrewKo
DrewKo's Avatar
44
Drives: 335i Montego Blue Saddle Brown
2007 335i  [0.00]
I am interested in breaking 12.5 at the drag strip. My best so far with stock wheels/tires and Procede 1.47 is 12.889. When the track opens again next year, I'll have a Procede v.2, catted DPs, BMC air filter, and I just received two Kosei's with Nitto 555rs, which are drag radials. They are not totally slick, but have some tread. I still may get two more for the front, but instead of putting on a drag radial, I am considering using an autox type high performance tire, like a Hoosier, because I also plan to run autox events. Anyhow, my question is do you think I can get by using the Nittos on the back and something else on the front for auto x racing, or do you think I need completely different, nondrag radial tires on the rear?
I think I already know the answer, but am just trying to save money rather than having another set of wheels/tires. I believe I could use autox tires up front for the drag racing, and then switch out the back wheels and tires for autox racing. That means 6 wheels and tires, but still better than 8 sitting in my garage.
Tx.
      12-20-2007, 03:02 PM   #2
leftcoastman
Drives: 335i
Drag tires have no lateral stability.
      12-20-2007, 03:07 PM   #3
DrewKo
DrewKo's Avatar
44
2007 335i  [0.00]
Right, I wonder how important that is for the rear tires though, in contrast to the front tires.
      12-20-2007, 07:21 PM   #4
leftcoastman
Drives: 335i
Very important. A squirmy rear end makes for unpredictable handling.
grip.grip.grip.grip...OVERSTEER!
      12-21-2007, 01:41 AM   #5
heavychevy
Drives: 2003 911 Turbo
Nitto NT-01.
AWESOME rear end grip, heat up good for Auto X as well.
      12-21-2007, 01:56 AM   #6
sambonator
Samtaro!
sambonator's Avatar
Drives: 2014 F32 N55 Alpinweiß
I've given up trying to make my tires do double-duty (with Kumho Ecsta V710's)... now just got BFG Drag Radials for drag racing application.
      12-21-2007, 05:28 PM   #7
VMRWheels
BimmerPost Supporting Vendor
VMRWheels's Avatar
2038
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
A good R compound will be acceptable for double duty. You definitely don't want to go the other way, and take the drag radials to the auto-x.
The R comps will provide good grip upon the launch at the strip, much better than street tires. They could be enough for your 12.5.
e90post
