08-19-2014, 01:01 PM | #1 |
Rep 4,515
MPBBK - coding required post DIY install ?
Gents
Can't reconcile cost of MPBBK for f2x series supply and fit by dealers here in the UK. Considering a cheaper DIY alternate as follows:- - use blue msport calipers off an f30 335i and 370mm dia MPE rotors for the front and MPE 345mm rotors on rear so I retain matching blue calipers front and rear. Does the car need coding for MPBBK ie abs re-calibration ? If so can this be coded retrospectively ? Advice welcome, thanks in advance, BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. Last edited by Bee Pee; 02-26-2017 at 03:47 AM.. |
08-19-2014, 01:11 PM | #2 |
Rep 207
Dont know if thers actually anything electronically different, but if it were me, I'd add the "2NH - M Sport Brakes" to the VO/FA just to be sure.
08-19-2014, 01:29 PM | #3 |
Rep 5,262
i think it changes the brake balance between front and rear
you could use the NCD/CAFD tool and the FA-CAFD section and see what changes are made |
08-19-2014, 04:14 PM | #4 |
Rep 5,262
found it this is what changes in the DSC ecu
DSC_CT01 > DSC_CODIERDATEN_LIEFERANT_CONTI 3004 > C_Trockenbremsen_Druckhoehe_C = Reduzierung um 0.2 bar |
08-20-2014, 02:30 AM | #5 |
Rep 4,515
Pikcachu,
Thanks. Did a search for SBPR in F30 forum and came up with these 2 threads http://f30.bimmerpost.com/forums/sho...highlight=SPBR http://f30.bimmerpost.com/forums/sho...highlight=SPBR Unclear whether or not these are relevant/useful for F2x series ?? BP
Current '22 X3M LCI.. Last edited by Bee Pee; 02-26-2017 at 03:48 AM.. |
