E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Launching automatic
      08-16-2014, 10:52 AM   #1
jboyorak
Drives: 2008 335xi
Launching automatic
What technique are people using to launch their auto?
I am having a difficult time finding one that is consistent and aggressive enough.
I brake boost to about 2-2500(whatever it lets me do) and let of on the brake while slowing pushing to full throttle. The launches are slow for the most part. Pulling 1.9 60' usually. With the low end torque these have and awd, I should be be able to pump out 1.7 all day long.
      08-21-2014, 08:13 PM   #2
S-P335xi
Drives: e92 335xi
try lunching at 3000
135i N54 Mpack Jb4 intake DPs
F25 35i - Mpack - Fully loaded
      08-25-2014, 12:58 PM   #3
Andrewe92
enthusiast
Andrewe92's Avatar
Drives: 2011 e92 lci 335xi
im actually curious about this too, with xdrive and auto it's kinda hard to get a good launch... to be honest i cant even brake boost a launch
      08-25-2014, 01:19 PM   #4
deeLow
DOPE
deeLow's Avatar
148
Drives: F80
You're A: not holding the brake hard enough and B: not giving enough gas.
It is tricky, and hard on the car
      08-25-2014, 08:40 PM   #5
jboyorak
Drives: 2008 335xi
Brake boosting the most rpm I get is about 2500. Full throttle/half throttle doesn't seen to matter.
Just tried again this weekend. I see there are people with steptronic pulling some good 60', so I am only to assume there is something wrong with my setup or technique?
      08-25-2014, 10:27 PM   #6
SaviorXi
SaviorXi's Avatar
Drives: 2009 335i xDrive coupe
I run 1.7-1.8 with consistent regularity.
The procedure I use is-
1) Hold DTC button in until DSC and DTC are turned off. (yellow warning symbol on dash)
2) Shift into sport mode and manually shift into 1st gear.
3) Hold in brake all the way.
4) 4 seconds before green light floor the car.
5) When green, keep car floored and let go of brake.
6) let car shift automatically from 1st to 2nd and then manually shift at 6000 RPMs thereafter.
If results are not good you should check-
1) Tire condition/make/tread/pressure
2) Car condition and maintenance
3) Your cars Tune and settings
4) your body weight
5) Track conditions including what equipment track uses, regular maintenance and calibration.
6) Weather, temperature, altitude
Best of luck
Mtech/M3Skirts/335isDiffusor/BBSrgr/PSS/OFT/Alpina/LCItails/LuceAngelEyes/OsramXenarc/ZKWRlenses/
FlowmasterHFC/vibrant/VRSFdp’s/Helix/Mr5CAI/M3rearBushings/M3StrutBrace/RearSway/UUCfrontSway/Meyle/
KoniTCKlineAdjFront&Rear/EibachPro/ECSbrakeLines/ECS2pieceRotors/Akebono
      08-26-2014, 11:18 AM   #7
Nonecure
Nonecure's Avatar
Drives: 2013 M3
4) your body weight
Best of luck
Nice write up!
I have not had my car at the track yet, plan to though. How do you know when you have about 4 seconds? My memory from years ago was the light tree moves really fast.
Do you stay above kick-down? Do you let the auto shift 1-2, but then shift after that at a lower rpm?
      08-26-2014, 11:36 AM   #8
SaviorXi
SaviorXi's Avatar
I try to get to the line and double yellow light before the other car I am racing since I have xdrive and they are usually burning tires it gives me more than enough time. As they are inching up to the line and get single yellow that is when I start brake boost. I let the car shift from 1-2 and the I manually shift after that at 6000 RPMs. Hope that helps.
      08-26-2014, 06:21 PM   #9
M.a.r.k.u.s
M.a.r.k.u.s's Avatar
Drives: 2011 BMW 335i xDrive manual
the longer you hold rpm's the harder it is on your tranny. Track is the only place I brake boost and I usually just floor it about 2 seconds before i let off the brake (about 3000 rpm) and consistently cut 1.7's. I have launched the car at 5000 rpm and broke all four tires loose but it didn't produce a better 60ft time and it is harder on the car.
I have noticed that a downpipe helps quite a bit when launching the car due to the throttle response being much better than with stock dp.
      08-26-2014, 08:28 PM   #10
Southjersey128
Southjersey128's Avatar
Drives: 2008 128i
2008 BMW 128i  [10.00]
4) your body weight
Afe Scoops and CAI, PBX, BMS Paddleshift upgrade, 261M's Powder Coated Gunmetal, 225/255 Michelin PSS, (BMW Performance: BBK, Illuminated Door Sills, Shifter Knob and Boot, E-Brake Handle, Steering Wheel, Front Strut Bar), E93 FSB, E92 RSB, M3 Rear Subframe Bushings, M3 Front Control Arms, HPA coilover kit (Koni Adjustables and Swift Springs), Steel Brake Hoses, Black Kidneys, Smoked LED side markers, Blacklines, Msport lip spoiler...
      08-27-2014, 01:46 PM   #11
v1nc86
Drives: 335xi
I brake boost at 2500-2750 RPM and cut a 1.7x 60 foot every time.
YouTube | 335xi Best 1/4 mile: 12.3@110 MPH | 335xi Top speed: 0-270 kph (165+ mph)
      09-09-2014, 06:22 AM   #12
X.X.I.V
X.X.I.V's Avatar
Drives: 16 F80
Nice
Just tried this yesterday
I'm FBO just 93oct
And I can't get the tires to break loose no matter how many times I've tried
It's a testament to how grippy my Conti DWS's are I guess
      10-03-2014, 10:23 AM   #13
jboyorak
Drives: 2008 335xi
A little late getting back to this. Here is some more technical info.
It appears the car isn't building boost off the line. I am using flash software, tunerpro, and bavarian technic to log.
It appears the car wants to build boost at first. Boost target initially goes to roughly 8-9 psi, then abruptly drops off to nothing and the dme closes the throttle. As soon as I start rolling target boost then goes up to normal.
I'd assume this is in the factory tuning to avoid doing just what I want to do. Is there a way to tune this out with a flash or do I need to use a piggyback to achieve what I want?
e90post
