WTB: N54 OEM Downpipe Cats or DP Fix
08-14-2014, 03:36 PM | #1 |
Rep 105
Looking to go back to the OEM Downpipes. Currently have AR Catless DP on now. Willing to trade + cash as well (local swap out is doable). Here's the thing, I have a 2010 E93 RWD N54 335i. I've read the XI models are different parts. I've also read that the pre/post 08/2009 DP's are different part numbers. Just to be sure, when sending me an offer, send me your year/model and part numbers. I would need it shipped to NJ if you're not relatively local.
OR... If anyone has a DP fix, I'd be interested in that as well. |
08-20-2014, 04:02 AM | #5 |
Rep 2,349
I have a set of stock ones i can sell you, but they would have to be shipped.
07 E92
Jb4-G5 - Sport Exhaust - Titek BOV BBS Lm reps - AFE dual cone intake |
08-21-2014, 06:17 PM | #6 |
Rep 105
I'm assuming both of yours are pre-08/2009 builds based on your signatures? Can you give me your Part numbers off both cats so I can cross reference? From what I've been told by the BMW dealer and confirmed with some part stores online, there's a different part number for pre/post 08/2009 cats. Also, PM me a price. Apologies in advance if I don't answer right away. Will be away on business for a few days. Will try to check in as often as possible.
08-29-2014, 05:30 AM | #8 |
Rep 2,349
Ah sorry you didnt tag me in your reply, so i had no idea you replied, make sure to hit Quote, so the people knnow you are talking to them.
I dont have a part number, but yes mine is pre 08. As long as its an N54 they should fit regardless. I'll take 75 plus shipping. Let me know (seems a pretty fair price for dp's with cats etc)
07 E92
09-03-2014, 11:16 PM | #10 |
Rep 105
Alrightly, I needed to pass inspection so I just ended up making my own dual line DP Fix. Confirmed both O2 sensors have independent signals so it should be safe to leave it in there long term, unlike the commercial ones that share the same signal to the ECU. I have a bunch of extra male/female pinned wires and would be willing to help others make their own, maybe as part of a service swap meet? Would just need to source out more resistors as I tapped out the local Microcenter.
I'm still open to buying an OEM DP from a 2009-2010 model if anyone has one for sale. |
09-14-2014, 12:36 AM | #11 | |
Rep 5,032
09-16-2014, 12:24 PM | #12 |
Rep 105
Fix was the same as in the DIY's all over this and other boards. Microcenter was out of 2.2 ohm resistors so I doubled up (in series) 1.1 ohm resistors for each "line" I made. The only difference was to make two lines instead of sharing the single O2 input. This allowed the ECU to read accurate (well modified accurate) readings for each bank. Haven't had any issues so far and IMO would resolve other people's issues with the incorrect fuel trim due to sharing the same signal on both banks on the commercially built ones.
For anyone local to me, I wouldn't mind helping build/solder it up for you, so long as you supplied the parts. Microcenter near me (Paterson) just remodeled so doubt I can find the resistors you need there as I bought everything that was on the shelf. Might be luckier somewhere else, possibly even Radioshack. Simple diagram: (Line 19/20) O2 input -> 2.2ohm resistor -> XXX ->ECU input (Line 19/20) \-->10ohm Resistor -> Ground (Chassis or Line 23) Line 19/20 would replaced with the new line you make and/or cut and spliced with this setup. Line 23 would only be T-tapped or you can use a chassis ground. I didn't take photos before I taped (sealed) and installed mine, but if there's enough demand, I wouldn't mind making one for someone locally (you buy parts) and take photos along the way. Maybe even take a video of the before and after O2 sensor readings as proof of independent signals if someone doesn't believe me? If anyone needs a new 10ohm variable resistor (potentiometer), I have one of those as well ($10). I was originally going to duplicate the "commercial" designs, but decided to try the dual line method. |
