08-01-2014, 05:13 PM | #1 |
1765
Rep 7,650
IND | Painted Key Hole Cover Installation
The old adage goes, "the devil is in the details". In keeping with this philosophy we are now able to offer the IND painted key hole cover for the F8X M3/M4. On all modern BMW 3 series vehicles the factory positions a physical key hole on the driver side. There is certainly nothing wrong with the key hole, but the painted cover is a great solution for those that seek a more streamline exterior.
The key hole cover is a OEM BMW part that is painted at our facility and can be shipped worldwide. For individuals that are concerned about the possibility of a dead battery, the key hole cover can be installed over the existing lock cylinder without any modification. Available for purchase through our website http://ind-distribution.com/ind/cate...ole-cover-1186 Tool(s) Required: Torx 25 Step 1: Now for the fun stuff. When you open the door you will notice there is a rubber plug located at the top of the door parallel with the door handle. Remove this cover. Step 2: With the rubber plug removed you will notice an opening. Using the Torx25 driver unscrew the Torx bolt that is set within the opening. Step 3: Upon removing the Torx bolt patiently wiggle the lock cylinder from the door. Step 4: Now that the lock cylinder is out of the door the goal is to remove the factory cover. The cover is held in place by 2 plastic tabs, one on each side. Use a pick or a smaller screw driver and carefully pry the tabs upward. Do not apply too much force! You simply need to move the tab enough to release the lock cylinder Step 5: Now that the lock cylinder is removed from the cover you are now able to install the IND key hole cover. This cover simply slides over the cylinder and is secured with the same tabs. IMPORTANT! When placing the cover over the lock cylinder the tabs may not effortlessly slide into place. Apply pressure on the flat portion of the tab until they are seated properly.
08-04-2014, 10:25 AM | #4 |
1765
Rep 7,650
Unfortunately the only way to access the lock cylinder is to break the cover. The tabs that secure the cover to the lock cylinder are rendered inaccessible when installed in the door.
08-08-2014, 08:06 PM | #7 |
Rep 106
09-19-2014, 10:38 AM | #12 |
Rep 42
Just changed my key cover on the my M4. The seal the blocks the bolt is a bit different on the coupe. Just peel it back and the follow IND instructions with the sedan. Took 5 minutes and it ns things up. Definitely worth the money.
2015 F82 M4
2014 F30 335i xDrive 2012 Tundra 5.7L 2004 S2000 |
11-23-2014, 11:53 PM | #13 |
Rep 1,656
Same here. M4 has that bigger rubber piece. The long part of the lock looks different as well, no biggie, but I did have to shave some of the inside of the new piece so it would click in.
12-05-2014, 04:23 PM | #14 |
Rep 145
I bought one for my F30 and never installed it. My M4 is same color (AW)... I assume it is the same part and will fit on the M4?
2017 BMW M3 6MT Comp
2002 Porsche 911 Turbo 6MT 1972 Corvette Stingray |
12-05-2014, 08:57 PM | #15 | |
Rep 1,517
I jest because I have installed this as well |
12-08-2014, 11:04 AM | #16 |
Rep 119
Looks cool but given history (my understanding anyway) of BMW's and their batteries I worry about this. I think I'll try painting the lock area body color as a compromise on looks/"emergency manual access"
AndrewC198910931.00 |
01-24-2015, 01:20 PM | #17 |
Rep 108
Drives: Sakhir Orange M4
Did you ever try this? I'm curious to know how it turned out because it sounds like a good compromise to me.
03-21-2015, 09:34 PM | #18 |
Rep 86
Some questions since others like me will likely find this isn't totally obvious:
- Does the torx need to come completely out or just loosen? If so how do you stop it from dropping inside the door? - The bolt just turns but isn't coming free in my case - Do you pull the existing lock straight out or does it come out at an angle (one side then another) - mine isn't coming out easily at all! - Can/should you push from the inside to pop it out? Thanks all. ** EDIT ** Answering my own questions here for posterity - hopefully it will save others 30+ mins. - It's ok to pry back the rubber seals - they are held in by 3 round grommets and the top slides into a slot - note this is an M4. The rubber won't just pop back into the round holes though you'll want to use a flat slim screwdriver or similar to pop them back in. - The torx bolt does not come out of the inner lock assembly. Loosen until it's spinning then pull hard on lock mechanism. No need to worry about torx dropping into door and rattling - The lock does pull straight out but you need to jiggle it top to bottom and pull hard - The swap out is a cinch, the new part fit well for me and I reused the lock assembly in case of emergency. - Inserting it back for me was the hardest part. The assembly seems to fit with extremely small tolerances top to bottom. I found it helpful to use a small screwdriver and push down on the assembly while jiggling and inserting. Mine didn't sit flush though side to side, so I used the torx screw to pull it in tightly, then loosened it again and reseated it until it sits flush. Then re-tighten. - Voila looks clean! Hope these extra instructions help people like me. BTW I had the same cover on my e92 and never had any issues, though I always used a trickle charger in my garage when parked for more than a 2-3 days. Last edited by Chris Csf; 03-21-2015 at 10:31 PM.. |
BitchinManWheels343.50 |
03-21-2015, 11:00 PM | #19 |
_______
169
Rep 1,088
I've had some pretty dead batteries in previous BMWs and the lock is one of the last things to go. This is my fourth keyhole delete on as many BMWs and I've never had to break the cover to access the lock because of a dead battery.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat |
04-16-2015, 11:56 AM | #20 | |
Rep 582
I also had a bit of a tough time getting it back in. Once you line up the TORX 25 bolt then you can use that to align it properly and bring it back in. One thing to note for those doing this, in step 4 of the OP, the tabs are the black long pieces. This took me awhile to figure out as I was thinking it was a typical tab inside the piece but rather they stick out about 3/4". Great addition, and as for the battery issues (I have had my own with BMWs) I just will leave the car unlocked in my garage as its private anyway. @IND, you should add a few clarifications to your post as it will save others lots of time. (Granted I should have read the whole thread before attempting it, as opposed to just reading your post. None the less, its worth noting on your post) |
04-17-2015, 08:33 AM | #21 |
Rep 1,450
I will say that if you want to reinstall the lock you will need a sharp hobby/pocket knife and some patients to shave down some areas for a nice fit. It's worth it to me. If it came to it you could cut/break/drill the cover and manually unlock if the battery is dead.
05-12-2015, 05:36 AM | #22 |
Rep 250
I have just installed the cover on my M4. It was very easy - plug & play - no need to sharp anything. It took me 5 minutes and everything was done.
I will post some pics in my car thread. Thanks to IND! |
