07-22-2014, 10:30 AM | #1 |
INSTAGRAM: @yaasplease
166
Rep 1,023
19x11 ET40 rears with 305/35/19 possible?
What do you guys think? Any guesses? I used different calculators, and consensus is a 13 mm decrease in both internal and external clearance.
2015 ///M4: M/Vorsteiner Aero, P3Cars, HRE R101, Dinan S2, Coils & Intake; Eis/Akra Exhaust
2013 WRX Hatchback: LED Conversion, Blacked Out, Rally Armor 2015 Macan Turbo: Techart Exhaust, Cargraphics Lowering Module, Blacked Out |
07-29-2014, 02:04 AM | #2 | |
Rep 1,095
Drives: 09 SC E90 M3 / 13 F10 M5
This is what the Porsches run factory. Depends on brand too.. I tried 305 michelins on 11" and it was way too wide.
07-29-2014, 10:21 AM | #3 |
Rep 3,051
You can prob run a 305/30/20. Don't quote me on it.
I'm planning on doing 295/30/20 with a 11 et 32 then trying out 11et 26 with a 305
2022 RAM TRX
2021 Ford Bronco 2022 BMW M3 |
07-29-2014, 10:54 AM | #4 |
definitivecars.com
354
Rep 3,833
Drives: Elsa - 2015 F80 M3 - YMB/SS
Garage List 2011 E90 M3 [6.66]
2009 (Lease up Sept ... [0.00] 2007 (Lease up 6/19 ... [0.00] 2007 (Lease up Octo ... [0.00] |
I was told that 295/30/19 11 wide with ET41 was the most aggressive you could go without rubbing problems. This was from IND, which is where I ordered my wheels... Hope you dont have problems with such an aggressive setup.
D |
07-29-2014, 11:23 AM | #5 | |
Rep 1,276
19x11 et 41 on 295/30/19? what is your front going to be?
2018 F80 M3 AW / SO
07-29-2014, 02:25 PM | #7 |
definitivecars.com
354
Rep 3,833
Fronts will be 275/30/19, 9.5 wide ET 27.
07-29-2014, 04:39 PM | #8 | |
Rep 1,276
whats ur front setup?
2018 F80 M3 AW / SO
07-29-2014, 06:13 PM | #9 |
Rep 949
04-29-2015, 04:19 PM | #10 |
Rep 3,834
redfox If you're running a staggered setup of 19s, I'd recommend 265/35/19 front and 305/30/19 rear (295/30/19 is less aggressive). This recommended setup has the same rolling diameter front and rear, better drive dynamic.
At ET40, you're fine with 305. Just don't run race compounds, like Hoosier, as their size is a bit larger than street tires. Refer to my reference thread if you have questions: http://f80.bimmerpost.com/forums/sho....php?t=1111833
Daily: G12 750 MSPORT Weekend Car: E90 M3
04-29-2015, 05:14 PM | #12 |
Rep 211
Drives: 2015 F82 M4 DCT
I am running 19x11 ET40 with 305/30/R19. Not sure about 305/35/19.
2015 F82 /// M4 DCT - BBS FI-R | Macht Schnell EVC | Eisenmann Performance | RKP GTS Lip | RKP Diffuser | IND Cosmetic Package | CF Seats Cover
2012 F10 528i xDrive - BC Forged HB05S | Meisterschaft GTC | 3D Front Lip | Vorsteiner Diffuser | MP Mirror Covers and Spoiler | ACS Springs |
04-30-2015, 08:43 AM | #13 | |
Go ///M or go home
276
Rep 1,280
2015 AB/SO F80 M3 6MT | 19" Black M437 | KW H.A.S. | AutoTechnik Black Front Grills | BMW Performance Side Grills | Painted Front Bumper Reflectors | Gloss Black Exhaust Tips
GONE 2011 SG/Blk E92 M3 CS 6MT |
04-30-2015, 08:45 AM | #14 | |
Go ///M or go home
276
Rep 1,280
05-01-2015, 12:46 AM | #16 |
Gone Fishin’
7316
Rep 12,125
In running 19x9.5 +20 (+25 w/ 5mm spacer due to rubbing on KW HAS) with 275/30 no issues.
My rears at 19x9.5 +35 with 295s have lightly rubbed the inner fender plastic a bit over huge bumps. +32 or so would probably be perfect. |
05-01-2015, 02:10 AM | #17 |
Rep 887
I'm runnning 295/30/19 on my Morr VS52 19x11 ET 30 with -2.2 camber no rubbing issues.
SilverLakeM3241.00 |
05-01-2015, 07:22 AM | #18 | |
Dinosaur supervisor
3030
Rep 4,214
05-03-2015, 08:39 AM | #20 |
One mod leads to another ...
416
Rep 2,900
19x11 et40 with 305/30 ... lowered on KW Clubsports ... no rubbing
Current: 2014 F10 M5 Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3 |
