07-21-2014, 03:35 PM | #1 |
Rep 623
aFe Momentum Cold Air Intake vs aFe Magnum FORCE intake?
Anyone have experience with either of these intakes? The Momentum is quite a bit more expensive ($419 vs $322 at Amazon), it it worth it? I'm curious to try one of them out...still a bit wary of CEL and/or rough idle but with Amazon, should be easy to return if not satisfied.
Magnum FORCE: Momentum Cold Air Intake: |
07-21-2014, 03:49 PM | #2 |
Rep 623
FWIW, the Momentum dyno chart looks quite a bit better than the Magnum FORCE as does the measured flow. (though just doing an intake ins't really known to give any real power gains so not sure how credible these charts are anyway).
Momentum CAI: Mangum FORCE: Last edited by HX_Guy; 07-21-2014 at 03:55 PM.. |
07-22-2014, 02:03 PM | #4 |
Rep 1,040
I have the Momentum Cold Air Intake on my car the first month of ownership. Can hear the blow-off valve open during higher rpm shifts. No problems or issues as some others have reported. I like that the cone is mostly enclosed to help reduce engine heat soak.
08-08-2014, 05:18 PM | #6 | |
Rep 4,528
Drives: M2 CS
08-09-2014, 05:01 PM | #7 |
Rep 1,040
Looking how Dinan designs the intakes for the F30 cars I believe the aFe design is fairly close. Granted you won't be paying for a Carbon Fiber cover but flow amount should be the same. Going to Dinan Stage 2 with the aFe should work just as well as the Dinan intake and be $1000 cheaper too!
08-10-2014, 07:21 AM | #8 |
Rep 189
Dinan stage 2? Where did you get that info? I only see stage 1 on their page. Also, does the Momentum CAI trigger any codes? maybe CEL? Will I need JB4 to get rid of those?
08-10-2014, 03:31 PM | #9 | |
Rep 1,040
If you want a good deal on a JB4, please PM as I'm selling mine (less than 4 months old with 1600 miles on it). |
08-10-2014, 04:21 PM | #10 |
Love to Drive
197
Rep 602
I have the momentum afe intake
No cel No rough idle at any time A lot more noisy than stock If you look at the pic of the momentum intake it has some breathers on top and also a connection to the oem snorkel to pull air from the outside... I sealed the breathers and the noise came down dramatically which I like and possibly intake temps.... |
08-10-2014, 04:31 PM | #11 |
Rep 246
Man I would love to see AFE make a non branded Momentum intake for us CA residence looking to go stealth and not raise flags with law enforcement.......that just starts the conversation of "Did you delete your cat?" :-(
M235i (Black) Auto, JB 4 (Stage 2 / Map 7 with EWG & FF wires) ER DP, resonator delete, running E35, BMW Performance LSD, Hankook Ventus R-S3's (255/35/18 & 235/40/18) ATE Super Blue Racing brake fluid, 35% tint, black grills!
08-11-2014, 05:09 AM | #12 | |
Rep 648
/Krelle |
08-11-2014, 09:15 AM | #13 |
Love to Drive
197
Rep 602
08-12-2014, 02:53 PM | #14 |
Rep 189
How did you seal the holes? And thanks for info, I think I'm going to grab one. Was worried about fault lights. I've installed short ram intakes before, and generally intakes are all easy, maybe 25 minute install, is this the same?
08-12-2014, 03:50 PM | #15 |
Rep 1,040
Compare to my WRX and the inside fender well install these are a piece of cake. Nothing tricky and everything in right in front of you. Converting back stock should be straight forward as well if you need too.
08-12-2014, 09:57 PM | #16 |
Rep 19
Any performance gains noticed with the MOMENTUM installed? I am torn between these two intakes.
-One has better dyno graphs and lower intake temps -Other makes more turbo noises and cost less. If any noticeable performance gains are noticed I will probably go with the Momentum. |
02-15-2016, 06:43 PM | #19 | |
Rep 75
02-15-2016, 08:35 PM | #20 | ||
Rep 321
