2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Wheel spacers installed!
      07-11-2014, 10:42 AM   #1
HX_Guy
Drives: 2014 BMW M235i
12mm front and 15mm back which I think is just about the right stance.
      07-11-2014, 11:16 AM   #2
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
Can you post the link where you got them?
      07-11-2014, 11:21 AM   #3
HX_Guy
Sure.
These are the lug bolts, ordered 2 packs (10 per pack): http://www.amazon.com/gp/product/B00ED4WMCS
And the spacers:
http://www.amazon.com/gp/product/B00KTNKDYQ
http://www.amazon.com/gp/product/B00KTNKG7U
The spacers don't list the 228/M235 as compatible cars but the specs (5x120, 72.6mm bore) are correct per H&R's website for the car. There was some initial interference from the black plastic cap on the hub but I think that's going to happen with any spacer in 12mm/15mm on this car, another member ran into the same thing with a different brand spacer. I didn't modify the cap like they did though, just tightened the lug bolts and it worked fine.
      07-11-2014, 12:49 PM   #4
Japper
Drives: F25 x35i, M235i
Nice stance, looks perfect.
Braver than myself going for an unknown brand on spacer and lugs though!
      07-11-2014, 12:51 PM   #5
HX_Guy
Yeah, I figured aluminum is aluminum, can't really mess it up unless they are unbalanced but there is no sign of vibration or anything.
I do have some concern about that plastic dust cap though...what's the deal with that? I've never seen it on any other car.
      07-11-2014, 01:40 PM   #6
VMRWheels
VMRWheels's Avatar
2038
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Nice touch
      07-12-2014, 08:21 PM   #7
HX_Guy
So I didn't feel 100% comfortable with the way I did the first install and how I put the spacer on top of the dust cap. What ended up happening was that the spacer did not sit flush on the face of the wheel hub by just sliding the spacer on, once the wheel was on and torqued down, then the plastic got squeezed and it sat flush, but it kept bothering me in the back of my mind so I went back and redid it.
I removed the dust caps and found they weren't air tight and sealed like I had understood from another thread I read on here. They pop in pretty similarly to wheel caps. With the dust cap removed, the spacers fit perfectly flush against the wheel hub face.
The rear hub does have some benefit of having a dust cover, since it's protecting something but the front is totally useless as there is nothing inside the hub.
Rear:
Front:
Since the caps aren't an actual air tight seal, I felt it was no problem to just install the caps on top of the wheel spacer and then put the wheel spacer on the hub. The rear caps actually fit pretty snug inside the spacer but the front are somewhat loose, so I applied an epoxy to the caps and attached them to the spacers both front and rear.
While in there, I also checked to see if smaller spacers could be installed on the rear of the car but it does in fact seem that 15mm is the smallest because of how far out the hub sticks out.
When the spacer is flush with the hub face, the hub ring is flush with the inner ring of the spacer.
      07-14-2014, 08:20 AM   #8
ManCityFan
Drives: Evo IX MR
excellent pix and writeup. very helpful for those of us considering spacers.
      07-14-2014, 09:24 AM   #9
pikcachu
pikcachu's Avatar
1399
Silicon glue might be a little less permanent option
      07-14-2014, 10:20 AM   #10
JM35
N54 Tuner
JM35's Avatar
Drives: 2008 135i 6spd
Any plans on lowering it? Fitment looks great but would be even better if it were lowered
2008 135i - 6MT - Jet Black
600hp 135i build blog
      07-14-2014, 10:47 AM   #11
RW Carbon
RW Carbon's Avatar
Drives: BMW F80 M3 & F87 M2
Perfect spacer size
Carbon fiber for the everyday driver: rwcarbon.com
3941 E La Palma Ave Anaheim CA, 92870
info@rwcarbon.com / (714) 328-4406
Instagram/Tiktok/Facebook: @rwcarbon
      07-14-2014, 11:00 AM   #12
HX_Guy
No, I don't plan on lowering it, I think the height is just right.
      07-14-2014, 11:01 AM   #13
HX_Guy
Originally Posted by RW Carbon View Post
Perfect spacer size
Oddly I don't like the back really, too aggressive for me in the back but most people seem to like it. I have a couple other sizes on order (5mm and 13mm) and will be putting the 15mm rear up for sale. Keeping the front 12mm though, I think that end looks perfect.
      06-20-2015, 10:32 AM   #14
M2TROLL
WRX Betrayer
Drives: M235ix Estoril Blue Coral Red
Sorry to revive an older thread but any issues with these amazon spacers and bolts after so many months? Or had you switched it up for any particular reason?
2addicts
