07-07-2014, 10:09 PM | #1 |
Rep 969
Wheel Fitment BEWARE!
So I got a set of E60 535i wheels since they are very similar offsets and same widths for winter use... Yeah they don't clear the back clips on the caliper for the front or the back. I don't even think spacers will help seeing as the wheel itself is the same circumference all around.. I'm pretty mad. So if anyone is looking for a set of 535 wheels... I've got some haha.
Looked at the our OEM 18s that came with the car.. It steps down to allow for clearance.. No clue how to even find aftermarket wheels then with this feature... |
07-08-2014, 08:53 AM | #3 | |
Rep 969
SUMMER WHEELS (F) 9 x 18 ET29 (R) 10x18 ET40 WINTER WHEELS (F) 8.5 x 18 ET27 (R) 9x18 ET29 The E60's 18s are... (F) 8 x 18 ET20 - (R) 9x18 ET32 So the rear is only 3mm off, I don't think a 5mm spacer would actually solve my problem. And the front should fit almost perfectly with extra clearance but the clips still rub. |
07-08-2014, 09:24 AM | #4 |
Rep 949
you have plenty of room to play with. honestly to get a nice fitment you could run a 10-15mm spacer on the front and for the rear a 15mm and still be fine! they would still sit in the fender and not be too flush.
07-08-2014, 09:33 AM | #5 |
Dinosaur supervisor
3030
Rep 4,214
But it is not the spokes (that spacers can solve) that are the issue, it is the barrel that touches the calipers as I understand it.
07-08-2014, 09:39 AM | #6 | |
Rep 969
Noticed in the first picture here.. the OEM wheel is narrower towards the outside of the wheel and then dips in and the barrel is now wider all around. That's where the caliper clip starts. The clip I'm talking about is this guy.. This picture is pretty unhelpful, but this is when the E60 wheel is on.. The clips are touching the barrel to the point where it doesn't allow the wheel to spin freely |
07-08-2014, 09:42 AM | #7 | ||
Rep 949
07-08-2014, 09:43 AM | #8 |
Rep 969
Yeah. I just want to warn people before they go out & buy wheels that apparently offset isn't the only thing we need to look for now.. barrel size is.. which I don't think that's listed in most cases.
07-08-2014, 08:50 PM | #9 |
definitivecars.com
353
Rep 3,833
Drives: Elsa - 2015 F80 M3 - YMB/SS
Garage List 2011 E90 M3 [6.66]
2009 (Lease up Sept ... [0.00] 2007 (Lease up 6/19 ... [0.00] 2007 (Lease up Octo ... [0.00] |
That's a bit scary, I'm hoping that someone can shed some light on why this is happening. It's very weird that the barrel would be so much smaller to cause this issue... I guess if your going 19s it's not something to worry about.
07-08-2014, 09:28 PM | #10 | |
Rep 969
I'm too scared to buy another set.. I even called the dealer today asking them how much the winters are.. they said they wouldn't know until September. |
07-10-2014, 10:32 PM | #11 |
Rep 3,244
Try some Apex EC-7 18's. I know they clear 380mm Brembo brake kits for the E9x M3 platform.
07-11-2014, 05:42 PM | #12 | |
Rep 32
I would suggest looking at some aftermarket wheel options for an 18'' wheel setup for your M3/M4. -Frank |
07-13-2014, 11:23 AM | #13 |
Rep 969
So this morning.. I stuck the BMS pin in so I could hang the wheel there. I pulled it so that it was just barely hanging off the lip of the hub and it seems to have just enough clearance to rotate around the caliper clips.
I measured the hub lip and it's roughly a bit over 10mm.. so I might try a 10mm spacer to see if that fixes the problem. I would need 4 unfortunately since it looks to be the same prob all the way around. If this works I'd be SO happy. With the spacers though.. there's gonna be about 5mm of extension than OEM summers.. so hopefully rubbing doesn't happen.. I feel 5mm is small enough that it should be alright? |
07-13-2014, 11:58 AM | #14 | |
Rep 3,244
See the quote from Turner Motorsport's web page for an explanation. "A note about 10mm spacers: Any 10mm spacer is considered a custom fitment. The stock hubcentric lip on BMWs can stick out by as much as 11mm. This leaves a gap between the spacer and the hub which seriously compromises safety. We recommend using a larger spacer (12mm and larger do not have this issue) or check that the lip sticks out less than 10mm." Turner Motorsports http://www.turnermotorsport.com/p-43...lications.aspx You will not have a problem with rubbing. Have you seen some wheel fitment threads on here? |
07-13-2014, 01:12 PM | #15 | ||
Rep 969
07-13-2014, 03:13 PM | #17 |
Rep 286
When I was in Europe for my ED I bought a set of 19s and those 19s didn't fit for the same reason. They actually could bolt on, but they barely rubbed the same way the OP mentioned. So all 19s won't work even on the Steel brakes.
07-16-2014, 08:52 PM | #18 |
Rep 969
Upon trying out the 12mm spacers today.. although I didn't bolt it up, I was able to mount it on the spacer's hubcentric ring & the wheel was able to rotate without scraping the caliper clip!! I checked the front.. I didn't test fit the rears.
Another note.. the extended bolts I received were not the same thread pattern as the e9x bolts.. That's annoying... So, that's SOMETHING ELSE we need to keep in mind... |
07-16-2014, 10:35 PM | #19 | |
Rep 2,787
07-17-2014, 12:44 PM | #20 |
Rep 969
07-17-2014, 02:53 PM | #21 | |
Rep 2,787
http://www.apexraceparts.com/apex-pr...l#.U8gpY_ldUmk |
