European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      07-03-2014, 01:44 AM   #1
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
MOAR FART GUN NOISES!! (Equivalent of Golf tee mod)
The F80/F82 use electronic valves in the exhaust. You can see them in the diagram below in yellow. When you start the car, they are fully open but after warm up, they close up and gradually open at around 2500 rpm or so, depending on what mode you are in.
If you notice, the muffler is almost entirely bypassed when the valves are open. I was very surprised at how loud it is with the valves disconnected - not much difference under load, but at idle and starting off, the car is quiet a bit louder. I ended up plugging mine back in - the car doesn't sound any better. It's still flatulent, just really loudly flatulent.
Anyway, if you want to disconnect them, with the car off, lay on the ground and look up at the muffler. On the outside of each side, to the front of the car past the muffler you'll see the valves. Just squeeze the latch on top of the connector and they pull off. Secure them so they don't flop around. I found it easier to use a pair of pliers, since the latch is pretty tight.
See pics.
Unfortunately, it doesn't improve the sound at all and it just makes the car louder at part throttle and low RPM.
DSC_3369 by Kit W, on Flickr
      07-03-2014, 05:33 PM   #2
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25039
Drives: '22 Chalk Gray Porsche C2S
Flatulence. The sound of victory!
      07-03-2014, 08:43 PM   #3
parky1215
parky1215's Avatar
561
Drives: F90 M5C | G06 X6 M60i
Shouldn't you disconnect when car is on with flap open?
I believe flap is at closed position when car is off. Disconnecting it when off would then leave that flap permanently closed until you plug the cable back.
Anyway, does it throw any error when you leave the cable disconnected?
      07-04-2014, 11:58 PM   #4
kitw
kitw's Avatar
471
All you need to do is shine a flashlight into the exhaust, and you can see. It's open when the car is off, on my car.
Honestly, it makes very little difference - in Sport or Sport Plus, the exhaust is mostly open anyway.
No CEL, but I'm sure there is an error code. Similar to unplugging the connector on an e90/e92 335i
      08-07-2014, 09:08 AM   #5
bobbyz
Drives: E90 M3
Thanks. Will try this when My M4 arrives. If I had DCT, I wouldn't do it and just put the car in Sport+ all the time, but with my 6MT I will loose the rev match feature in Sport+ so this is a nice solution to have both the flaps open while retaining rev matching.
      08-07-2014, 12:39 PM   #6
Definitive
definitivecars.com
Definitive's Avatar
Drives: Elsa - 2015 F80 M3 - YMB/SS
Just did this and it actually made a huge difference in start up sound, low rpm driving and parking. Now just to figure out what to do with the plugs hanging around. I suck mine through the biggest opening in the rubber exhaust hanger, but I dont like it just exposed to the elements. I wonder if wee can get a cap or something for this plug...
D
      08-07-2014, 02:22 PM   #7
bobbyz
Drives: E90 M3
Just wrap them up good with black electrical tape making sure to cover the contact area well.
      08-07-2014, 04:56 PM   #8
CatchM3
CatchM3's Avatar
Drives: 2020 X6M Competition DG
2008 E90 M3  [9.00]
can someone help me and try to explain how to disconnect the wire? Does it just simply pull right out? There is a slight elevation on the top end of the coupling but I'm no certain if Im to push a tab in? It says squeeze the top connector but Im not having any luck.
Thanks guys.
2020 X6M Competition // Donington Grey // Executive Package// Bower and Wilkins Sound System // Driver Assistance Package // CF Trim
      08-07-2014, 05:42 PM   #9
Definitive
definitivecars.com
Definitive's Avatar
You want to grab the part of the plug that is red where the green arrows are with your fingertips. On the topside you squeeze the tab and pull away from the plug.
      08-10-2014, 07:02 PM   #10
parky1215
parky1215's Avatar
561
I am having EAS do this for me tomorrow when i drop by to get bunch of exterior parts installed.
      08-11-2014, 09:46 AM   #11
CatchM3
CatchM3's Avatar
2008 E90 M3  [9.00]
awesome! thanks for the help. I finally got them disconnected.
The sounds isn't too bad with the valves open. There is definitely more "noise" at low rpm's. The is mod has eliminate the annoying start up rattle too.
      08-11-2014, 09:48 AM   #12
CatchM3
CatchM3's Avatar
2008 E90 M3  [9.00]
let us know what you think of the sound Parky1215. Can't wait to see your car after all the exterior mods.
      08-11-2014, 10:53 AM   #13
parky1215
parky1215's Avatar
561
Definitely. I am also removing charcoal filter from intake so that may also contribute to some sound increase.
I am heading out to eas in few minutes
      08-14-2014, 05:43 PM   #14
Tonymiabmw
Tonymiabmw's Avatar
552
Drives: Nardo F90 M5 on order
How where the results?
      08-14-2014, 06:33 PM   #15
parky1215
parky1215's Avatar
561
It sounds better as you can hear exhaust note across all rev range whether you are pressing gas pedal or not, but it produces drones at freeway cruise speed on DCT from 70-75mph (1.8-2.1k rpm).
I put the flapper cable back to exhaust.
I am going to just remove secondary cat for now and wait for some nice axle back to come out.
      08-15-2014, 02:42 AM   #16
ameersM3
Drives: F80 M3
Just curious so you have no filter in your Intake?
      08-15-2014, 09:59 AM   #17
parky1215
parky1215's Avatar
561
I still have paper air filter in, but charcoal filter that sits on top of paper air filter is removed.
      10-20-2014, 10:15 PM   #18
Jaguar
Mark 42
Jaguar's Avatar
1051
Drives: M
Reviving this thread-so is it confirmed that you need to warm up the car, then go to sport mode and remove the plugs with the car on and in this mode? Or do you remove the plugs when the car has been off all night night?
      10-20-2014, 11:30 PM   #19
rutiger
Drives: m4
When car is off valves are open. So crawl under there and disconnect each side. Ziptie them up so they don't hang loose. Up to you if you want to cover the now open plugs on each end in some manner. I unplugged mine for some added noise and I like it. Will run this way until someone releases a reasonably priced exhaust.
      10-21-2014, 02:54 AM   #20
nasdaq100
nasdaq100's Avatar
France
66
Drives: BMW M4 DKG
I will save 6K Euros if it works as you said. I will don't need MPE anymore Just wonder if any of you got an error signal with DCT after unplugged them?
And can u take a pic how you wrap the cable and plugs?
Thanks a lot
      10-21-2014, 05:53 AM   #21
nasdaq100
nasdaq100's Avatar
France
66
Drives: BMW M4 DKG
Since when did u unplugged them? Did you notice any problems?
      10-23-2014, 12:25 PM   #22
Accel Junky
High on Acceleration
Accel Junky's Avatar
Drives: 08 M3, 90 GTR, 21 Gladiator
This is cool. So basically I can unplug these and have my noise AND rev-matching at the same time?
f80post
