E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Off-Topic Discussions > Smoke Detectors
      12-08-2007, 04:04 PM   #1
Snooky
Snooky's Avatar
40
Drives: Audi RS5 Sportback Carbon Blac
Smoke Detectors
Very OT but one of our smoke detectors has started beeping constantly today to 'tell' us that the back-up battery is low/dead. Driving us nuts but we cannot get the battery drawer out to replace it - there is a Key Slot above the battery drawer but we never got a key (we have had the house from new). I have tried screwdrivers etc and there is no manufacturer's details on the detector to try and get a key
Anyone else got detectors needing a 'key' to unlock the battery drawer? If so what do they look like etc
Next step is sledgehammer to knock it off the ceiling as the beeping isdoing my nut!!!
      12-08-2007, 04:44 PM   #2
mikem
Drives: Z4M
Can you unclip it from the mounting plate ?
      12-08-2007, 04:50 PM   #3
Z4 Beemer
Z4 Beemer's Avatar
Scotland
84
Drives: 2009 Z4 sDrive 23i
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
Is the key not located on the inside of the detector (the cover bit perhaps)?
E89 Z4 sDrive 23i... for the more discerning driver
      12-08-2007, 08:35 PM   #4
Serjames
Serjames's Avatar
Drives: E93 335i M-sport
yeh I'd be tempted to simply break in or smash it they only cost like a 5er or something for a new one...
      12-09-2007, 03:09 AM   #5
peterg1965
peterg1965's Avatar
Drives: F30 335d M Sport, F15 X5 40d
Trouble is I suspect it is mains powered, with a battery back up. We have a similar problem in that our mains powered one bleeps constantly when the battery is inserted into the unit. Therefore, we just don't put a battery in it. Not clever and I wished I had the builder put it right (new house) but its too late now.
Does the cover unscrew from the body ?
      12-09-2007, 03:39 AM   #6
Snooky
Snooky's Avatar
40
Thanks all - it is a mains powered unit and you cannot dismantle the unit without taking the battery drawer out first (serious design fault in my opinion). I am nervous about just breaking it off the ceiling as it is wired in.
Thanks for the help - I will continue to try the elbow grease route!!
      12-09-2007, 05:15 AM   #7
SoYank
SoYank's Avatar
Drives: 2009 E90 335i MT
Call the fire brigade (non-emergency number) and ask them to come take a look. I know they fit smoke detectors for a small fee. Once you get it resolved, replace the unit with one that doesn't require a key (what a screwed up design).
In the meantime, what does the keyhole look like? Maybe if we knew that we could brainstorm some solution to get your sanity back.
Is the unit mounted on a wall or ceiling with a baseplate? Most smoke detectors do and you normally insert it into the plate and twist. There will be a latch to keep it from easily being removed. The mains connection will normally be a socket (female) so that the unit can be removed and the electric remain safe. Some are designed where you have to remove the mains connection before you can gain access to the battery compartment.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7
European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor
Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269
      12-09-2007, 09:20 AM   #8
NFS
NFS's Avatar
Drives: M340i
Who is the manufacturer?
Does this help:
http://www.diconsafety.co.uk/downloads/2502_A0033.pdf
      12-09-2007, 09:38 AM   #9
Oli
Campervan man
94
Drives: RS3 and VW Kombi
Try using a lump hammer!
www.bmvs-camperhire.co.uk
Genuine VW T5 California Rental
      12-09-2007, 09:46 AM   #10
Z4 Beemer
Z4 Beemer's Avatar
Scotland
84
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
Do these mains powered smoke devices have 240volts going to them, or is it some sort of low voltage 12v setup?
      12-09-2007, 09:52 AM   #11
beemerbird
beemerbird's Avatar
England
172
Drives: Merc diesel
Good test would be, lick your fingers and touch the wires. The difference between 240 & 12 V must be about 6'......ie. where you end up on the floor
Seriously, if you can't isolate it off the ring main, then attack the bugger & make sure you've got a pair of rubber gloves on (marigolds should do it). That bleeping noise would drive me insane. Hope you haven't got a dog or cat as well.
      12-09-2007, 09:59 AM   #12
scotw
scotw's Avatar
Drives: E90 320D SG
2007 E90 320D  [0.00]
I had exactly the same problem, drove me nuts and was mains powered. In the end I cut the power to the house and took a screwdriver and hammer to it in order to get it off the mounting plate. The silence afterwards was wonderful!
      12-09-2007, 10:09 AM   #13
Z4 Beemer
Z4 Beemer's Avatar
Scotland
84
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
What are you guys like... sledgehammer and nut spring to mind
      12-09-2007, 10:46 AM   #14
Snooky
Snooky's Avatar
40
Some genius designed it so you could only unscrew the unit from the baseplate once you have removed the battery drawer...
Does this help:
Searched everywhere and no logo or manufacturer name
Seriously considered it Oli
Eeeeeek
Well (cue drum-roll) I finally got the b*gger out!!! One broken knife and forced lock later the little battery drawer relented. Popped new super duper (extra long life) Duracell in and waited... me on the step ladder, miswah and sprogwah standing just below waiting..... and silence, GLORIOUS SILENCE (so good I feel the need to shout!!!)
Thanks to all the support/advice and attempted murder (you know who you are....*cough* BeemerBird *cough*)
      12-09-2007, 11:04 AM   #15
NFS
NFS's Avatar
Drives: M340i
Bit late now, but having looked on the net a bit - I don't think this had a separate 'key'.
There is usually a locking pin, which prevents idle hands opening the battery drawer and filching the battery.
The pin (or key) would have to be removed before the drawer could be opened.
Or alternatively you could try a knife.
      12-09-2007, 11:36 AM   #16
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
949
Drives: 997.2 GT3
i would not spend 5 quid on a safety device.
Thats like buying a 70 pound crash helmet, sod that..
My Arai GP3k was 400 squid in 2000. Proper helmet!!!
Some are far more expensive tho. Mine is safe enough to use in f1
997.2 GT3
      12-09-2007, 11:41 AM   #17
Gibbo
Gibbo's Avatar
103
Drives: Golf Ed35
You thinking of applying for the 2nd seat at McLaren next year.
Alonso is replaced by 'Fandango' BMW 3 Series Diesel Test Pilot.
Golf Ed35 Black with - Black Leather
      12-09-2007, 11:48 AM   #18
Z4 Beemer
Z4 Beemer's Avatar
Scotland
84
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
Absolutely Carlos - smoke detectors are a waste of money and will not save your life. I have one of these expensive devices parked on my driveway to deal with any fires in my home.
      12-09-2007, 11:54 AM   #19
dxb335d
dxb335d's Avatar
England
949
Drives: 997.2 GT3
Would be nice mate
997.2 GT3
      12-09-2007, 11:55 AM   #20
beemerbird
beemerbird's Avatar
England
172
Drives: Merc diesel
Attempted murder Snooky lol, it's the amps you need to worry about - honest
Silence is golden though eh. Glad you're sorted.
      12-09-2007, 12:19 PM   #21
Hotcoupe
Hotcoupe's Avatar
Drives: Don't know yet!
Snooky Quote:
So it's silent,but how do you know it's actually working?
You need to light a bonfire underneath the detector to check it out,dining room table and chairs is a good test.
Make sure the lacquer is not toxic as the fumes might kill you,Helen has already failed!
      12-09-2007, 12:29 PM   #22
SoYank
SoYank's Avatar
Actually, I think Carlos is meaning he would not buy a safety device that cost a mere £5 but would invest in a more stable, quality unit. I'm with him on that score.
BTW, that big red and yellow machine wouldn't fit in my driveway. Heaven help me if I needed them to pay a visit. Love the wheels on it though.
e90post
