06-25-2014, 01:31 AM | #1 |
M3AT LOVER
322
Rep 1,853
List of Features code-able on F80/F82 M3/M4
There are a long list of features that we can enable for our new cars. I don't know most of them, but I want to know about them all and decide what I would want to enable or disable on my car.
Could we use this thread to build up a list of code-able features for our F80/F82 M3/M4 cars? Please post below and I will compile and put it on the second post of this thread.
2015 F80 M3 | SSII ext SO int | M-DCT | 19" Black Wheels
06-25-2014, 01:32 AM | #2 |
M3AT LOVER
322
Rep 1,853
From: http://f80.bimmerpost.com/forums/sho...8&postcount=33
1) DVD In Motion 2) Enable Video Via USB Port (HU_NBT only) 3) Disable Legal Disclaimers (Startup, Cameras, Etc.) 4) Add/Delete Weatherband Radio (WB) To Entertainment Options 5) Enable (Sport Displays) Torque & Power Meters In iDrive 6) Enable Tire Pressure & Temperature Readings In iDrive 7) Transfer Phone’s Ringtone To Vehicle 8) Disable Seat Belt Chimes (Driver and/or Passenger) 9) Disable Initial Start-Up 3 Dings Chime 10) Close Windows & Sunroof With KeyFob & Comfort Access 11) Fold/Unfold Side Mirrors With KeyFob & Comfort Access 12) Fold Side Mirrors As Soon As The Vehicle Is Locked 13) Disable Window Safety (Auto Up works when door is opened) 14) Start Car Without Braking/Clutching 15) Unlock Doors When Car Is Turned Off 16) Disable A.S.S Or Set It To Last Memory Setting 17) Close Trunk From Key & Interior Button (Only cars with power trunk mechanism) 18) Enable Fog Lights As Welcome Lights and/or Cornering Lights 19) Disable Halogen DRL’s 20) Enable Angel Eye’s As DRL’s 21) Disable Side-marker Running-Light LEDs (Still Work As Turn Signals) 22) Run High Beams & Fog Lights Simultaneously 23) Change ‘One Touch’ Lane Change Count From 3 Blinks to (4,5,6,etc) 24) Turn On Taillights As DRL’s 25) Disable Headlight Washers 26) Change Amount Of Sprays For Headlights Washers From 2-3 27) Digital Speedometer (On By Default On ///M Cars) 28) Enable ///M Performance Logo In The Gauge Cluster (Need 6WA Cluster) 29) Disable Speed Overestimation (Only For Analog Speedometer) 30) Change Cluster Language To Spanish, Chinese, Etc. 31) Disable Top Speed Restriction For Cameras (Can Be Used While Driving) 32) Angel Eye Brightness 100% during DRL and Headlights 33) Enable Full-LED Headlights (Dazzle) (Remove De-Coding for US LED Headlights) 34) Enable Siri Voice Control from Steering Wheel 35) Turn Cameras On/Off at any speed on iDrive Screen 36) Change Comfort Access Delays for Open/Close via Kick-Open Feature 37) A/C System Remembers Last Setting 38) Enable Enhanced Bluetooth (Streaming Audio via BT – depends on hardware in car) 39) Enable LED Door Handles Illumination when in Reverse 40) Increase the brightness of ambiance lighting 41) Add Sport+ to vehicle without this comfort setting
06-25-2014, 04:48 AM | #3 |
Rep 496
Drives: 2015 BMW M4 (transporting)
Flashing break lights, DVD in motion?
06-25-2014, 04:52 AM | #4 |
Rep 496
Here is a list from pillpusher
06-25-2014, 06:20 AM | #5 |
10711
Rep 27,531
^^dang thats a lot of option!
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
06-25-2014, 12:42 PM | #6 |
Rep 670
I need someone with an ///M3 or ///M4 F80/F82 and an ENET cable to pull me a copy of the SVT and CAFD files ... once I have a chance to review these, I will give you a full list of what I see can be altered through coding, as well as a cheat sheet with the values necessary to be altered to make said changes.
If someone has taken delivery already of an F80/F82 ... please e-mail or txt me ... and we can get this going. ************************* 973-477-5694 |
06-25-2014, 01:58 PM | #7 |
definitivecars.com
352
Rep 3,833
Drives: Elsa - 2015 F80 M3 - YMB/SS
Garage List 2011 E90 M3 [6.66]
2009 (Lease up Sept ... [0.00] 2007 (Lease up 6/19 ... [0.00] 2007 (Lease up Octo ... [0.00] |
Ok, Ive been watching Pillpushers threads, but was still unsure if I would do some coding, and now after seeing this list it is a must. I think I would do 75% of whats listed there!
Pill, Ill either be buying your cable or making one before I get my car. Ill be in touch with you about some questions I have that will determine if I decide to go at it myself, or do a remote session with you. D |
06-25-2014, 02:05 PM | #8 | |
M3AT LOVER
322
Rep 1,853
06-25-2014, 02:24 PM | #9 |
Rep 3,249
This looks really legit.
'21 /// M5 Comp - Frozen Brilliant White/Black
'18 Porsche GT3 Carrara White/Black/Red - Sold '18 /// M3 - Individual Imola/Black - Sold '15 /// M4 - YMB/SO - Sold '12 E92 ///M3 ZCP - AW/FR - Sold |
06-25-2014, 03:32 PM | #10 |
Rep 670
Thanks ... Not everything here applies to the 3er ... Not 100% sure until I comb through the cafd files ... But I will provide a final list after review .... Still need a donor for the cafd files ... Who's taken delivery and has an enet cable?
06-25-2014, 03:59 PM | #11 |
Rep 1,478
Come on guys, someone help Pillpusher out! My car won't be stateside until Nov (ED in early Sept) and really want feedback on what is possible/doable in the M4 - need some guinea pigs
06-25-2014, 07:22 PM | #12 |
Rep 496
Best I can do is the end of July. Surely someone will step up sooner than that.
06-25-2014, 07:27 PM | #13 |
Rep 670
06-27-2014, 01:36 PM | #16 |
Rep 2,991
06-27-2014, 02:04 PM | #17 |
Rep 670
I can remote in via teamviewer and setup for you if you are having trouble ... Just email me/txt and we can setup time if necessary.
06-27-2014, 08:38 PM | #18 |
Rep 172
I'm picking up my car in Munich on Tuesday morning and I'm bring the cable I bought from you. If I can get access to a decent wifi signal I'd be willing to help you out, but cannot make any promises. We'll see how my internet is.
06-27-2014, 09:57 PM | #19 | |
///MD
33
Rep 170
Damn!! I didn't know that all of that could be done. Sorry for the ignorance but is the dealer able to detect these changes when you take it in for service and could they somehow void your warranty? Also is there any chance you can screw up other things with coding? I wouldn't like to brick my car. Again sorry for the ignorance on this subject. |
06-27-2014, 11:04 PM | #20 | |
Rep 670
seriously ... if you have some down time with a good wifi signal when you are not enjoying europe or drooling over your new car ... let me know and we'll get to coding. Do you have my cell # (iMessage)? if not ... e-mail me: ************************* Do you have the software installed and all ready to go? If you want me to take a look at it for you ahead of time I can. |
06-27-2014, 11:09 PM | #21 | ||
Rep 670
I don't see how they could prove that the coding changes are ground for voiding the warranty. What coding does is simply use BMW's ESYS software to change pre-defined settings (already set in the ECUs by BMW) to operate at a feature that is not allowed/set for the market that your vehicle was delivered in, however is available in another part of the world. Quote:
As long as you do not hit the button that says "Code Default Values" in ESYS ... you should be fine ... however I guarantee nothing unless I'm doing it myself, and even then ... I'm not charging you for my services/time ... so it's all at YOUR own Risk ... but, yea ... the slightest chance in the world, maybe, that something could get screwed up. |
06-27-2014, 11:48 PM | #22 | |
///MD
33
Rep 170
