Go Back   BMW E39 5-Series Forum | 5Post.com > BMW 5-Series (E39) Forums (1995 - 2003) > General E39 Discussions
      08-26-2018, 12:31 AM   #1
JP's M2xx
Drives: 2016 M235i x drive conv
Looked at an '02 540 today, have a question
So I checked out a 2002 540i today with sport package. I noticed a lot of negative camber in the rear wheels, is this normal for these cars or is this something that I need to look into further?
The test drive was great and I'm guessing the negative camber is a help in the corners but want to make sure it isn't a sign of something bad that will need repair.
Thanks!!!
      09-25-2018, 08:00 AM   #2
BH86ENG
Drives: 2006 BMW 330i 6-Spd Spt
You will absolutely notice an increase in wear. If you are looking to daily drive I highly recommend having it aligned at a shop where you can request an alignment different from spec.
I had mine modified with as little negative camber as possible while still equal on both sides. I think I'm around -0.8 degrees.
Still handles great, still a joy to drive, I get more than 20k out of my tires.
