04-09-2016, 06:22 PM | #1 |
Rep 81
Buying a e92 M3 with 105k...
Hi M3Post, this is my first thread on here, I have many on bfc. I have had a couple e36 M3's over the years and in the process of searching for a clean e46 I stumbled upon this alpine white 2009 M3 coupe with dct. I made my way to the dealer to check the car out and it was super clean showed very little wear especially considering the mileage/ age. The only thing that did concern me was the car idled rough it bounced around from 750 then dipped down to 550 rpms for a second. I assume the car had not been started for a couple days, anyways after 3-4 minutes the car shut off. Not sure if this is because the key proximity (dealer went into office with key) exceeded its limit, or if this car is just a sick puppy. Despite that, the car is overall very clean and I negotiated a deal with the dealer, and would like to hear some input from more knowledgeable people regarding whether to buy this car or keep the search going. Thanks!
here is a link: http://www.msportmotors.net/2009_BMW..._261093545.veh |
04-09-2016, 11:19 PM | #2 |
Rep 60
Obviously depends on the price but that engine doesn't seem to be in great shape. The car shouldn't just shut off even if the key is taken some distance away.
04-09-2016, 11:50 PM | #3 |
Rep 1,611
I would honestly suggest before you consider buying it, to get yourself a tool we all use here, called Carly ( former BMWhat ) It has an VIN check and pre owner driving habbit check aswell as coding and CEL readout & erasing.
Easy & super fast handling as the OBD2 adapter gets operated by your smartphone. Please be careful with considering an rough running ///M, specially when you're on a budget! Here's all money saving info you need to know to be 100% prepared as an future m ///M 3 E9x owner. http://www.m3post.com/forums/showthread.php?t=1245204 Last edited by vsix; 04-09-2016 at 11:55 PM.. |
04-12-2016, 07:09 AM | #5 | |
Rep 2,362
No such thing as key proximity unless it is equipped with comfort access. I walk away from my car into my house or a store with the ignition on (with passenger/s inside) and it's still running when I come back. So no, it is not that either. |
04-12-2016, 07:18 AM | #6 | |
Rep 927
This. I have comfort access on my car and I can walk halfway across the world away from my car with the key in my pocket locking the doors and all without it turning off. Sounds like it might have a couple of hidden issues to it |
04-13-2016, 01:26 AM | #7 |
Rep 81
I just left a non-refundable deposit and was going to pick the car up next week. I looked into the carfax and it was fully serviced at a BMW dealership just a month ago.. What could cause the car to just shut off at idle?
04-13-2016, 07:32 AM | #8 |
Rep 1,320
Just a heads up OP, normally buying a car with 100k+ miles isn't unreasonable....but buying one of these takes way more consideration. I hope you have deep pockets, because repairs for this vehicle (especially on of that car's mileage) are still repairs on a what-once-was 70k vehicle. Just because it was serviced at a BMW dealership doesn't mean crap, good luck and let us know how it goes!
04-13-2016, 03:30 PM | #10 |
Rep 734
Car shutting down by itself is quite questionable... and you put a NON-REFUNDABLE deposit of how much? You need to do more research and protect yourself when buying a M3 for sure, and expect the usual things to go wrong potentially (Throttle body Actuators, Rod Bearing Changes [for peace of mind], etc.)
Personally, i will actually steer clear. Good Luck!
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold) 01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold) 08' E90 M3 6MT - DD 13' W212 E63 AMG Wagon |
04-13-2016, 03:35 PM | #11 | |
Rep 927
04-13-2016, 11:39 PM | #12 | |
Rep 81
04-14-2016, 07:46 AM | #14 | |
Rep 1,566
04-14-2016, 07:51 AM | #15 |
Rep 486
I looked at a CPO one that did this when we let it idle and talked about it.
My research said it was the idle control valve or some other valve, that I can't remember now. Its a cheap fix. It could be that...or it could be hot garbage. |
04-14-2016, 09:59 AM | #16 |
Track Whore
542
Rep 1,640
Find out of the IACV, TVA and rod bearings have been done.
If not, that's gonna cost you like $5,000-$7,000 not to mention other wear parts that may not have been serviced... Radiator Water pump Thermostat Belts Etc I bought a used one with 101,000 on it and spent $3500 replacing everything above at $0 in labor because I did it myself. I also had an independent third party do a full PPI and a compression test on the motor. Good luck! |
04-14-2016, 10:19 AM | #17 | |
Rep 1,566
OP, how much are you getting the car for? If it's anywhere near the $27k asking price I wouldn't touch it with a 10ft pole. It would have to be below $25k to be a "good deal." Maybe $23-24k? I would expect to put $3-5k into it to cover some of the things mentioned above. Maybe more if it needs things like tires and brakes or if you will be paying for labor. Do you have any extended warranty options at this mileage?
04-14-2016, 01:59 PM | #18 |
Rep 1,326
You're buying a car that isn't running properly right off the bat. Why would you do that?
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
04-14-2016, 02:14 PM | #19 | |
Track Whore
542
Rep 1,640
04-14-2016, 02:45 PM | #20 | |
Rep 927
04-14-2016, 04:43 PM | #21 |
Rep 81
The rest of the time the car was running fine, that was just what happened the first time the car was started in a days if not weeks. The car is cosmetically in perfect condition and had a bunch of recent maintenance, not sure of the specifics but I will call the dealership it was serviced at and ask. I have already ordered a Blackstone oil analysis kit and will send it a sample in as soon as it arrives, and that should reveal any potentially serious issues regarding the motors health. Also if when I go to pick the car up and its running like shit I obviously won't buy it, or have the dealer take care of it.
04-14-2016, 04:50 PM | #22 | |
Track Whore
542
Rep 1,640
Also, Blackstone recommends you warm up the oil first FYI. Good luck! |
