BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      04-19-2021, 09:31 AM   #1
Pappas Fritas
Pappas Fritas's Avatar
Drives: E93 M3, Melbourne Red, 6sp
DIY: E93 Roof Drain Cleaning (Convertible, Origami Top)
Greetings fellow e93 owners!
This is an important PSA for E93 owners. These roof drains are often overlooked until it's too late. Front drains can leak into the cabin, and rear drains can flood your trunk (and damage all of the electronics stored in the lowest areas ). This is a starting point, and I will add photos/videos next time I do it.
Front Convertible Roof Drains:
When the top is down, you will see them at each corner at the “top” of the windshield. This Youtube video shows them early on in the video:
I use a 1/4” trombone cleaner to clean them, while some use a hose or compressed air. Note that it drains from the bottom of the A pillar and will splatter nasty crud when the door is open. I usually put a bucket or piece of plastic to cover the door/door jam.
Rear Convertible Roof Drains:
The drain plug is located behind a small trim panel directly in front of each rear wheel. Remove the plastic trim piece first in order to access the drain plug, which is held on with 2 plastic T30 bolts and 3 tiny push through rivets to get it off. Once that trim is off, use a 14mm socket to free the plug’s pins by loosening a 1/8 turn then pull it down to get it out. Don't force it more than that or you risk breaking the pins. Here is a video of someone else doing it, but please note that he improperly rips the drain plug out and I also would be nervous sticking a garden hose up into the drain like he did.
This is a starting point, and I will try to update with photos/videos next time I do it.
'08 E93 M3, 6 speed
Melbourne Red Metallic with Fox Red Interior.
BE Bearings / BE-ARP Bolts @ 57k miles by Active AutoWerke (12/2020)
Active Autowerke Pulley, Tune, and drop-in Filter. Full Akrapovic Evo Exhaust (dual resonated with secondary high flow cats).
CTMike262.00
bake602.50
ToddinTN504.00
victo6.00
      04-19-2021, 09:28 PM   #2
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
Thank you for posting this!
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      04-20-2021, 03:39 PM   #3
jdamore
jdamore's Avatar
436
Drives: 2008 e92 M3
Wow. That was a lot of water! Does this apply only to e93s?
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
      04-20-2021, 04:38 PM   #4
Pappas Fritas
Happy to share the info, helps all of us to share and collectively comment in one location! I'll update this with photos next time I clean them.
These drains are specific to e93s. There may be other drains specific to e90/e92, ie sunroof drains. Someone else will need to chime in.
Fyi, There are 2 drains in the engine bay that all e9x M3s have, close to the windshield. They have a small baskets in them to stop leaves from falling in.
'08 E93 M3, 6 speed
jdamore435.50
      07-13-2021, 08:28 AM   #5
E93M3MW
Drives: E93 M3
Firstly thanks for the very helpful post and informative video!
Unfortunately I couldn't get to free the plastic plug's pins. A 14mm socket doesn't fit as it was too small, and I couldn't find anything suitable to turn it to loosen it. I had to use the method in the video, yanking it off with pliers
The good news however, was that not a single drop of water came out!!
      02-17-2022, 06:10 AM   #6
Kixars
Drives: BMW 335i
Mine were blocked and submerged the hydraulic roof motor. It corroded it away to the point where fluid poured out. Now looking for a new motor.
      03-11-2022, 01:08 PM   #7
cloumeM
Drives: BMW e93 M3
Just checked mine and no water found. Then again, it rarely sees any rain...
      11-13-2023, 11:05 AM   #8
b4ldguy
Drives: M3 V8, Bentley GT, Lexus RX
This is exactly what i needed and have cleaned and checked all my drains on my UK M3.. Many thanks!
      04-24-2024, 01:34 AM   #9
Mak1etee
Drives: e93 M3 jerez black
Anyone knows the name or the part number for the plastic drain plugs ?
Can't to find it online
Tags
convertible hard top, convertible roof, drain, drain plug, e93, e93 cabrio, e93 convertible, e93 diy, e93 routine maintenance, roof drain
m3post
