03-09-2021, 04:53 PM | #1 |
Rep 658
Cant get road paint overspray off the back bumper
A while back I got road pain overspray in tiny dots on the mid and right back bumper and nothing seems to take it off. I tried Goo gone after watching youtube videos but that didnt help either.
Any advice? |
03-09-2021, 05:01 PM | #2 |
Rep 685
Take it to a pro, won't cost a ton and they'll have no problem getting it off with paint correction. I've given up doing stuff like that and just take it to a shop.
03-09-2021, 05:41 PM | #3 |
Rep 1,532
Overspray is a pain, especially road paint which is tough as hell. A pro detailer will typically use a heavy grade clay bar and then polish, or use a plastic razor blade to try and carefully scrape off each dot.
2013 335is Mineral/Coral - DR 6466 - DR Mani - PI - Motiv FF - Dodson Clutches - OEM CF Roof - M3 GTS DCT/LSD/DS/Halfshafts/Suspension/Subframe/Brakes/Chassis Bracing F+R - DEFIV Diff Brace - 437M/R888R
2015 X5 35D - 1990 535i [RIP] - 1992 318i Convertible - 2002 540i/6 |
03-09-2021, 06:13 PM | #4 |
Rep 946
Clay bar will probably work. Id be surprised if you needed an actual paint correction for some overspray
I’d be very hesitant to taks a razor blade or anything sharp to my paint
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
tracer bullet2411.50 heavyD^23688.50 |
03-09-2021, 07:26 PM | #6 |
Rep 3,548
I'd say try a "normal" clay bar, if there's more than one level, as a DIY thing. You might get the job done. if not, take it in. If so - hooray. Then add your favorite wax.
I once (once!) did some spray paining in my garage one winter. I ended up clay barring all 3 cars we own. Wore my ass out but did the job just fine (went through like 5 clay bars). |
03-09-2021, 08:16 PM | #7 |
Cole
321
Rep 498
Rubbing compound and a buffer will take it off with no problem.
Go to harbor freight and buy the $5 headlight restoration kit. Toss everything except for the buffing pad and attach it to your drill. Apply liberal amount of rubbing compound such as meguiars to the pad. Spread the compound out and than slowly use the drill. Gradually increasing speed until as fast as it will go. You will watch the splatter disappear with ease. Now the only side affect will be splatter so you'll want to wash the area after. |
03-10-2021, 11:44 AM | #8 | |
Rep 1,532
I have a pack of these for working around delicate areas that I don't want to risk damaging with a steel blade. I'd still try a clay bar and maybe some polish first, tbh you're FAR more likely to damage the paint with some buffing pad on a drill (for example) than you are with a plastic blade
DPelletier675.00 |
03-10-2021, 02:06 PM | #9 |
Rep 2,956
I second clay bar. I once parked at the end of a work parking lot where an idiot decided to rattle can paint his wheels next to my car leaving a massive amount of overspray and clay bar removed it all.
03-10-2021, 06:58 PM | #10 | |
Rep 946
I agree a buffing pad in inexperienced hands could have poor results
Vivek.1366.00 |
