11-10-2015, 02:01 PM | #68 | |
Rep 2,806
Drives: '09 E90 M3 - IB
The video in my previous post is from Willow Springs. Buttonwillow is coming up up next. The data overlay is done using data from an AIM Solo DL and using RaceRender to turn the data into gauges and put it on the video. |
11-10-2015, 02:09 PM | #69 | |
Rep 2,806
I never thought the stock DCT software downshifted quite this smoothly. With this current file, I can downshift pretty much anywhere and the car will perfectly rev match and carry on with it's day. |
11-10-2015, 02:51 PM | #70 | ||
Rep 2,672
OP, curious if you are running in S6 and if you've tried any other setting?
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
11-10-2015, 03:16 PM | #71 |
Rep 2,806
Historically much of my tracking has been done with Euro MDM on. It sits in S5 for that. When I go DSC off, I either do S5 or S6. Honestly I forget about S6 sometimes because I'm concentrating on other things.
11-10-2015, 03:28 PM | #72 | |
Rep 2,672
Do you use Euro MDM in the wet? I am tempted to go that route in the wet to avoid the mud though I do dial it back quite a bit in the wet anyway.
11-10-2015, 04:08 PM | #73 | |
Rep 2,806
Being in SoCal with drought conditions, in the last 4 years, I've had maybe three track days threatened by rain out of 80 days, so I just haven't had any tracking in the rain. And now with all my side windows gone, tracking in the rain doesn't sound like much fun. It's not worth it for me to turn the inside of my car into a lake with all that exposed wiring…… |
11-11-2015, 05:56 PM | #75 |
Rep 2,806
Thanks! I like your equation.
Tires: I really like the TD's. I feel secure on them. Braking grip and corner grip are solid. They don't glide/slide nicely like an R6, but they're faster than R6. I'm trying BFGoodrich R1S next week for the first time. I've heard that they're a fast tire. Aero: I love full aero! It's new to me. Only two events with full aero so far and I've bested my previous times by several seconds at both places I've visited. That's a huge margin considering I'm usually scratching for 10ths and hundredths. But the story is longer than that…...I wanted to drive the car without aero after the gutting and cage install. (I have always liked having the option to be able to go off-track at Buttonwillow if necessary. Front aero is not friendly to off-track excursions.) But the rear became so light, the car did not drive in a balanced way----too twitchy and edgy in the rear---you could just feel it wanting to step out. I tried to put a band-aid on it by getting a rear wing. But I didn't really commit. What that means is I bought a 67" wing large enough to be the right size for a full front-and-rear aero setup---not a wing small enough to just settle the rear a bit. Even with a mild angle of attack, the wing was still too much in wide rounders like Buttonwillow's Riverside and Big Willows Turns 2 and 9. At 75-85mph in a wide rounder, the understeer was mildly disconcerting. At 85+mph in a rounder, the steering wheel became a useless decoration. And if you reduced the angle of attack too much on the wing, then the rear of the car started feeling nervous again. So, the front splitter went on, and the car's balance has been restored. It feels GREAT. Turn-in is amazing at Willow Springs. I need to get used to that. There's actually a fair amount more speed to explore in Turn 8 and 9, which leads me to the next part of your equation----> Balls: haha! It actually takes me some time to build up speed. My brain does not adapt to new abilities in the car quickly. It takes me time to build up trust. When the car was lightened by the gutting, my braking zones were totally messed up. In looking at my AIM Solo DL's data at Buttonwillow, now that the car is lighter, at some turns, I'm braking over 100 feet later, and I still don't have it figured out. That's a significant amount later! The AIM shows how I've slowly been adapting to braking later because the car is lighter. But it's not happening overnight. I'm sure someone else with bigger balls would have that figured out right away! Same thing with this new aero grip. Phew----it's gonna take me some time to sort out how to take advantage of this new aero grip combined with the car being lighter from the gutting. Oh yeah, and then add into the mix a new grippier tire I've never driven…..sure, I'll have that all figured out right away in my warm up lap! Buttonwillow is next on the list. I consider that to be my home track. My best there so far is 1:54.0. The car had full stock interior and no aero. It will be fascinating to see what happens there-----no doubt a solid learning curve. |
11-11-2015, 06:43 PM | #77 |
Rep 2,806
Nothing crazy in the helmet department. I have a Pyrotect that I bought in early 2012 as I was just entering motorsport. I just looked at it right now, but I can't find a readily available model number on it. It was in the $300's range. I've had no complaints about it. I tried several helmets at the time in the store. This one fit fine and seemed a reasonable price. As I recall, the Bell that was in the $500's was quite nice.
Anyway, now it's connected to a NecksGen neck restraint. It was pre-drilled for that and works fine with that too. Last edited by dogbone; 11-11-2015 at 07:49 PM.. |
11-11-2015, 07:47 PM | #78 |
BimmerPost Supporting Vendor
3562
Rep 6,799
Wow, your car has come quite a ways Gabe. Looks phenomenal!
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
11-11-2015, 07:58 PM | #79 |
Rep 2,806
11-15-2015, 12:32 AM | #80 |
Rep 8,077
Drives: 11 E90 M3 Individual
Great looking build! Love the E90 and Interlagos combo. Great idea on the door.
How much wiring did you remove? I'm thinking about doing an E92 build. I'd love to get a non-I Drive car but that seems pretty hard to find. Looks like you kept most of the wiring. I'd start prepping my E90 which has no I drive but I don't want to rape my Monte Carlo Blue paint at the track.
2018 F30 320iX Melbourne Red
11-15-2015, 01:08 AM | #81 | |
Rep 2,806
I did not remove any wiring at all yet. When the build was first completed, I had three track days up in NorCal right away. I had heard from several people that you can be chasing wiring gremlins around for awhile when you strip wiring. I just wanted the car to work. I figured I could strip the wiring later if I needed the weight loss. Honestly, there's much less difficult places to lose weight before I worry about wiring. I still have a stock muffler and rear glass. Before the car was a dedicated track build, I had an Xpel clear bra put on the car. It's a self-healing clear bra. It has done an amazing job keeping the car looking decent. And I have a lot of track days on it. It is starting to show some wear now, but c'mon, I'm being quite awful to it. |
11-15-2015, 09:04 PM | #82 |
Rep 12,736
its going to be pretty cool when you take the clear bra off and its like you have brand new paint on that car.
Instagram; @roastbeefmike
11-16-2015, 07:47 PM | #83 |
Rep 6,218
you should do in cabin videos so you can assess driving even more!
11-17-2015, 01:20 AM | #84 |
Rep 2,806
Ok, some fun news/results from the build: I went to Buttonwillow 13CW today. I wanted to test the full aero and drive the new BFGoodrich R1S tires.
I'll skip to the results: I dropped 5 seconds off my previous best. New personal best: 1:49.02 The car feels amazing----very dialed in. The front aero has completed the build. The R1S tires felt really good. They are an impressive tire. It was REALLY windy out there today. And the wind was definitely causing issues. My best lap came in the last session when the wind was finally dying down. In the video, you can see the afternoon sun is low and DIRECTLY in your face at times. It was still blowing but way mellower than the howling that was going on all day. I'm quite certain the lap time can drop further with the right conditions. Since I've never driven these tires, I don't know how long they stay prime, but they still felt great in the last run. I turned traction control off today because I was just running into it too much. After 4 years, I think I've finally found the limit of Euro-MDM traction control on my car: 1:51.5. As some of you may know, I've been roundly criticized and ridiculed over the last 4 years for leaving traction control on. That's ok, I'm immune to peer pressure. I would certainly never turn MDM off because people poked fun at me. But today, with full aero and faster tires, it was just kicking in all the time. You could tell the car wanted to go faster, but MDM was holding back the power and frequently engaging the brakes on individual wheels (I can see that with the AIM Solo DL). So, I turned it off. I've been practicing with DSC-off---maybe 25% of the time, and I've spent time on a skid pad, so DSC-off is not new to me. Well, the car just popped to life and and the aero was doing it's thing and the tires were doing their thing and it was just a great day out there, regardless of the wind. I am really enjoying this phase of the car---the cage, the lighter weight, the full aero, the R1S tires, the harnesses/neck restraint, the data, the video. It all came together today and worked incredibly well. Here's the bumper cam: |
11-17-2015, 01:27 AM | #85 |
Rep 2,806
I do, but I don't post those.
11-17-2015, 08:07 AM | #87 |
Rep 2,806
Yup, I have a neck restraint. But I use the NecksGen brand, not Hans. On the picture above at the far left edge, you can see the mounting point on the helmet and the red release pull string. I liked the idea of the NecksGen because it offers lateral protection as well as frontal. (I did mention the neck restraint two posts up that has the 1:49 video.)
11-17-2015, 09:36 AM | #88 |
Rep 6,218
Let's see these! Just seeing that bar in the idrive section makes me want to watch it lol
