01-16-2023, 04:05 PM | #1607 | |
Rep 873
Conissah1576.00 |
01-17-2023, 03:39 PM | #1608 |
Rep 1,238
I don't have any pics to show but I have a desire to build a secret bar/speakeasy room in my basement. We have a large utility room that is unfinished that we can cut into to grab some space for the new secret room. I want to do a in-wall bookshelf with the one book that if you pull it the door opens-- apparently you can buy kits that do this.
Anyone have any experience or insight on doing a setup like that?
2024 M2
2019 M240i- Sold |
04-10-2023, 09:33 AM | #1609 |
Rep 1,238
My garage progression
In November I was able to finish off my garage walls and ceiling, installing drywall, insulation, vapor barrier, and fire tape. We added in a tool bench/cabinet setup. Next week we are having our garage floor coated. We are going with this gray/black/white flake assortment.
2024 M2
2019 M240i- Sold |
MoeTE87723.50 vreihen1615551.50 lakefront566.50 dreamingat30fps5419.00 Kilabyte3949.00 BMWGUYinCO4132.50 Wolf 3352368.50 |
04-22-2023, 08:04 PM | #1610 |
Rep 4,823
This is a relatively small but long overdue project.
When we bought our home in 2002, one of our first projects before moving in was replacing the Formica countertops with granite. We purchased something common but decent in 2cm thickness (mistake #1) and a white sink (mistake #2). Over the years, the white sink started to stain and we wanted to replace it, but the granite behind the sink started to crack and it was impossible to replace the sink without doing something about the granite. The crack we learned was because the original installation required a metal rod to support the thin stretch of granite and it was not properly dried and started to rust, which led to deterioration of the granite from below. We had the granite crack repairs (basically filled with crush granite and epoxy) and the sink resurfaced / sprayed (mistake #3). The granite repair separated almost immediately and within a year, the sink started to peel. So we got it sprayed again (mistake #4), and I filled the visible granite cracks with silicone to avoid more water getting in from the top. The faucet was precariously attached to the counter at this point and we thought the faucet could fall over, or worse the granite fail and sink collapse. We were thinking of remodeling the kitchen but we had bigger priorities (impact resistant glass, master bath and roof among them) and inflation ran prices wild so we started looking for a temp solution - maybe something to put off a remodel 3-5 years. We tried to find a slab that was a close match but couldn’t find one in 2 cm, and this would be costly anyway. So we found someone who could cut out the bad granite (and metal rod) and replace it with a piece of scrap he had and purchased a drop in sink with a ledge / lip behind it to cover up what was done. The reason this was necessary is because we had scrap granite from the original install in our garage that I threw away (mistake #5) when we had an ac air handler leak in 2013 resulting in mold over a bunch of items. Anyway, we spent about $2,200 all in for the granite repair, Kraus stainless steel sink, Delta faucet, new garbage disposal, granite guy and plumber. Before and after pics - I think it looks 1000% better and just hope it doesn’t somehow turn into mistake #6. Also glad we don’t need to think about it for a while because this dilemma has been going on for about 4-5 years.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
04-22-2023, 08:20 PM | #1611 |
Rep 3,506
That sounds extremely reasonable compared to what it would have cost in the homes we've owned in the SF Bay Area, New England, and now in SW Ohio.
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
RickFLM411000.00 |
04-22-2023, 08:33 PM | #1612 |
Rep 4,823
I thought so too, especially if it allows me to defer a remodel for a while. Appliances are ok and cabinets look dated but still functioning well. This was the only thing pushing me into thinking of a remodel now.
dradernh4485.00 |
04-23-2023, 08:06 PM | #1613 | |
I'm Batman!
3949
Rep 1,477
S55, 2JZ, M48.00 |
04-24-2023, 08:36 AM | #1614 | |
Rep 1,238
You would have to see what your local garage floor folks are willing to do.
2024 M2
2019 M240i- Sold |
10
nyalpine907444.00 Kilabyte3949.00 vreihen1615551.50 RickFLM411000.00 Alfisti6571.00 cmyx6go15823.00 BMWGUYinCO4132.50 ShopVac4106.00 Car-Addicted7276.50 P111591.50 |
11-15-2023, 07:53 AM | #1615 |
Rep 1,144
Little kitchen update and dry bar! A lot of work still left - backsplash, floating shelves, then eventually refacing the cabinets in the kitchen. I have a couple before shots in there of when we were brainstorming as well. We also redid the floors and painted. It’s coming along!
13
peaceindriving164.50 nyalpine907444.00 infinitekidM2C4223.00 jmack550.00 BMWGUYinCO4132.50 wyatth3553.00 MoeTE87723.50 ShopVac4106.00 Wolf 3352368.50 GeorgeR288.00 MaC-N54-E82494.00 P111591.50 SpeedBuggy640.50 |
11-15-2023, 10:57 AM | #1617 | |
Rep 2,045
Posts Drives: 2022 X6///M Comp Join Date: Aug 2015
11-15-2023, 11:25 AM | #1618 |
Rep 474
Posts Drives: F36 440i GC Join Date: Jan 2011
We moved into our downtown condo this past summer and began doing some remodeling.
Here's a quick before and after of the garage: I will probably swap out the old florescent light for something LED and add a few more cabinets for storage. We have a lot more planned. Gutting and remodeling 3 bathrooms, full remodel of the kitchen and bathroom conversion to a pantry, custom closet, all new hardwood, new windows, etc.
2024 Porsche Taycan 4S
2017 Ducati Monster 821 |
11-15-2023, 03:07 PM | #1619 |
Rep 1,238
Thanks! It technically isn't epoxy. I think they call it poly-aspartic or something. The workers lay down primer on top of the cement, then broad cast all the colored flakes, finishing up with a clearcoat over the flakes. You can feel the texture from the flakes through the clear which gives it some traction. When it gets wet it's a little slippery but not too bad. Then the step into the house they add some grit. Next up is keeping it clean during the winter months here in MN.
2024 M2
2019 M240i- Sold |
11-16-2023, 09:23 AM | #1620 |
Rep 1,238
Here are a couple recent pics. After our flooring was done we got our cabinets all situated. Prior to the NFL season I did add a couple new TV's in my corner TV nook. It has turned into the neighborhood fantasy football command center.
Last week we had an electrician install a 220 circuit and hang a DynaGlo 7500 watt electric heater. The thing works great!
2024 M2
2019 M240i- Sold |
05-13-2024, 08:05 AM | #1621 | |
Rep 3,560
What flooring finish is that? |
05-19-2024, 12:03 PM | #1622 |
Rep 218
Finally wrapping up a Kitchen Remodel that included replacing the Family Room cabinets to match and replacing an old desk with a beverage bar.
The kitchen has refaced cabinets and new quartzite countertops and an induction cooktop. The beverage bar has matching quartzite counters and I was able to add a sink which made installing a water filter and plumbing the espresso machine possible. The family room now has larger cabinets for the AV components and cooling fans and screen doors for airflow. The amplifiers are in a cabinet in the crawlspace below the family room. The floors were refinished and we can replace the area rugs, runners and door mats. We are still waiting on the cabinet maker to put crown molding on the beverage bar cabinets, add some trim and replace a few doors that were either the wrong size or slightly warped. |
05-19-2024, 01:40 PM | #1623 | |
"Salud"
13980
Rep 4,689
Posts Drives: F01 & F15 / Mineral White Join Date: May 2013
I just finished remodeling our large kitchen island. Pics coming soon... |
GeorgeR288.00 |
05-19-2024, 01:48 PM | #1624 | |
Rep 3,413
Have you had an induction cooktop before? If not, you are in for a treat. If so, you already know you made a good choice. |
GeorgeR288.00 |
05-19-2024, 02:01 PM | #1625 | |
Rep 218
Thanks. |
05-19-2024, 02:31 PM | #1626 | |
Rep 3,413
Yes, there is a learning curve. Once you have new compatible pans and get the hang of it, induction is fantastic. In addition to great heat control, wicked-fast boiling, and easy to clean top, there are a couple of other things we found. 1) The kitchen walls, ceiling, and cabinets remain cleaner than with a gas cooktop, and 2) You can use it as a countertop when not cooking on it. You'd be surprised how handy this can be if you decide to try it. Anyway, your remodel is fantastic. Best of luck with adjusting to induction cooking. |
05-19-2024, 03:21 PM | #1627 | |
Rep 218
I don't know how susceptible the ceramic is to scratching but the stainless edge looks like it can scratch easily. Thanks. |
05-19-2024, 03:58 PM | #1628 | |
Rep 3,413
Enjoy! |
