      11-12-2019, 02:06 PM   #23
FuriouslyFast
Drives: Miss Daisy
Just hire a hooker to put them in while she gives you a hand job
      11-12-2019, 02:41 PM   #24
M_Six's Avatar
Someone changed the title of my thread. Does that happen all the time?
"There is no shame in dropping fruit in your glass."
      11-12-2019, 02:43 PM   #25
upstatedoc
I'll get back to you
upstatedoc's Avatar
7564
Drives: blue streak
sometimes it's just never enough
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/
Countermeasure enthusiast.
King Rudi13154.00
      11-12-2019, 03:45 PM   #26
UncleWede
UncleWede's Avatar
Only when you can't see because you can't put your lenses in correctly
M_Six16966.50
      11-12-2019, 05:04 PM   #27
overcoil
Drives: M235i 6spd
When I was in college I took a program and got a NCLE (National Contact Lens Examiner) it was like a licensing for some states or certificate with not much punch. Doctors office should teach you insertion and removal to the point your pretty proficient and they should be very agreeable to follow up instruction.
A good mirror at a comfortable level can be very helpful. It just takes practice.
      11-13-2019, 02:42 PM   #28
No one
Drives: F21 118i
I saw only one angry message from a person whose post had been changed so far.
I was taught to do it without a mirror at once. A mirror is a bad addiction: it's very helpful to have no need for it all the time.
      11-13-2019, 03:14 PM   #29
FuriouslyFast
Drives: Miss Daisy
Hope she's a hot doctor!
overcoil3073.50
      11-13-2019, 03:19 PM   #30
MKSixer
MKSixer's Avatar
34185
Drives: 2015 BMW i8, E63 M6, 328d
2016 M4 GTS (Allotted)  [0.00]
2013 BMW 328d  [0.00]
2007 BMW M6  [10.00]
2015 BMW i8  [10.00]
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion.
Rmtt8211.00
King Rudi13154.00
      11-13-2019, 03:29 PM   #31
Mintsopoulos
Mintsopoulos's Avatar
Drives: '15 MW F80 6MT
I start with this mechanism.
MKSixer34184.50
King Rudi13154.00
      11-13-2019, 03:37 PM   #32
overcoil
Drives: M235i 6spd
Whatever works, but I didn’t want people to think using a mirror is incorrect
https://www.ooa.org/aws/OOA/asset_ma.../110768?ver=82
      11-13-2019, 04:36 PM   #33
No one
Drives: F21 118i
I thought most people didn't even know it could be done without a mirror.
      11-13-2019, 11:24 PM   #34
ericsbestshot
Drives: none
I just keep stabbing my eyeball till it sticks. I keep thinking the harder i press the better it will stick.
      11-14-2019, 02:09 AM   #35
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3045
Drives: 340 6MT, 50e, others
Takes time. Use mirror at first. Once you can open your eye and not flinch you'll be ok. Takes about 6 months. if you think they suck try scalera lenses !
      11-14-2019, 03:47 AM   #36
No one
Drives: F21 118i
That's wrong. It's not gluing. You push the air from under it and it sticks due to the vacuum created (atmosphere pressure). It can hardly stick "better". It either sticks or not. It does not take much/any effort to apply it properly and that should be done gently. It should be done over a table with some clean cloth or paper towel on to drop it safely if that happens. You can blink a few times to make sure it sits well. It can be also moved through the eyelid (closed) to position properly.
Well, I can't find confirmation of my lens sticking due to "vacuum" idea, they are supposed to let some oxygen in and still I'm absolutely positive it's not gluing - no need to press hard or hold depressed long.
Rmtt8211.00
      11-14-2019, 06:04 AM   #37
Rmtt
Rmtt's Avatar
Drives: 2011 BMW 128i, 2008 LS3 C6
I do it this way without a mirror. But I have worn them for close to 30 years. I don't even think about it now and can do it with one hand. Lens on my pointer finger, middle finger pulling my lower lid down, look up...and basically let the lens do all the work.
My prescription hasn't changed since I have been in lenses...when I started we used the hard lenses. I wear the Accu-Vue Dailies. But they are phasing them out and going with their Oasis brand. Something in that formulation of lens does not agree with me...and I have issues with them.
So I bought up over a year of stock with the others. When I run out...I may look into Lasik.
      11-14-2019, 06:07 AM   #38
cmyx6go
cmyx6go's Avatar
15763
Drives: 2022 X6///M Comp
2019 X6 ///M  [10.00]
Originally Posted by MKSixer View Post
Me MK
MKSixer34184.50
      11-14-2019, 06:42 AM   #39
cmyx6go
cmyx6go's Avatar
15763
A few of mine have been changed. Apparently your title needs to be as precise as possible in describing the context of the thread.
Raises hand.
King Rudi13154.00
      11-14-2019, 08:40 AM   #40
No one
Drives: F21 118i
I started wearing contact lenses over 33 years ago. Those were soft at once. I learned to apply them without a mirror initially and though I might've used the same application technique at first it absolutely didn't take me decades to turn to how I do it know: put it on the index finger and apply straight where it should be, looking forward. This simple.
My first lenses were 2 years ones if I recall it correctly. Then I wore 1 year lenses, surely. Now I wear Air Optix Aqua which are monthly. My only issue with them is I can't see well what's close: I see close without them better. I never noticed this before with other lenses. I'm not interested in daily but I've just read they are less oxygen-transparent than monthly. That's not good.
I looked what Lasik was when I saw it mentioned in this thread. As it has been noticed here, Lasik doesn't look the most reliable method. Anyway, I will never take even the least risk of eye surgery while I can do without it.
      11-14-2019, 09:47 AM   #41
Yapakanichi
Monkey Marshall
Yapakanichi's Avatar
635
Drives: 2005 Z4 3.0i
Pull bottom eyelid down, put contact just a little lower on eye (1 millimeter maybe), close eyes and blink a few after. Should be good. Lubricate eyes throughout the day as needed.
      11-14-2019, 10:13 AM   #42
UncleWede
UncleWede's Avatar
Not dailies, but I got switched to the Oasis because of graduated bi-focals. Better than the previous for me, in that they don't masquerade as being properly situated for insertion. The previous Accu-vue would sometimes be inside-out and I couldn't tell. Oasis are always right-sided.
      11-14-2019, 11:17 AM   #43
Rmtt
Rmtt's Avatar
Yeah....they have a number printed on them of "123". You can hold it up and see if if it's oriented right.
My eye doctor said he had a few people that had some issue with Oasis...and I know there are huge threads about it on the internet.
When I run out of these, he wants me to give Hubble a try.
      11-14-2019, 11:41 AM   #44
King Rudi
King Rudi's Avatar
13154
Drives: Meat Suit
Point me in the direction of the hooker with four arms please.
Typically only if the thread is completely off topic, has no relevancy whatsoever to anything regarding cars or BMW's and usually a thread where everyone is getting along......oh and moderators aren't tagged; those just get deleted.
Originally Posted by upstatedoc View Post
sometimes.....
Viddy well, little brother. Viddy well.
"Ho, ho, ho! Well if it isn't fat stinking billy goat Billy Boy in poison! How art thou, thou globby bottle of cheap stinking chip oil? Come and get one in the yarbles, if ya have any yarbles, ya eunuch jelly thou!"
Rmtt8211.00
