04-07-2013, 10:33 AM | #23 |
Rep 3,995
Another thing I just noticed is that the timestamps shown for 'last post' while browsing through topic lists are incorrect. However, if you go into the actual thread the time is shown correctly. I think the topic list time is not being adjusted from GMT.
See attached, in the topic list view it shows the last post of 'WTB SOCAL: Gitani Race Rear...' as 7:14 AM, but in reality the last post was made at 1:14AM (local time).
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic |
04-07-2013, 09:37 PM | #24 |
Rep 92
1) Scroll to top option by tapping top of screen not working anywhere on the new application.
2) Option to unsubscribe particular threads not available. Re-tapping the subscribe button after subscribing keeps displaying "successfully subscribed" alert. Thanks, e9292121 |
04-08-2013, 07:59 PM | #25 |
Rep 4,201
Thanks to @etek @135 and @jzbm3 for the bug reports. The first post has been updated and your bugs have been added to the list for fixing!
@E9292121 to unsubscribe a thread, swipe over the thread title from the subscribed threads list, a button that says 'delete' will appear, press that and it will unsubscribe you from the thread |
04-10-2013, 01:50 AM | #26 |
Rep 127
Not sure if its just me but when pressing "quote" to respond to a post the text on the thread is all jacked up. It usually happens when I quote a quoted post. It'll show first quoted text in quote box but post I'm actually quoting looks like I typed it but tried to add [quote/] to it
04-10-2013, 11:22 AM | #27 | |
octane chick
79
Rep 1,187
Posts Drives: ex-M Join Date: Oct 2010
At the bottom, it says "Error messages will only be displayed during development. When your app is packaged for final distribution, no error screen will appear. Test your code!" Only now, in testing this in portrait orientation, did I see the bottom of the error screen. Previously I had viewed it only in landscape orientation, which does not resize or responsively lay out the page contents. [See attached screenshot] But-- I seem to be.... Semi-logged-out? I just noticed that the app avatar states I am logged out, but I can see some of My Forums. Behavior is as if I'm only partially logged in. I just went to the Settings page and logged in, and now I no longer get the Subscriptions error, but otherwise have the same experience in the app. Same subset of My Forums, etc. So it's like I was logged in before, except for subscriptions and avatar. Maybe some cached configurations from the previous version of the app were lingering, interfering with the current app? Usability feedback: Every time I load the application, I tap on almost-invisible forum icon in top center, but find only the main forums menu. Then I realize that I should tap on the logo in the top left. It's a bit counterintuitive to have the rest of the forum links hidden behind the logo. Would be nice to have all of those options together. |
04-10-2013, 12:11 PM | #28 |
octane chick
79
Rep 1,187
I just now got the RSOD when trying to save an image. I touched the save button and there it was.
04-19-2013, 08:44 PM | #30 |
Rep 682
Version 2.03
Tapping (short or long, dependent on the Last Read Post setting) on a subscribed thread does not go to the last read post. Applies to both read and unread threads in the Subscriptions list. Ampersand (&) does not display correctly in Messages list or title. In Message list -> &amp In Message title -> & Possible cause may be related to escaping in either HTML or XML encoding. May need to ensure other escapable characters encode correctly. Last edited by 135; 04-19-2013 at 11:02 PM.. Reason: Added an additional bug |
04-26-2013, 12:51 AM | #31 |
Rep 682
Version 2.04 is available.
Tested the fixes and confirmed to work as expected. v2.04 has also resolved the following bug:
04-26-2013, 01:04 AM | #32 |
Rep 682
This post is for testing a bug regarding indentation.
... and here is some text that is indented outside of a list TEST 2: This is a another testto test multiple indentationincluding a third indent
Note: there is supposed to be three blank lines between TEST 2 and 3. Last edited by 135; 04-26-2013 at 01:14 AM.. Reason: Added further tests |
04-26-2013, 01:15 AM | #33 |
Rep 682
Version 2.04
The following bugs still exist:
Note: Unordered Lists and Indentation are displayed correctly in a web browser. |
05-22-2013, 02:21 AM | #34 |
Jedi samurai ninja turtle
619
Rep 3,021
Posts Drives: X3 M40i 2018 Join Date: May 2012
Creating new threads is playing up.
When you select 'new' the new page does not appear on the page, but it actually appears when you navigate to the top left menu/logo button > forums. |
06-28-2013, 07:42 PM | #35 |
Rep 107
Connection Error
Odd that this one hasn't been mentioned yet. Frequently (usually?) when browsing the main E89 forum I get "Connection Error" even though I have good wireless signal, and other apps on my phone/pad as well as though out the rest of my home network are working fine. I'm wondering if its a scalability/capacity issue as browsing to some of the other E89 forums (like classifieds and such) ~usually~ don't have this problem.
It's been like this for years & across versions... |
07-16-2013, 12:18 PM | #36 |
***** noob
1366
Rep 10,479
Posts Drives: 325xi>M235i>428GCx Mspor Join Date: Sep 2005
I have uninstall/reinstall the iphone app at least 30 times cuz it keeps getting hung....sorry I gave up on this app
08-13-2013, 10:25 AM | #38 |
Rep 682
This post is for testing a bug regarding font types and font sizes.
Here are a selection of fonts: This is the <default> font. This is Arial font. This is Comic Sans MS font. This is Courier New font. This is Lucida Console font. This is Tahoma font. This is Times New Roman font. This is Verdana font. This is the default font size. This is font size 1. This is font size 2. This is font size 3. This is font size 4. This is font size 5. This is font size 6. This is font size 7. |
08-13-2013, 11:13 AM | #39 |
Rep 682
Version 3.0.0
Here are some bugs that I have identified:
Perhaps the iOS app is supposed to be more lightweight than the browser experience but my usage and preferences don't change between the app and browser so below are some suggested enhancements for your consideration:
That's it! Last edited by 135; 08-14-2013 at 08:09 AM.. Reason: Added an extra suggested enhancement |
10-08-2020, 08:58 AM | #40 |
Rep 1,079
On my iPhone/iOS app my attachments are shown twice or repeated. On my post linked below it shows up fine on desktop and mobile browser but in the iOS app I see one of the pics showing up twice. It seems like the app is displaying one image on its own apart from the ones I am displaying using the attach tag. I'm running the latest iOS and bimmerpost version on iPhone 11 max pro but have noticed this in the past on my iPhone X also. I created the post on my laptop:
https://www.bimmerpost.com/forums/sh...php?p=26772732 EDIT: Just realized I deleted that post, my new post looks fine on the iOS app as well as mobile and desktop browsers. I wonder what was different with the previous one, maybe the size difference played some part? Let me know if you guys want me to replicate it, I can use the same pics in a similar manner as before. Last edited by thatBimmerBloke; 10-12-2020 at 02:11 PM.. Reason: Add more info |
04-13-2021, 07:45 AM | #41 |
Field Marshal
6726
Rep 1,829
Posts Drives: '08 E92 M3 Join Date: Jul 2010
iPhone Notifications with iOS 14.4 no longer work with the latest Bimmerpost App version 4.6.7.0
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium63031.00 Cabbage624.50 |
05-01-2021, 01:30 PM | #42 |
Rep 1,165
It's been like that for months..
2018 BMW F80 ///M3
570WHP/578TQ |
05-23-2021, 11:16 PM | #43 |
2134
Rep 1,834
Posts Drives: Many, BMW. Join Date: Aug 2007
Please hire someone to maintain and update the app, it's one of the biggest assets to Bimmerpost, yet receives the least management.
I'm having the hardest time with attachments, as well as notifications. |
MisterF80M31045.50 |
05-27-2021, 06:21 PM | #44 |
2134
Rep 1,834
WTB: Bimmerpost App
