E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > Who is taking his 335 to the track??
Reply
      01-21-2009, 04:31 PM   #1
bbbsti ltd
Drives: Subaru STi
I wonder how are the 335's holding up at the track (road course)?
How are the engines holding up at the track? Any incidents of broken ringlands of fatal engine failures on stock or just slightly modified cars?
I am thinking on trading in my 2007 STi for a BMW 335, I would like to take the car maybe twice a year to track events.
I cant imagine repairing a 335 engine damaged for knock or detonation because of extreme or hard use at the track.
Thanks
      01-21-2009, 04:51 PM   #2
Hoothout
Hoothout's Avatar
Drives: 2008 BMW E92 328i
2008 e92 328i  [0.00]
many people take their 335's to tracks, i havent heard of any problems at all.
2008 SG E92 328i
iDrive,Premium Pkg,Sport Pkg,Cold Weather pkg,Black Dakota Leather,GP Thunder 8500k cornering,drl,and foglights, ,Blacked Out Grills,Painted Reflectors,Shadowline Emblems,Hardwired Beltronics V-995, AFE Intake, Muffler Delete, Berger tune
      01-21-2009, 04:54 PM   #3
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
If you are really fast you might get 'limp mode' on a hot day of extended tracking even with the stock oil cooler.
Some people are concerned that the 335 runs oil hot, but 335 is too new to be able to determine whether it makes a difference
If you are only going twice a year to DEs I suspect the 335 will be just fine
      01-21-2009, 05:13 PM   #4
mike-y
just another bmw douche bag
Drives: 1.9L of fury
early 335's did not have the oil cooler. A friend of mine with a '07 reported it only took about 6-7 laps for his oil temps to become "uncomfortably hot". He has since ordered the factory oil cooler kit, which comes as standard equipment on newer cars.
check out the Track/Autocross forum, you might get some better feedback on the issue.
      01-21-2009, 06:41 PM   #5
MRQturbo
Drives: 91 MR2 turbo....07 335i...
no problems so far after all track days...drive it there...drive it on the track...drive it home....gas mileage is severly decreased though....lol...
91 MR2Turbo....07 335i....
      01-21-2009, 08:00 PM   #6
digivue
digivue's Avatar
Drives: '09 E90
I am wondering if guys who track their cars lease or own them? I cannot imagine myself abusing my own car or risking wrecking it..., which is a big PITA with the insurance , unless your money grow on a tree of course.
      01-21-2009, 10:49 PM   #7
Blue335i
Blue335i
Blue335i's Avatar
Drives: Blue 335i Sedan
My 07 335i sedan has been to the track 4 times, and the problem is; Hot Oil, even with a factory Oil Cooler.
First time, no OC, overheated in 70 degree weather at Sears Point. OEM OC installed, oil overheat, a.k.a. lip mode at Thunderhill, though it was 100 degress out. Back at Sears point, about 70, hot, but no limp mode. I slowed when it got to hot for a lap. Last week at Laguna, 75 degress, it was hot again, but no limp mode, came close a couple of times.
Running hot keeps me from totally pushing the car.
I have a VKwerk OC to install, but due to an oil and transmission leak spotted while attmepting to install the OC. I had the shop stop and then I had to take it to the dealer and miss my opertunity before my track day.
At Laguna Seca, I did get a ride in the Dinan 135 with a Dinan OC and it never got above the 260? degree spot. the VK should be almost as good, as it is the same core, but no extra duct.
One other smaller issue - no LSD. Cornering you get one wheel spining it is not good (I installed an LSD just this month). This is even more evident in Autocrossing.
Bottom line; for a track day you have to have a Factory OC.
      01-21-2009, 11:43 PM   #8
leftcoastman
Drives: 335i
50+ track days, tuned the whole time. I'm an instructor, so not exactly driving it like a grandma.
Stock oil cooler got me to 290-295 oil temps, VK motorwerks cooler keeps me at the 270 range.
Engine hasn't blown up yet.
      01-22-2009, 12:01 AM   #9
scollins
Bootleggin' 'n Gunrunnin'
scollins's Avatar
137
Drives: 2024 X3 M40i
I'm wagering you have an Auto, yes? If so, more than likely your limp modes were caused by excessive coolant temps and not excessive oil temps. That is not to say that 6MTs don't hit limp modes on the track occassionally too, but the Auto also relies on the stock cooling system. Upgrading the oil cooler may have helped a little, but I bet an Auxilliary auto trans cooler would have prevented your limp modes.
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles
2019 Ford F450 STX, Oxford White
2013 Ducati Multistrada Touring S, Red
      01-22-2009, 12:09 AM   #10
ianbiz
Back in a BMW
ianbiz's Avatar
Drives: 2015 335i Msport
http://www.e90post.com/forums/forumdisplay.php?f=98
Ian
      01-22-2009, 12:16 AM   #11
darkphantom
Drives: E93 335i
wow, after a good 20-30min of hard driving through the twisties my temps max at 260 barely... stock IC
      01-22-2009, 12:25 AM   #12
leftcoastman
Drives: 335i
With all due respect, street use is NOTHING compared to track use. additionally, even with track use, if you're a beginner, you'll probably have no issues with heat.
See below
http://www.e90post.com/forums/showpo...8&postcount=14
      01-22-2009, 10:54 AM   #13
mike-y
See below
+1
      01-22-2009, 11:03 AM   #14
Rando
What is the warranty impact of taking the car to the track? That is what keeps me from it... if something happens, I don't want to lie and say the problem happened somewhere else. Thanks!
      01-22-2009, 11:11 AM   #15
vgame64
vgame64's Avatar
Drives: BMW 335i
I'm not sure of BMW NA's official stance, but I am quite sure if some component fails while tracking the car, and you let them know of this, they won't cover it as it will be considered abusing the car out of its intended purpose. (I think this has happened to a few M3 owners who then complained saying that even the brochures show the car on a track). If they don't know you tracked it, and they are dump, they might cover it under some premature wear clause.
If they know you are tracking, they will most likely not replace worn components like brakes etc.
And if you get into an accident, and BMW assist logs your position, most likely you are screwed with insurance, screwed with the track (you signed a waiver), and screwed with BMW.
I suggest you track your car only if you can accept the risks.
      01-22-2009, 11:15 AM   #16
vgame64
vgame64's Avatar
Drives: BMW 335i
Thanks
At a track event I went to, I saw a non-sport 335i running (it was his last day on his lease ) when it was around 65 degrees outside and he had no limps.
      01-22-2009, 02:56 PM   #17
335e92tx
ahat
335e92tx's Avatar
1036
Drives: Was '07-335e92 - Now '13-335IS
My track experience (first time - just getting the feel for things)
http://www.e90post.com/forums/showthread.php?t=186387
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos.
https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8
      01-22-2009, 03:56 PM   #18
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
drive harder?
      01-23-2009, 07:14 AM   #19
ImolaZHP
ImolaZHP's Avatar
Drives: E46 Imola ZHP coupe
I went to NJMP in hot August last year with NJBMWCCA. We were a group of friends - 06' E90, 07' E92, 08' E92 with sport and cooler. There were also other E92's at the event also.
Only one guy approached and asked about limb mode. He had a 08'(or 07') car with sport and cooler, but he had problem.
We were not in the high level class, but we drove hard. The only thing we do is replace brake fluid and engine oil before the event. We run stock pads. We chased down E46M. We chased down Porsche C4 at PCA events. I haven't had a problem with E92. BMW is reliable, no worry.
2014 F25 35i M Sport
2010 E90 SG M Sport - ED -> recycled
2008 E92 AW ED -> Nurburgring -> PCD -> recycled
2005 E46 Imola ZHP -> back to BMW recycle bin
      01-23-2009, 08:24 AM   #20
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Drives: Green Bastard
This is very YMMV. Some cars perform great see leftcoastman others not so well see myself/S4to335.
Luck of the draw.
      01-23-2009, 09:12 AM   #21
S4to335
Drives: 2014 Audi A4 / 91 Track Miata
Luck of the draw.
Last week at Laguna Seca..I hit oil temps of 290 and backed off...it was only about 72 degrees at the time. I didnt have any limp modes or CELs.
Car is now gone .... :-(
      01-23-2009, 10:32 AM   #22
leftcoastman
Drives: 335i
Luck of the draw.
Make no mistake - with stock OC, my car got hot as a biotch.
The ONLY time I have ever "heat limped" on a stock OC is at Miller, where you constantly go from mid triple digits to low corner speeds. So I was on boost like you've never seen.
With an upgraded oil cooler, that problem is now diminished. I believe there are only two choices out there now:
1) VK Motorwerks - $600? and is a pain to DIY, but can be done by your mechanic pretty easily.
2) Dinan - Same as above except $2,000.
Reply
e90post
